11-02-2023, 05:54 PM | #1 |
Rep 3,408
Engine air filter recommendation
I've got a 2014 F30 328i M-sport.
Any recommendations for a engine air filter? Also, there seems to be a different filter for the m-sport model. The fit is the same, but a different part number. What is the difference? Thanks |
11-02-2023, 08:53 PM | #2 |
Rep 5,457
Drives: F30
I've been running the MANN C24025 filter. Every 15k with a good inspection and knock out upside down, each oil change in between (to release larger particles). Also have a K&N high flow filter on the shelf that I've used in the past and would use again... but prefer the better filtration of the OEM style filters for every day driving over the slight increase in flow achieved with a less restrictive (performance) filter. Aiming for longevity mostly. Not aware of any TRUE differences with the M Sport part numbered OEM filters... airbox is the same regardless. I've seen some advertised with an extra snow filter, which seems unnecessary:
sygazelle11420.50 |
11-02-2023, 08:55 PM | #3 |
Rep 16,091
OEM. Ignore the hype about high flow filters. They do work with normally aspirated engines, but not with turbos. If BMW knew they could improve performance for such a small investment they'd do it.
11-07-2023, 05:46 PM | #4 |
Racecar Driver
1289
Rep 1,955
Drives: BMW M4
I just grab the most expensive one at FCP Euro and send it back once it's dirty. Same with Cabin Air Filter. #FreeReplacements4Life
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
11-11-2023, 11:43 AM | #5 |
Rep 1,582
I get WIX WA10005 Air Filter for engine protection. Mahle and Hengst are solid too.
sygazelle11420.50 |
11-11-2023, 03:33 PM | #7 |
Rep 16,091
His test shows that you can't get higher airflow without getting more particles too. That's not exactly shocking news. Many drag racers have no filter, but they don't care about engine life. A few minutes is all they need.
He totally overlooked the benefit of high flow filters with turbos. There's little to none. A turbo sucks in as much air as the engine can make use of. |
11-13-2023, 01:33 AM | #8 |
1899
Rep 2,091
OEM BMW / Mann / Hengst / Mahle: stick with OEM/OEM spec - that's all you need
sygazelle11420.50 |
