03-17-2019, 10:01 AM | #1299 |
Rep 161
Drives: slow
245/18/40 18x9.5 et25 square @dbuiltco on IG |
03-17-2019, 11:44 AM | #1300 |
Rep 1,288
Drives: 2014 435iX, FBO
That must handle like a champ.... how does it feel?
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
03-17-2019, 01:00 PM | #1301 |
Rep 463
03-17-2019, 02:43 PM | #1302 |
Rep 161
Drives: slow
Still need to get the alignment dialed in. Put suspension and sway bars on last night. I went bc br coils which come with camber plates, yes. Just have it at zero right now. Some rubbing with just me in the car (small frame 140 pounds) and with others it really isn't too happy. Fronts more than the rear. If camber still upsets it I might have to pull out the roller.
They're Nankang as-25.. $60 a wheel. Got them as cheap off season tires. I'm in the tri state area and I have to say... I had full confidence in my car and felt a great amount of grip in bad weather conditions. Being Rwd that's a huge plus. Before suspension I felt like the turn in had improved drastically having more rubber and surface area in the front being 9.5 vs whatever the OEM 397s were. Haven't had a chance to test grip in a spirited manner on decent roads yet with the suspension. Note, It's set to the stiffest possible. All in all I wanted a track-esqueue look with aggressive stance. I think with the aggressive wheel setup, a good fender roll and coilovers it is definitely achievable. |
03-17-2019, 03:22 PM | #1303 | |
Rep 1,288
I would also recommend getting the Michelin 4S tires. Your car with your suspension, camber and coils will be friggin incredible. it SHOULD feel and grip and turn great. I wish I had your setup. let us know how you make out, maybe make your own thread.
03-17-2019, 04:41 PM | #1304 | |
Rep 161
Drives: slow
DaFish156.50 |
03-19-2019, 05:14 AM | #1305 |
KendrickOak
359
Rep 201
You're right. It will not fit. Sorry about the miss info. You need around +35 in rear to fit. The front will be fine with 225/35/
03-21-2019, 04:30 AM | #1306 |
Rep 966
Back with a couple more
kern4174446.50 alexng72147.00 RobbDubbs99.50 weavingtraffic214.00 HondaGoneRogue432.50 stickman130933.00 hybris204.50 |
03-25-2019, 12:04 AM | #1309 |
They like my Swag...
433
Rep 3,762
Drives: 15 GSM 435i GC
This thread is nothing but dope cars and invaluable knowledge. I owe a lot of you a drink for sharing your setups in detail. I hope to share some good pics soon.
2015 435i Gran Coupe - Current 2008 AW 135i - Sold |
03-25-2019, 03:47 AM | #1310 |
Rep 966
HondaGoneRogue432.50 |
03-25-2019, 12:10 PM | #1311 |
Cheapskate
4447
Rep 4,993
Alright, time to fix the rubbing once and for all. My wife and son are riding with me more and more now so I figure I'll bite the bullet.
Turning on flat ground is fine. The only time i rub is with minimal steering input with undulations in the road. It's like the first 10* of input pushes the tire into the front bumper. With more steering input the car raises itself up (thanks to caster) so no rubbing there. For example this weekend I'm driving through an uneven parking lot, and it rubs a. on initial turn in and b. the last moment before the wheel is fully straight. Driving straight and at full lock it was fine. I basically found myself stopping, turning the wheel, then moving again to eliminate the rubbing. I saw on E90s they shave the material joining the bumper and fender. Does it work the same on our cars? I'm considering trying it but would prefer not to chop into things if it's not the same. I also thing this would help me roll my fenders better since it can't be rolled flat near the bumper tab. https://www.e90post.com/forums/showthread.php?t=1088888 https://www.e90post.com/forums/showthread.php?t=1118243 I've obviously considered camber, but not willing to deal with the rattling noise that came with camber plates that I've had on previous cars (again just me at the time, now with the family I'd like to avoid it). The camber adjustable bushings seem like a nice option if all you care about is camber angle, but for clearance I really need to bring the top of the tire in instead of pushing the bottom of the tire out. So I don't think it'll fix my fender rubbing issues. BUT, I read some that adjusting caster can affect camber. So considering the caster bushings if that may work. |
03-25-2019, 07:01 PM | #1312 |
Rep 969
03-26-2019, 06:46 PM | #1313 |
Rep 58
Drives: 2013 F30 335i Xdrive
hey guys got a question if you guys can help me. currently got a set of weds kranze borphes in19x8.5 et 40 and 19x9.5 et41 3 piece wheels. i want to increase the widht all around by a inch. do you think i can make it work? currently sitting on H&R sport springs. 2013 335 xdrive . tires im running 225/40r19 and 255/35r19. thank you
03-27-2019, 06:03 PM | #1315 |
Cheapskate
4447
Rep 4,993
F30_SixSpeed1170.50 wdeerfield2746.50 Bt130915.00 KendrickOak358.50 HondaGoneRogue432.50 stickman130933.00 Alpine-F80200.50 |
03-28-2019, 01:29 PM | #1316 |
433
Rep 3,762
BBS LM DBK/DBK
19x9 et27 and 19x10 et37 General G-Max RS 245/35/19 and 265/35/19 Airlift Performance 3P
03-29-2019, 09:48 AM | #1317 |
Cheapskate
4447
Rep 4,993
Is that aired out? What are you hung up on, just a lot of tire?
03-29-2019, 10:06 AM | #1318 | |
433
Rep 3,762
It makes for a really good track stance at driving height, so I'm not disspointed.
kern4174446.50 |
03-29-2019, 11:31 AM | #1319 |
Cheapskate
4447
Rep 4,993
Yeah I like the meaty look too
03-29-2019, 12:18 PM | #1320 |
433
Rep 3,762
The front will def go lower if I roll the fenders or get rid of that tab where the bumper meets the fender, but I'm not sure if I want to do all that yet.
Tags |
aggressive, f30, low, slammed, stance |
