09-22-2018, 02:56 PM | #1 |
Respect My Authoritah
368
Rep 873
Front end wobble noise over small bumps at low speeds
Hoping that someone can help me pinpoint this issue. When going over bumps or road imperfections at low speeds, I get a wobbling noise coming from the front end of the car. It sounds like a blown strut, but it isn't....It just sounds like it. It happens when going straight over a crack in the road that touches both tires at the same time. If I drive over a man-hole cover with just one tire, it doesn't make the noise. It doesn't do it when turning, or at high speeds.
I put the car on ramps, removed the belly pan, and looked for things out of the ordinary. I found nothing, no leaky anything, no loose anything, nothing. I checked things like the charge-pipe, the intercooler, the waste-gate, the turbo, etc... Common issues like the sway bar links, or tie-rod ends seemed fine... nothing was easily moved by hand. I even checked the motor on the steering rack which has been known to have sheared bolts connecting the motor to the rack. I've searched to find information about this, or similar cases. Ultimately, I learned that the rack and pinion could cause the noise. I've read about the rack being replaced and the issue leaving and eventually returning. I've read about the rack being replaced and the issue never retuning. I've read about the rack being replaced and it not fixing the issue.... I've noticed zero issues with steering, but since it only makes the noise when it tracks straight, it does point to this part. I have CPO coverage until 2020, but don't want to pay $150 for them to tell me it's normal. I'd like to find the issue before going to the dealership so I can tell them to look at and replace xxxx part. Drivability isn't affected, it's just an annoying noise. I have the adaptive suspension. Anyone have/had this issue that they were able to fix?
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
11-29-2018, 09:16 AM | #2 |
368
Rep 873
Anyone have experience with this? Now that it's colder, the wobble became more frequent. It's driving me crazy.
11-29-2018, 09:54 AM | #3 |
Rep 445
I have an m235 and have been meaning to post about issues that seem similar to yours. When on bumpy/uneven roads at low speeds I get a rumbling noise almost resembling a bad wheel bearing(blown strut noise is also a good comparison), but the car feels completely fine. I have only just noticed this noise so I have not played around underneath my car like you have, but now that I think about it, I notice it the most when driving straight. I'm also in the same boat as my regular warranty just ended and I'm now under CPO. My car only has 25k miles, any failed suspension parts would be odd, especially considering it feels just like normal. Would also love to know if someone has gone through the same thing and resolved this noise.
11-29-2018, 09:59 AM | #4 |
Rep 1,288
Are you Xdrive? I'm Xdrive and when I hit small bumps it sounds the same... I figured it was the CV joints... to makes sure I took it in and had them check the suspension and everything was okay...
11-29-2018, 10:07 AM | #5 |
Rep 799
I have been noticing a slight wobbling shimmy sensation over certain surfaces at low speed but not a noise .... I'm in the midst of doing sway bar end links / check the wheel balance / alignment / re-torque everything to see if that helps.
As far as a noise goes it could be the strut top mount .. those are junk. And yes I've read the steering rack as well. Could be endlinks / CA bushings. |
11-29-2018, 11:37 AM | #6 |
Rep 884
Please watch this video:
See if you can replicate the noise by turning the steering wheel while the car is off. I been dealing with what I believe is this exact issue for over a year. Initial reco from the dealer was to replace both front EDC dampers for $3K 😳 Car is going back in a year later (on Mon) to revisit to look at the EPS based on my research. Will keep you posted. |
eluded3065.50 |
11-29-2018, 12:07 PM | #7 | |
368
Rep 873
I've spent hours researching this and have found a lot of info on it. From what I've read, it's the steering rack, but a replacement might not fix it. If it does, it might even come back down the road... people are being told to live with it but it really bothers me. It just sounds cheap and shitty. The one that mentioned that it sounds like a rumble hit it right on the nail. At high speeds, I never hear it.
11-29-2018, 04:58 PM | #8 |
368
Rep 873
I am X-Drive!
11-29-2018, 05:27 PM | #9 | ||
Rep 884
11-29-2018, 05:49 PM | #10 |
368
Rep 873
Yes. I verified today that it makes that noise. I've read reports of people stating that they were told that all of them do it. One even said that his SA brought him to brand new cars and they did it too...
11-29-2018, 06:15 PM | #11 | |
poopycat
266
Rep 791
11-29-2018, 08:05 PM | #13 | ||
Rep 445
11-30-2018, 09:07 AM | #15 |
368
Rep 873
Thanks! I guess that's not linked with the issue.
12-03-2018, 11:28 PM | #16 |
Rep 1,288
12-04-2018, 11:18 AM | #17 |
Rep 21
I notice I hear a noise that sounds like it's coming from the front left of the car. I can hear it loudly if I go over a speed bump with just the left tires.
12-04-2018, 12:01 PM | #18 |
Rep 5,244
I have a low speed clunk that disappears at speed. Had the drivers side shocks replaced but sound persists. Going back in on fri and will update you all after that.
12-04-2018, 12:24 PM | #19 |
368
Rep 873
Thanks! Have them check the rack.
12-04-2018, 01:03 PM | #20 |
Rep 445
Oddly enough the noise is more prevalent when its cold, probably why I am just now noticing it since it takes a while for winter to reach down here. Weird that I did not notice it after I bought the car in Jan of this year. Temp would make me think something rubber and suspension related, but again nothing I can feel- only noise.
12-04-2018, 01:43 PM | #21 | |
368
Rep 873
12-04-2018, 02:08 PM | #22 |
Rep 552
Might be worth checking all the nuts and bolts are tight.
I didn't tighten a rear lower strut bolt tight enough. Everything felt tight by hand as there's tension in the suspension. But it was knocking over bumps. Tightened it up properly and the knocking went away. |
Korvo368.00 |
