06-15-2017, 04:40 PM | #45 | |
Rep 665
A user on the uk site with more time than me made this table |
pimp4cheddar520.50 |
06-15-2017, 04:49 PM | #46 |
Rep 5,995
He made this table or it came from BMW? Other users have a contrary view. Wouldn't make sense to have a sport + mode if you can just turn off traction control in sport to have the same effect.
06-15-2017, 04:58 PM | #47 | |
Rep 665
Anyway you're letting the side down a bit here mate Traction control and throttle mapping two different things |
06-15-2017, 05:06 PM | #48 |
Rep 2,557
Trying to piece together the story it would seem sport+ takes the throttle and shift settings of sport and relaxes the traction and stability control to allow for more yaw and wheel slip with some nannying retained not full off.
06-15-2017, 05:09 PM | #49 |
Rep 5,995
You can do the same thing with sport and turning "off" traction control. It's still on partway or you can turn it off completely.
06-15-2017, 05:10 PM | #50 |
Rep 5,995
Yes but unfortunately they're linked. If you want the sportiest throttle response you get less traction control. I don't see why this has to be the case as like you said they're two separate systems.
06-15-2017, 05:23 PM | #51 | |
Rep 665
I don't agree that throttle mapping and traction control are linked. Neither does the table; it shows you can have 'sensitive' mapping in both sport (with traction control) or sport+ (with reduced traction control, i.e. DTC on). |
06-15-2017, 05:31 PM | #52 | |
Rep 5,995
06-15-2017, 05:31 PM | #53 |
Rep 2,557
traction control (which manages wheel slip from overspin) and stability control which will selectively brake and slow the vehicle to return the vehicle to its intended line are two different systems. turning one off only removes the paremeters from that system vs relaxing them overall
06-15-2017, 05:38 PM | #54 | |
Rep 665
Try it by pressing the 'Traction' button in your car, it will move you into Comfort mode. I hate to say it, but the table tells you this too |
Poon Stick42.50 |
06-15-2017, 05:41 PM | #55 |
Rep 5,995
I've done it before in my car, putting it in sport and then DTC. I don't care what the table says.
06-15-2017, 05:43 PM | #56 | |
Rep 665
06-15-2017, 05:54 PM | #59 |
Rep 5,995
06-15-2017, 07:17 PM | #60 | |
Rep 584
It's possible that your car is a special snowflake that behaves differently than all the other F30s on the board. But it's very unlikely, and frankly you have blown most of your credibility on the issue. |
06-15-2017, 08:04 PM | #61 |
Rep 2,557
Back on topic question
for MPPSK, not the std exhaust flap behavior: If you put the car in sport immediately after cold or warm start, do the valves just open as soon as the car is ready or do you have to cycle back to comfort then sport again and again? |
06-15-2017, 08:06 PM | #62 | |
Rep 5,995
06-15-2017, 08:15 PM | #63 |
Rep 1,170
Yes, the valves will open in about two minutes although sometimes, maybe 5% of the time it seems to take some throttle input to make it happen.
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
06-15-2017, 09:55 PM | #64 |
Rep 689
06-15-2017, 10:10 PM | #65 |
Rep 233
Back on topic, for those people who have driven both, would you say the sound of the 340i with MPPSK is superior to the M3? If yes, why is that?
06-15-2017, 10:28 PM | #66 |
Rep 1,011
I've done that comparison a few times. and the 340 with MPPSK is definitely better sounding by a large margin in terms of tone, growl, throaty-ness, the m3 is higher pitched and sounds a bit tinny at times no deep sustained growl. the m3 sounds apologetic and the 340 just let's you know how it is and says goodbye.
