01-12-2017, 07:38 PM | #1 |
Rep 110
Drives: F30 335i
19x8.5 et 35, 19x9.5 et33 Max tire size.
19x8.5 et 35, 19x9.5 et33 Max tire size that would fit my F30. I was thinking
245/35-19 and 265/35-19. Can I get 275 in the rear?
2012 F30 335i | M Preformance Aero | Borla ATAK | KW V1 | R1 Slotted & Drilled Rotors + Pads | Injen intake | Bootmod3| VRSF DP | ER 7" Comp FMIC. --- @slow_f30
01-13-2017, 05:47 AM | #2 |
Rep 953
I have the same setup with wheels but am running 235/35/19 front and 265/30/19. You should be fine running 245 in the front if you're only on h&r sports (Let someone with h&r sports confirm), and should be good with a 275 if you wanted.
EDIT: You may need some more camber in the rear to fit the 275
2014 328i - FBO/KW v2/VMR v710's IG@F30_Joe
iseven29.00 |
01-16-2017, 01:42 PM | #3 |
Rep 50
I am running 265 on a 9.5j et35. A 275 would look squarer as the 265 shows a little bit of stretch but in my instance this is needed. As Joe_E said, you would probably need a touch more negative camber to avoid the arch with a 275
iseven29.00 |
01-23-2017, 12:32 PM | #6 |
Luke Wright
166
Rep 252
1. 235/40 and 265/35 would be your best bet unless you're going to slam the car. If you are go with Joe_E's suggestion.
2. 275'S will end up poking excessively in the rear because of the aggressive offset. I chose 265 so I could have a slight stretch 3. With 245/35 and 265/35 you'll have varying diameter wheels, with the front wheels being less tall than the rears making the front wheel gap even worse than it is already. My car on 235/40 and 265/35 with 19x8.5 et35 and 19x9.5 et33 |
07-12-2019, 02:45 AM | #7 |
Rep 250
07-12-2019, 11:29 AM | #8 | |
Rep 129
07-12-2019, 11:45 AM | #9 |
Rep 808
Sorry don't really have any great shots but I run 275/30/19 rear lowered (not crazy) and it works well.
Same wheel specs as you Also included an image of my 'excessive poke'. |
