BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > 72k what maintenance recommended
      02-17-2019, 04:45 PM   #23
bavarianride
Drives: bimmer
Originally Posted by cesarortiz23 View Post
Right now the coolant on my reservoir looks blueish green
But I am going to do that check and see how it goes
Do extract some coolant into clear bottle to check, looking into reservoir may not be as accurate.
      02-17-2019, 07:52 PM   #24
IraHayes
Drives: 328i
If you do the voltmeter test, it’s .4 volts or lower, not .04; put my decimal in the wrong place lol. Some people say .3v, some say .5v, so you may want to go with the lower number if you want to play it extra cautious.
      02-18-2019, 04:40 PM   #25
Broadsword
Sustinendum Victoriam
Drives: '13 335i
I'm about the same mileage and getting walnut shell blasting done. I will post pics once I get them from the indy shop.
      02-18-2019, 07:02 PM   #26
sspade
sspade's Avatar
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
What engine?
How much are you paying?
Dealer, Indy, DIY ?
      02-18-2019, 07:59 PM   #27
bavarianride
Drives: bimmer
Originally Posted by sspade View Post
What engine?
Dealer, Indy, DIY ?
One data point is local indy quotes $600 for walnut blasting.
sspade2466.00
      02-19-2019, 06:38 AM   #28
Broadsword
Drives: '13 335i
What engine?
Dealer, Indy, DIY ?
N55. Indy. $490
sspade2466.00
      02-19-2019, 05:28 PM   #29
Broadsword
Drives: '13 335i
Pictures from the shop.
      02-19-2019, 06:29 PM   #30
bavarianride
Drives: bimmer
That looks good. Is there any CEL/error code after the walnut blasting?
      02-19-2019, 08:04 PM   #31
Broadsword
Drives: '13 335i
This is the before walnut blasting picture. I will upload the after pictures when I receive them.
sspade2466.00
      02-19-2019, 08:21 PM   #32
bavarianride
Drives: bimmer
Got it, that does not look too bad to start with. How many miles and years?
      02-19-2019, 08:27 PM   #33
Broadsword
Drives: '13 335i
72,839 mi. Just over 6 years.
      02-19-2019, 11:00 PM   #34
bavarianride
Drives: bimmer
Were the photos taken with the intake manifold removed, or the mechanic was able to snake in borescope with a few simple steps?
Honestly@73k miles and 6 years, your intake valves look relatively clean.
Did the mechanic say u need walnut blasting due to rough idle or something?
      02-20-2019, 07:22 AM   #35
sspade
sspade's Avatar
I agree... valves look fine at 75k miles.
Ever ran a catch can?
I thought the N55 was more prone to carbon buildup due to DI.
Wonder what an N20 with this mileage looks like.
      02-20-2019, 10:53 AM   #36
n00bkiller944
Drives: '14 328d M Sport
Agreed. I am surprised they recommended it for how clean it looks
      02-20-2019, 12:19 PM   #37
bavarianride
Drives: bimmer
N20/N26 is also DI, so it is susceptible to same carbon buildup if present.
      02-20-2019, 12:21 PM   #38
bavarianride
Drives: bimmer
Probably just soak the valves with cleaner and let it sit overnight, and the thin layer of deposit can be stripped without walnut blasting. Then vacuum extract any pooled cleaner and call it a day.
That's assuming the intake manifold is already removed(which probably is the case).
      02-20-2019, 04:02 PM   #39
Broadsword
Drives: '13 335i
Photos were taken with the intake manifold removed. I have an issue at random times where the idle fluctuates very badly almost like the car is going to stall at start up.
Mechanic ran diagnostics and everything checked out except one time fault on cylinder 2. Mechanic wanted to verify it wasn't due to carbon build up on the valves. Still having him walnut blast it as a maintenance item; only would've saved .8 hours of labor if he didn't clean them.
Never ran a catch can.
