BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Caliper Rebuild Kit
      01-06-2018, 12:11 PM   #1
sickF30
Drives: F30 335i
Caliper Rebuild Kit
Greetings!
I'm looking for a caliper rebuild kit for the OEM Brembos but all I can find are the boots for the piston (34216857153 and 34116850935) and not the inner seal. I don't suspect I really need to replace those parts (I'm powder coating my calipers) but I'd rather have them in the event I find a torn boot/seal or tear one while removing them.
Or, if I could find out the size of the pistons, I could find a matching kit available for all the Subaru's and Evo's.
Anyone run into this?
      01-07-2018, 12:35 PM   #2
Orion4
Suggest you contact Zeckhausen: https://www.zeckhausen.com/catalog/i...zeck-plain.png
800-222-8893
Monday - Friday 10AM - 5PM
They appear to carry a wide range of rebuild kit of Brembos: https://www.zeckhausen.com/catalog/i...ssvl7man859e30
      01-07-2018, 03:25 PM   #3
sickF30
Drives: F30 335i
yeah, i found their site while looking around yesterday. thanks!
      01-08-2018, 01:06 PM   #4
Orion4
Give them the year, model and VIN and they should be able to provide the kit.
      01-08-2018, 01:09 PM   #5
Orion4
What year is your 335i? Needing a rebuild kit for an F30 is a little unusual unless you"re seeing some leakage or are tracking or very high mileage with some hard braking.
      01-09-2018, 08:34 AM   #6
DrifterX
DrifterX's Avatar
Drives: 2016 340i M Sport 6MT+RWD
Yeah, I'm wondering the same; why do you need to rebuild so soon?
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch
      01-09-2018, 09:58 AM   #7
Whistlefist
Drives: 2014 335i Msport
He is powder coating the calipers, says in the first post. Which means they will be fully disassembled. Since they will be apart anyways, what better time to replace anything that may be worn, or anything that may end up damaged due to disassembly.
sickF3053.50
      01-13-2018, 10:05 PM   #8
sickF30
Drives: F30 335i
Exactly what Whistlefist said.
      01-14-2018, 09:38 PM   #9
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Centric 143.42041 will get you everything you need for the front and rear 3-Series M-Performance brakes on one side.
Comes with boots and seals for one side for the front 4-piston and rear 2-piston. You'll need two of them. Should run around $20 each, so $40 altogether.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
      01-20-2018, 10:17 PM   #10
sickF30
Drives: F30 335i
That's awesome, thank you!
I was hoping to stick with OEM but having run Centric rotors on a previous car with no issues, I'll pick these up.
      05-10-2018, 09:12 AM   #11
BlueM3Wagon
BlueM3Wagon's Avatar
856
Drives: 2012 M3 e91
Ordered these for the Brembo F30 340 calipers and does not fit FYI for anyone looking at rebuild kits
2012 E91m3 custom build
Follow on Instagram: BlueM3wagon
      05-14-2018, 03:38 PM   #12
sickF30
Drives: F30 335i
damn, that sucks.
i ended up not needing to replace mine, so i have these sitting in a drawer.
      05-18-2018, 08:50 AM   #13
r0b3r
Drives: Bmw F
oh damn, I asked for references in BMW this week 34216857153 and 34116850935 and I thought that those inner rings would also come that I also need (for the same reason that you) clamps have been sandblasted and painted.
So why is BMW so useless to sell its half replacements? How can we get only those stamps? because if it is as I decide I will receive only the outer stamps and not the internal ones ..... and they have not been cheap precisely ... 140 € only exterior detents then.
Do you have pictures of your painted clothespins? How do I paint? the M logo got it in an original way? I am looking for the original logo as it comes from the factory in the clips with the medium gray and I see it difficult to get, on ebay there are some similar but not the same.
      05-18-2018, 11:26 AM   #14
r0b3r
Drives: Bmw F
reference of external rubbers BREMBO original of these clamps is 98.5032.40, in fact BMW references come without the internal torica, I need those toricas and do not know how to get original brembo
      07-10-2019, 06:02 PM   #15
NicksN20F30
Drives: 2013 BMW 328i xDrive
I'm also trying to rebuild some 340 f30 brake calipers as the dust boots are torn. The pressure seals are fine but the dust boot(s) needs replacing. I removed one of the pistons and measured it and it is in fact 40mm.
Stoptech sells dust boots that fit obviously Stoptech caliper pistons and most late model brembos. Does anyone think this will work or should I not waste my money? I'm kind of in need of a new dust boot that will fit as I won't be able to get these brakes on the car obviously.
Any help is greatly appreciated.
Bootmod3 stg. 2
FBO
      07-10-2019, 06:17 PM   #16
NicksN20F30
So actually doing some more research and looking at the actual brembo part number on the dust boot I found that a 40mm piston dust boot PN is BRE20.4872.46 (see picture)
Then typing that into google I found a company called HRP that sells race parts. They have a selection of brembo dust boots ranging in various sizes.
This this the link to a 40mm dust boot. Sold per boot @ $7.65 a piece. I'm ordering these as they should be the same exact part on the caliper currently.
https://www.hrpworld.com/bre-2048724...dust-boot.html
I will post back here again with whether or not these work. I'm hoping they will since the part numbers match. Hope this helps.
Bootmod3 stg. 2
FBO
      07-11-2019, 01:44 PM   #17
rphz
Drives: 2014 F32 435xi
I can confirm that those dust boots with part number 20.4872.46 will fit the 4-piston Brembos calipers (mine are the reds and replaced the factory silvers) as I recently had to replace all of my seals due to overheated brakes.
      03-31-2020, 07:16 AM   #18
Polo08816
Drives: 2014 335i M Sport
Originally Posted by sickF30 View Post
damn, that sucks.
Anyone find an alternate kit?
      05-29-2020, 12:15 PM   #19
OSUClevage
Drives: 16' 328i xdrive f31 wagon
These caliper rebuild kits fit the F30 M-Performance calipers (370mm front / 345mm rear).
Manufacture: Centric
Front: 143.34039
Rear: 143.34040
https://www.zeckhausen.com/catalog/i...5096_5774_6220
      01-16-2022, 08:51 PM   #20
boyerizm
boyerizm's Avatar
Drives: BMW 328i xDrive M-Sport
Hey wondering if this kit would work for the OEM 335i / 340i Brembos ?
https://www.zeckhausen.com/catalog/p...oducts_id=6539
Or this https://www.ebay.com/itm/BMW-4-Serie...-127635-2958-0
