BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > A/C Compressor Bracket Torque Spec?
Studio RSR
      09-30-2023, 11:52 AM   #1
mcsweeto
Drives: 2015 M-Sport 435i xDrive (6MT)
When doing my accessory belt today, my dumb ass suddenly forgot how a torque wrench works and the threads where the idler pulley inserts went 'poof'. Now I get to take more stuff apart.
I have to replace the bracket where the A/C compressor mounts underneath the alternator. Anyone know the torque specs on those bolts?
Thanks.
MHD Stage 2+ / VRSF Catted DP / ARM F3X IC / BMS CP / AFE Pro Dry S
      09-30-2023, 03:18 PM   #2
mcsweeto
If anyone else manages to do this, you need the bracket that hangs off the alternator that the A/C compressor is mounted to.
https://www.realoem.com/bmw/enUS/sho...diagId=64_1918
I dropped the compressor to get access to the 5 13mm bolts that attach the bracket. I have a new one coming on Tuesday to finish this up.
