01-26-2022, 02:28 PM | #1 |
Rep 15
MMI vs NBT EVO upgrade
Hello,
I have got a 2014 F33 with NAV pro, large screen, I believe the unit version is NBT ID4. I play music from an iPhobe over BT, it works just fine, supports playlist, song cover, etc However, I am considering upgrading, I believe I have 4 options: 1. Upgrade to NBT EVO ID5/6 hardware unit 2. Code ID5/ID6 with the existing hardware 3. Install an aftermarket MMI box 4. Install and aftermarket LCD headunit I think option 4 is pretty much an customized Android tablet. What I am thinking to gain is the advantage of using Google maps to navigate or/and use Siri to tell where I want to navigate. Does the LCD version offer much in terms of quality of the display compared to the stock one? Would I have any benefit from the LCD version compared to a MMI box? Apart from touchscreen which I dot think Ill use much. Is the OEM unit the best choice in terms of functionality, compatibility and error free operation? Will it be difficult to install the MMI box or LCD unit, I have read somewhere its a little more tricky for a cabrio? All comments are greatly appreciated Thanks. Cio |
01-26-2022, 03:16 PM | #2 |
Rep 706
Options 2 is not possible on your HW. Only NBT EVO unit released after 7/2015 build date is eligible to upgrade to idrive 6
Options 1 is the most expensive one. Options 3 is the least expensive one. Options 4 is about $500. So budget wise 1 >> 4 > 3 |
01-26-2022, 04:09 PM | #3 |
Member
78
Rep 206
Option #3 is the best! Best bang for the buck and once installed, nobody will know if it's OEM CarPlay or MMI box. I did this on my 2014 328xi with NBT ID4.
So far so good. Btw, I got the RoadTop MMI unit.
2014 328i xdrive | Black Dakota Leather w/ DIY Blue Stitching | EB Interior trim | M Sport | Lighting | Premium | Driver Assistance | Cold Weather | LCI Tail Lights | M Performance Brakes (Blue) | 340i Muffler
01-26-2022, 09:38 PM | #4 |
Rep 1,459
Drives: 2023 G81 M3 Touring
I’m on my second option 3 (first was an MMI in my E90, second I just installed in my
F82), and thrilled with the result. If your goal is voice assistant and google maps, this is easily the best option. With an android screen you will need to have it connected to the internet somehow, versus CP/AA which will fire up automatically in moments and have all your smartphone apps and connectivity available. The other benefit is retaining the factory display, which to me looks better than the aftermarket screens (though they have improved). Audio quality is excellent, controls are very responsive, and it uses the factory microphones and internal AUX (no extra cables). Can even control CarPlay using the wheel on the right side of the wheel! |
tajayq9.00 |
01-26-2022, 09:54 PM | #5 |
Rep 1,459
As for difficulty, depends on your confidence. It’s a pretty easy step by step, with lots of excellent, helpful videos online, but you do have to pull the dash and glovebox apart to make it happen.
01-27-2022, 09:57 AM | #6 |
Rep 15
For my F30 2016, I first went with option 3, the MMI interface. I didnt like it much. To buggy, and it didnt feel 'OEM'.
So, after some consideration, I sold the MMI, and bought an ID6 headunit. Unfortunately, I also needed a new screen, so I spend about 1000 euros. But, totally worth it! |
01-27-2022, 10:02 AM | #7 | |
Rep 1,502
Drives: F36 435xd
Im considering the same upgrade. You need headunit, screen, cable to screen and WiFI antenna right? That's it?
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
01-27-2022, 10:10 AM | #8 |
Rep 15
01-27-2022, 10:12 AM | #9 | |
Rep 1,502
Drives: F36 435xd
I don't think there are any benefits changing that one or?
Brgds
01-27-2022, 12:11 PM | #10 | |
Rep 706
If you are planning to use the car screen, then you need to buy a new cable since the car screen is apix1, the new cable has a voltage regulator since apix 1 and apix2 screen have different voltage. So a bare minimum is headunit Optional is screen and controller |
anielsen71558.50 |
02-02-2022, 12:45 PM | #11 | |
Rep 765
02-03-2022, 06:26 AM | #12 |
Rep 56
02-03-2022, 07:07 AM | #13 |
Rep 375
Doesn't look like a 20" screen - looks smaller than my iPads 11" screen!
02-04-2022, 02:15 AM | #14 |
Rep 38
Picking up a 2016 F30 next week. It only has the 6.5” screen and business navigation.
I’m considering upgrading to the NBTEvo ID6 (8.8” screen, head unit and controller) but was hoping someone might be able to help me out with the part no.s please |
02-23-2022, 12:28 AM | #15 |
Rep 6
If you go with option 1 and upgrade to NBT EVO ID6 hardware unit, is there still a way to potentially get Andriod Auto or do you have to choose between NBT update or MMI box?
06-07-2022, 10:41 PM | #17 |
Rep 1
trouble w/ sos system
I went with option 3 and installed a 3rd party MMI. All seems to be working but it triggered an SOS system malfunction. Has this happened to anyone else and does anyone know how to get rid of it?
06-08-2022, 03:17 AM | #18 |
Newbie
Rep 82
I'm not sure why people pull the glovebox when installing MMI - there is ample space in the shelf below the steering column is there not ?(certainly in my UK F33). I knew of this as the first time I got my MMI box installed that's where the fitter installed it. When I returned the MMI and got a newer one I simply repeated with the antenna positioned in the centre space befind/above HU.
There is an hole/space to route the cables and antenna and with 2 screws only means getting to the MMI box is a breeze Ive done options 3 then 2 and an happy with the MMI for Android auto & Spotify on MMI and fresher/modern interface with integrated carplay for when my girlfriend uses the car on the ID6 lite upgrade Added bonus is that aftremarket reverse camera connected to MMI box works in both cases - just simply put into reverse. Last edited by Tony_B; 06-09-2022 at 04:12 AM.. |
