10-02-2018, 03:41 PM | #67 |
Rep 640
Drives: 2008 M3 (E93)
Anyone have issues with intake temperatures running the BMS intake?. I bought it ahead of time but haven't installed it yet due to this concern. Any feedback/experience would be great to hear, thanks.
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
10-03-2018, 08:08 PM | #68 | |
Rep 190,805
Heat from an open intake is not a concern on turbo cars, thats why you have an intercooler.
10-04-2018, 03:25 PM | #69 | |
Rep 888
This is akin to saying outside ambient temps have no effect on your car...they clearly do. Your intercooler only has so much thermal capacity and if you raise your IAT's by 20-30° you still see this on the manifold side effectively altering your timing and/or fueling. IAT temps have a significant impact on thermal efficiency of these cars and it's been proven the A2W intercooler on B58's isn't near as efficient as say an M3. *I own a BMS intake* and I generally don't see higher IAT's, however in stop and go driving in summer time I definitely do and you can feel the power drop off. Intercoolers don't make magic happen...they control intake temperatures only to a certain extent. Efficient closed intake systems are superior in generally every way...there is reason every level of motorsports racing doesn't slap on a cone filter and call it day. |
10-04-2018, 03:27 PM | #70 | |
Rep 190,805
When/If new data show otherwise, i will gladly change my mind.
10-04-2018, 03:44 PM | #71 | |
Rep 888
I assume the comparison data you speak of is with a large dyno fan pointing right at the engine bay...this doesn't even come close to replicating the dynamic loading the engine sees during various drive cycles. There's a significant difference between understanding these facts and misinterpreting skewed results... From a simplistic point of view let me ask you this, if additional heat was not an issue on intercooled cars why would nearly every single MFG work to design elaborate shielding to help mitigate the additional temperatures open air intakes are subject to? Furthermore, to support your theory why would every level of Motorsports racing not just slap a cone filter on their cars then? Last but not least here's a relatively simple article explaining the above in more detail: http://www.zerotohundred.com/2017/ho...ith-high-iats/ |
10-04-2018, 03:46 PM | #72 | |
Rep 190,805
Anyone can do the same comparison with the B58 and post the results. You are posting theories without any real life proof like actual temp comparison.
10-04-2018, 04:40 PM | #73 |
Rep 1,457
This goes way back to the N54 dual intake cone days testing with the filters and the stock closed air box: https://www.n54tech.com/forums/showp...70&postcount=1
10-04-2018, 07:31 PM | #74 | |
Rep 888
- Lack of any level of temperature instrumentation before or aft the intake such as thermocouples to measure the temperature delta? - Did they measure the mass flow to check for any differences in measured CFM? - Also, no mention of logging AFR to see any effects of said intake? - What conditions did they test in? No mention of ambient temperatures or humidity. Testing in various atmospheric conditions will produce DRASTICALLY different results...obviously a known fact. - Were these results averaged out over a number of runs for a consistency in observed deltas? - Insert missing variable here that would impact results... On the flip side you say my posts are based on theory, unfortunately this is proven FACT...it's called the Law of Conservation of Energy, or better known as The First Law of Thermodynamics. Intercoolers (heat exchangers) don't magically make heat disappear as you infer, they have a level of thermal efficiency that dictate the maximum level of heat capacitance that's available. In layman terms: more heat in = more heat out which equates to less performance. Just to reiterate and be clear I'm not arguing and saying the BMS intake magically turns these engines into a hairdryer...I'm saying your generalized comment "Heat from an open intake is not a concern on turbo cars, thats why you have an intercooler" is absolutely a false blanket statement. But I digress, none of the above matters for the average person deciding on open vs closed intakes that want a little extra noise. For some people that actually understand the engineering principals that define efficiently designed components...it matters. My point is blanket claims that are slightly misinformed I find a bit misleading...that's all. I'll leave it at that |
10-04-2018, 08:05 PM | #75 | |
Rep 190,805
By the way, just because we do not agree does not make me someone that does not understand engineering principals. I have 2 engineering degrees
10-04-2018, 08:47 PM | #76 |
Rep 1,457
From my view... closed intake or open, the air being drawn in is still hitting the compressor side of the turbo so that’s obviously heating up prior to the water-air intercooler. Open filters does have the advantage of drawing in more air.
04-12-2019, 01:19 AM | #77 | |
Rep 1,503
Hate to bump an old thread but this is spot on. The air in the turbo is already hot as hell in comparison to the heat in the engine bay. Turbo doesn't mind the "hot" air as much as people think, it just wants more of it.
FBO M235i r
F80 M3 |
04-17-2019, 12:50 AM | #78 |
Rep 190,805
+1
04-17-2019, 10:16 AM | #81 |
Rep 1,457
Been running meth for years.... don't fear it
2024 X3 M40i
2014 BMW M5 |
04-18-2019, 02:19 PM | #84 | |
Rep 1,457
2024 X3 M40i
2014 BMW M5 |
04-19-2019, 01:01 PM | #86 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
I had the BMS and was really disappointed with the sound and quality of the product. The AP fits perfectly fine and i have no issues with it. The sound is definitely louder which is a plus for me.
B58557.50 FirstBMWLA186.50 |
05-08-2019, 11:43 PM | #87 |
Rep 190,805
Looks good
ErkanTR16598.00 |
