04-07-2024, 07:06 AM | #1 |
Rep 7
F31 Rear Battery Vent Issue!
Team - what is this vent flap for and why on earth would you cut out a section of it?!
Just bought this LCI F31, had to get the battery changed and found all of this - maybe a rodent issue? (In the UK so probably mice maybe?) But why would you gut out this section of the vent and do I need to replace it? |
04-07-2024, 07:18 AM | #2 |
Rep 1,825
that’s definitely a rat that made a home there. most cars have that vent in rear bumper, without it you risk blowing out your glass when you close the trunk from pressure build up.
04-07-2024, 09:37 AM | #3 |
Rep 7
Why would you cut out a section of the vent flap?? It looks like it has been cut with a Dremel or similar.
Do I need to replace the flap? The plastic cover on the outside has been cut off too!! Would it let water... and rats in then?! |
04-07-2024, 09:59 AM | #4 | |
Rep 1,825
are you sure it was done by a dremel or a human even? the bottom of that hole looks very chewed to me. rats can chew through almost anything.
04-09-2024, 07:46 AM | #10 |
Rep 467
When my wife bought her new Subaru in 2010 a mouse entered in that same vent within 3 months of ownership. My wife said her car smelled of death which lead to my investigation. A mouse made a home in the spare tire well and had a liter with a few babies still in the nest. I removed the nest but the smell lingered. I took out all the upholstery from the trunk and back seats searching for the source only to find a few of the baby mice died into a gelatinous mess in the lower back seat cushion foam. To say the least that new car smell was short lived. Took a year to flush out the smells of death and deodorizers. Because at the time we didn't have a garage and living in the sticks I put metal wire mesh over those entry points on both sides which arrested the issue.
BMWCCA Member #132862 |
04-13-2024, 02:52 PM | #12 | |
Rep 7,506
Good luck. Here’s a link to what an X3 owner did with the same problem: https://www.bimmerfest.com/threads/f...vents.1446642/
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-13-2024 at 03:00 PM.. |
