05-31-2018, 01:20 PM | #26 | |
Rep 357
Cheaper than MCCB and dust corrosion free. It will improve stopping distance vs M Perf kit, and save 15lbs per front rotor = 30 front =150lbs sprung weight reduction and corresponding improvement in handling. Of course I would not put this on a 320i. But if doing so, 370mmx30 strand woven CCB is the way to go. If wishing to find out more, PM or check the other post. |
08-21-2018, 07:29 AM | #27 |
Rep 864
Sooo read through the thread and still not certain.
So we know the calipers bolt up. But do the rotors 380mmm front and 370mm rear Do you also need the f80 wheel hubs? |
08-21-2018, 12:01 PM | #29 |
Rep 10,256
Carbon ceramic brakes for street use are not particularly helpful. It's a profit generator for BMW, both at the point of sale and later during service visits. There is nothing wrong with a profit motive of course.
Better investment would be a BBK with 6 pistons - front and 4 pistons - rear, either from Brembo or AP Racing. |
07-13-2020, 01:40 PM | #30 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
I found someone selling a set of front and rear F80 M3 calipers for $600. Will they fit onto my F30 335i? My car has the M sport package but with the silver calipers.
07-13-2020, 01:44 PM | #31 |
Car Hypochondriac
335
Rep 901
Yep! This is what I did, and that's a great deal assuming the paint and the caliper seals are in good condition. They bolt straight on, you just need the proper sized rotors (370 front, 345 rear).
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
07-13-2020, 03:28 PM | #32 |
Moto Lover
187
Rep 591
07-13-2020, 04:11 PM | #33 |
Car Hypochondriac
335
Rep 901
07-13-2020, 08:32 PM | #34 |
Rep 1,934
It's the same mperformance f3x setup. F8x just get them stock with larger rotors due to the f8x hub allowing the caliper to mount 5m farther away from the axle.
07-14-2020, 10:16 AM | #35 | |
Rep 3,016
Drives: 2019 M2 Competition
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
08-03-2020, 12:45 PM | #36 |
Moto Lover
187
Rep 591
So correct me if I'm wrong.
Non m-sport and m-sport use same front calipers but different real calipers. Non m-sport are silver while the m-sport are painted blue? Both setup use the smaller rotors? M performance & M model cars use the same calipers and same rotors? But our F30 cars can't fit the rotors? A little confused. |
08-03-2020, 01:10 PM | #37 |
Rep 3,016
Its a better option to install the M5 front calipers and M2 400mm rotors. You can get the calipers off a wrecked car cheaper then buy the $250 frame/adaptor.
Lestywesty7.50 |
08-03-2020, 01:13 PM | #38 | |
Rep 3,016
Turner motorsports has a GREAT writeup on this btw, in far greater detail than I will go into here. (but) In general the "grey" front rotors are 4 pot and essentially the same as the colored (usually blue) m performance/sport brakes, which are ALSO identical to the F8X front default brakes. That said, they all have different rotor sizes. The grey have the smallest rotor, the m performance has larger and the F8X have slightly larger still (though not compatible with the F3X wheel hubs). The rears CAN be significantly different, but also in general, the grey are single pot calipers and a smaller rotor. The "blue" (or red or orange) brakes are 2 pot and a larger caliper. Its SUPER easy to get the default (non carbon ceramic) calipers off an F8X (wrecking yards are your friend) and then rehab the calipers and install the correct sized rotors on your F3X. I have a full DIY of this posted up btw. Again in general..
08-03-2020, 01:14 PM | #39 | |
Rep 1,934
There are 2 versions of the front 4piston brembo. Grey. They come on F3x N55 and B58 stock, msport or not. Blue. This color is also labeled msport, but uses a 340mm front rotor only on the 4cyl F3x. Blue for N55/B58 uses the same 370mm rotor as Mperformance brake packages for the F3x. The same 4piston brembo also shows up in 370mm for F3x, or 380mm for F8x. This is possible because of different uprights on those vehicles. The calipers themselves can mount to either car without issues or mods. The stamp on the backside of the caliper will say 370/380. The reason the exact same CALIPER design can be used on 340 or 370/380mm rotors is due to the one piece design. The mounting "ears" are part of the caliper. They are not removable. On most cars this bracket is an independent part on the caliper that can be swapped. This is not the case for BMW. All of these 4piston Brembos, regardless of color (grey, blue, red, orange, yellow) use the exact same brake pad in size.
OSUClevage51.00 Alpine-F80200.50 |
08-03-2020, 01:47 PM | #40 | |||
Moto Lover
187
Rep 591
https://www.turnermotorsport.com/t-b...ke-Differences With all this being said, the M2/M235i should be the same calipers correct? I found a set of calipers that say "2015-2020 BMW M2 M3 M4 M235i" calipers but don't mention any part #s. |
08-03-2020, 02:24 PM | #41 | ||||
Rep 3,016
08-03-2020, 04:49 PM | #42 |
Moto Lover
187
Rep 591
Ok, I will see if this guy can get part # from the seller. Here is what I am talking about: https://www.ebay.com/itm/2015-2020-B...0AAOSwhZ5fJNtc
08-03-2020, 09:23 PM | #43 |
Rep 1,058
^i hope whoever bought that set you linked realized that it only supports 340mm front rotors. Thus isn't M3/M4 calipers, but the 335i/340i M Sport front calipers. The listing is wrong.
08-03-2020, 09:28 PM | #44 |
Rep 1,934
The m235i comes with these so just wrong on the M3/m4 part.
