01-19-2014, 11:17 AM | #265 | |
Rep 14
Drives: F30 320d M Sport
01-19-2014, 11:31 AM | #266 |
Rep 1,976
Drives: 2020 G20 320i M Sport
NBT gets all of the vehicle data and time settings from the KOMBI (Instrument Cluster). Coming from HU_ENTRY, I think you have the Basic Instrument cluster which doesn't have the optical output that goes with NBT/CIC. You might need to retrofit a 6WA cluster in order to get all that to work. What's the model year of your car and what's the country spec?
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
01-19-2014, 11:43 AM | #267 | |
Rep 458
01-19-2014, 11:47 AM | #268 |
Rep 458
I thought even the HU_Entry without 6WA would still have the MOST connector to link the sound output to the amplifier.
The MOST cable goes into circular pins 1 & 2 shown in the top left of the main wiring harness shown below: |
01-19-2014, 12:09 PM | #270 | |
Rep 14
Basic instrument cluster Basic idrive unit Sport Auto Trans with Paddles I am sure there is no optical cable. I should have stick with my tom tom Nav ))) Last edited by nima; 01-19-2014 at 02:14 PM.. Reason: forgotten put more information |
01-19-2014, 12:25 PM | #271 |
Rep 1,976
In Canada, if you have a 2012 or 2013 model with any of the four Lines; Sport, Luxury, Modern or M Sport, you get the 6WA cluster even if you didn't order the On Board Navigation system.
After examining all these model years and builds, I think by far the easiest vehicle to adopt NBT is a Canadian 2012 - 2013 F30 with any of the four lines and no navigation. With that setup, you will have the 6WA cluster already, the Bluetooth Mic, Bluetooth Arial, AUX and USB are all in the front since there is no combox. Just rotate the HSD plug underneath the plate of the armrest 180 degrees, shave the locking pins off the white USB cable and you're all set. For navigation, you can just use the aftermarket GPS Arial antenna like 1lyfe and you will have a 100% fully functional NBT system. From what I know, the CIC controller will be plug and play without issue. With the 2014 models in North America, you will need to run the Mic, Bluetooth Arial, AUX and USB from the combox all back to the front just like going from CIC to NBT and you will need a 6WA cluster which seems to be the most work compared to all other builds not to mention the issue of getting the iDrive Controller to work.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 01-19-2014 at 12:34 PM.. |
01-19-2014, 12:28 PM | #272 |
Rep 1,976
NBT can still function without the optical cable. It's just going to be a bit annoying because when an error pops up, it's not going to show up on your iDrive screen and the chime will no longer sound.
01-19-2014, 12:35 PM | #273 |
Rep 14
If I put new 6WA and wire the optical from cluster to NBT, does it work PnP or need this difficult coding !
01-19-2014, 01:08 PM | #274 |
Rep 458
UK spec cars are no harder than Candian ones unless you didn't spec 6WA, which is optional.
Also I get no sound on my setup if the MOST cable is not connected. Could be because I have the Harmon Kardon Audio. That is what sends the signal to the amp in the boot. |
01-19-2014, 01:25 PM | #275 | |
Rep 1,976
01-19-2014, 01:44 PM | #276 |
Rep 14
Guys can you help me to figure out what i need to buy to make this nbt work properly?
what about wiring stuff? many thanks |
01-19-2014, 02:27 PM | #277 | |
Rep 458
You would also need to add it to the vehicle order (FA coding) then you would need to VO code both the NBT and the KOMBI (6WA). FA coding changes the list of options on the vehicle. VO coding sets different ECU's on the car to the default values for your FA. You need to VO code the NBT anyway or it will not match the configuration of your car and your sound may not work. |
01-19-2014, 02:46 PM | #278 | |
Rep 14
thanks for your time and reply. my car does have the standard sound system and no amp neither an optical cable. Here comes the dragon and probably i need to put some time learning this, what a nightmare this car is making by rejecting the retrofit. i red in couple of post that i need Enet cable with E-Sys software, but i have no idea of this type of coding and how to do this, OMG this is getting so much more complicated than i was expected, if i knew bmw makes it this much hard then i would have buy a car with this things in it. |
01-19-2014, 04:27 PM | #279 |
Rep 458
I spent the 6 weeks waiting for my car learning about what I would have to do when the car arrived to do the retrofit.
I can't imagine it is much more complex for you than installing the NBT which is mostly plug and play, then add 609 to your FA then VO code the NBT. Even without the 6WA it should work fine, you will just be missing that integration. Just read the sticky thread at the top of this forum. There are guides for changing your FA and VO coding on that thread. It isn't really that complicated. You will need a copy of E-Sys (PM ShawnSheridan) and and ENET cable. You will then need to buy a token for E-Sys and Shawn can tell you where to get this from. I bought one of the cheap (only) ENET cables from eBay UK and it has been rubbish. So rubbish in fact that I'm having a batch of cables made up myself which should arrive this week and will be going on eBay. I will advise you though, that it is possible to mess up your new car. For example due to a faulty Emulator my car has no Stereo or working screen, but I know how to fix it. If you read all the guides and aren't that confident, then it may be best to find someone who can retrofit it for you like bimmertech, but it won't be cheap. |
01-19-2014, 04:49 PM | #280 | |
Rep 14
http://www.ebay.com/itm/BMW-ENET-Eth...316c66&vxp=mtr any good?! i wont code till i am confident that i understand what's going on , thanks for that. I will Pm Shawn for esys. many thanks for your time and replay, much appreciated. |
01-19-2014, 04:54 PM | #281 |
Rep 458
Yeah, that looks like a much better quality cable than the one I bought. I wasn't prepared to wait for that to come from the states so bought one costing £20.
01-20-2014, 04:32 AM | #282 | |
Rep 30
Set KOMBI_CIC to kombi_low Then you can set time/date, trip information, service information will show up I was also using the basic instrument cluster, everything works except for you will not hear warning chimes (annoying, but worth the compromise for the added features in my opinion). |
01-20-2014, 04:56 AM | #283 | |
Rep 14
01-20-2014, 09:28 AM | #284 |
Rep 88
No settings will stick until you VO code NBT. If you have basic Kombi, VO coding will set the KOMBI_CIC to kombi_low.
I supposed you can FDL code but you'd have to figure and set every function. Obvious benefit is that you can also code your own customized settings and do it in one go. |
01-20-2014, 10:34 AM | #285 | |
Rep 30
