BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Best Suspension option to maintain stock/near stock ride height
      05-08-2021, 11:15 PM   #1
tpoddar
Drives: BMW 320i B48
Hey guys, I own a B48 320i LCI with standard suspension and I am looking for a sportier suspension setup for daily driving and rare use on track. I want to retain stock ride height or near stock (max 20mm drop). Any opinions on what I should go for? I have been choosing between-
1. Bilstein B6 with Stock Springs
2. M Sport Suspension (need spring part numbers. Unable to find?)
3. M Performance Suspension (need spring part numbers. Unable to find?)
Any other options that I can choose from? I would like to strike the right balance between comfort and sportiness but am willing to compromise on the comfort bit.
      05-08-2021, 11:56 PM   #2
alohasurftoad
Drives: 428i gran coupe
Koni Yellow Sport or SA(Red) dampers paired with Eibach Pro-Kit springs, 6-22
tpoddar25.00
      05-09-2021, 12:14 AM   #3
tpoddar
I just checked the eibach website, the drop on pro kit springs is 28mm up front and 25mm in the rear. Our country's notorious for tall speed bumps and I won't be able to handle such a large drop in ride height.
      05-09-2021, 02:08 AM   #4
alohasurftoad
M-performance suspension...
33-50-2-320-980 up to 1/2015
33-50-2-409-927 from 1/2015 and on
      05-09-2021, 08:08 AM   #5
anotheran
Sedan Driver
Drives: A nice car
Bilstein b14
tpoddar25.00
      05-09-2021, 09:56 AM   #6
cfm56d7b
Are KW coilovers available in India?
      05-09-2021, 10:14 AM   #7
tpoddar
Yep. We have access to all major brands.
      05-09-2021, 10:18 AM   #8
tpoddar
Originally Posted by anotheran View Post
Bilstein b14
Minimum drop is 30mm front and rear. It's too much for the road conditions that I see on the daily
      05-09-2021, 12:17 PM   #9
cfm56d7b
KW Street Comfort coilovers are worth exploring then. These coilovers can be set at near OEM height.
tpoddar25.00
      05-09-2021, 01:41 PM   #10
anotheran
Sedan Driver
Drives: A nice car
Can do bilstein b12 then
tpoddar25.00
      05-10-2021, 02:28 AM   #11
tpoddar
What would be the netter option amongst the two considering that the bilstein b12s will cost about 1/2 of that of KWs?
      05-10-2021, 10:19 AM   #12
mlev
mlev's Avatar
Drives: 2014 335i M-Sport
The B12 is going to be stiffer, if you prefer that.
I would also consider Air Suspension if your speedbumps are that bad.
tpoddar25.00
      05-11-2021, 03:08 AM   #13
tpoddar
Air Suspension would be high maintenance and also extremely costly. I will research more about the B12s though.
      05-11-2021, 10:16 PM   #14
cu260r6
Drives: 428i
I have F82/M4 springs and Koni yellow shocks and love the setup. It came out about .3in lower than stock, negligible.
      05-13-2021, 09:55 AM   #15
Jvac
Drives: 2015 335i rwd
The ohlins road and track kit can be adjusted to stock ride height if I remember correctly
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler, Mppk lower airbox
      05-13-2021, 07:34 PM   #16
anotheran
Sedan Driver
Drives: A nice car
That would be the best choice. But most ppl on here these days too cheap to go that route or can't due to xdrive
      05-14-2021, 12:43 AM   #17
tpoddar
Sadly, there isn't an official dealer for Ohlins in India :/
      05-14-2021, 01:44 AM   #18
alohasurftoad
stock springs or M-Sport springs paired with Koni SA or STR.T
tpoddar25.00
      05-14-2021, 05:21 AM   #19
tpoddar
Koni isn't available until the first week of July due to production slowdowns. I'm either going to wait or just go with M Performance/M sport suspension.
      05-17-2021, 10:59 PM   #20
F30_Sushi
Drives: 2014 BMW 328i
2014 BMW 328i  [0.00]
+1 on M Performance Suspension.
Just switched from M Sport Suspension and can say it is a night and day improvement. Completely eliminated the overdampened feel of the M Sport suspension over rough bumps and floaty feel on turns. The M Performance suspension is firmer in the sense I have a better connection with the road and chasis feel but handles bumps well without feeling any jolt. The description "on rails" feels quite accurate while managing to be more comfortable in my opinion than the M Sport suspension. This could also be because my old struts were completely shot but figured it may be worth chiming in. Cheers.
      05-18-2021, 11:21 AM   #21
E60F30
Singapore
29
Drives: 2012 328i Sport Line
I'm on bilstein b6 with stock springs.
Substantially firmer than stock but there is still a touch more body roll than I would like on high speed corners.
2012 Glacier Silver F30 328i
18 x 8.5 Square Apex SM-10 | 245/40/18 Michelin PS4 | F8x LCA | Red M Performance Brakes | M Performance Conversion | F80 Steering Wheel | VRSF 5" HD FMIC | Full FTP Piping / Oil Catch Can
      05-31-2021, 11:10 PM   #22
J26
Drives: E92
Bilsteins.
