02-17-2017, 02:25 PM | #133 |
Rep 190,807
Thanks to Zepeda Vlogz for posting this DIY / review video
07-29-2017, 02:06 PM | #135 |
Rep 1,454
Just in case anyone made the same mistake: I dropped the bracket allen wrench screw for the intake down in the engine bay.. (I know, I'm dumb). After a few trips to Home Depot, 10-24 1/2" was an acceptable machined screw for the bracket. 8-32 was just barely too small, and the 10-24 is a bit snug but will screw in without stripping the threads much. 1/2" is the desired length that works, no nuts/washers needed.
2022 CT4-V Blackwing 6-speed
07-29-2017, 02:19 PM | #136 | |
Rep 2,964
G.Newt810.00 |
07-29-2017, 10:39 PM | #137 |
Rep 1,454
The screws and accompanying nuts were around $1+tax at my local Home Depot. It'd probably cost more to ship the screw to you than it's actually worth lol.
07-30-2017, 09:47 PM | #138 | |
Rep 190,807
I do not have a dyno with M power kit but gains should be the same as the standard version.
07-31-2017, 01:01 PM | #139 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
I got a CEL the other day. Scanned the code and it showed P00BC Mass or Volume Air Flow "A" Circuit Range/Performance.
According to my SA apparently the MAF Sensor was dirty and showing readings of low air. Requested me to re-install original intake and they will do testing. Car stayed in shop for 1 day and everything looked normal with stock intake/MAF. SA recommended to leave the stock intake for 2 weeks and see if a CEL comes back on. If not it's something wrong with BMS Billet intake. Has anyone else experienced something like this before? |
07-31-2017, 02:34 PM | #141 | |
Rep 190,807
Mechanic said sensor is dirty and showing readings of low air and he concluded that problem might be from the intake? It sounds that the problem is from the sensor
ErkanTR16598.00 |
07-31-2017, 03:40 PM | #142 | |
Rep 369
So it's safe to say that the SA is incorrect. Last edited by Roki187; 07-31-2017 at 08:58 PM.. |
ErkanTR16598.00 |
07-31-2017, 05:12 PM | #143 | ||
64-bit
598
Rep 814
mike@x-ph.com24200.50 |
07-31-2017, 11:52 PM | #144 |
Rep 126
Revisiting the MPPSK question, did anyone do this? Do you need to remap the boost or is it suitable as a drop in?
2017 340i xDrive
MPPSK More to come |
08-01-2017, 12:18 PM | #145 |
Rep 190,807
I cant find the question you mentioned. This intake will not need any remap
08-01-2017, 06:33 PM | #146 |
Rep 1,454
I think BMS sells the cleaning/oil kit for $30.
http://www.burgertuning.com/B58_340i...ce_intake.html
