12-04-2017, 03:16 PM | #177 |
Rep 1,245
Did my first coding today, and it all went well. Much easier, and I felt more confident than the Carly solution.
I was looking at the expert parameters, and saw several starting with "SDARS", which is Satellite Radio. Do any of those do anything? (I've had Sirius activated for a couple of years now). |
12-06-2017, 10:38 AM | #178 |
Rep 59
Is it possible to code out the alarm that goes off when temp drops below 37°? I haven't been able to find it on bimmercode. This alarms annoying as hell I always think it's something worse?
2013 328i M-Sport Estoril blue W/335 M-Performance exhaust
Carver, Mass |
12-06-2017, 09:51 PM | #179 |
Rep 93
Bimmercode works great!
Just purchased the Bimmercode App for my iPhone and OBDII wifi connector to reprogram my 2017 340i GT and my wife's 2016 X3. I programed the mirrors to fold in using the comfort access, the rear hatch to close by remote, got rid of the legal disclaimers and a few other things that bothered me LOL. It worked flawlessly and I highly recommend Bimmercode...It cost me $26 for the app and $25 for the wifi adapter via Amazon...Only took a few minutes to recode each car...no hassles and worked flawlessly!
12-07-2017, 12:20 AM | #180 |
Rep 23
Agreed! Now that it is colder, every day!!! Always a couple blocks away from house and I keep expecting to look down and see I have a flat tire warning or something more serious than "oooh it's 37 degrees out"
12-11-2017, 04:49 AM | #181 |
Rep 25
I did some coding today with Bimmercode, turning off the legal disclaimer and a few other codes including starting car without brake depressed. The brake coding did not work, and now also I have to push the start button twice for the car to start.
I used a backup code to remove the disclaimer and brake function coding to reset back to factory however this did also not work. Any suggestions on how to fix the start button? |
12-11-2017, 12:27 PM | #182 | |
Rep 63
I didn't like it and changed it back. |
12-12-2017, 02:12 AM | #183 |
Rep 9
Ok going to try this out. Just bought the BimmerCode app. Vgate icar pro arrives tomorrow so will give it a whirl. New to coding and willing to learn but looks like the program is pretty easy.
12-12-2017, 08:45 PM | #185 |
Rep 5,458
Drives: F30
Also wondering if engine/transmission coding is possible with BimmerCode?
12-13-2017, 04:39 AM | #186 |
Rep 25
What did you do to change it back? I did the backup and the disclaimer came back but the start button is still the same.
12-13-2017, 05:25 AM | #187 | |
Rep 2,036
http://f30.bimmerpost.com/forums/sho...e+transmission http://f30.bimmerpost.com/forums/sho...e+transmission
molnii481508.00 |
12-16-2017, 02:13 PM | #188 |
Leave the gun. Take the Canoli.
9133
Rep 7,680
Is there a list somewhere of what things to change in expert mode to affect different things? Trying to get the seat to auto move back when I open the door and to auto unlock the doors when I turn the car off. I think they are somewhere in expert mode, but I have no idea where to find anything in there.
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40 --> 2025 X5 M60
Retired: 2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe |
12-16-2017, 05:21 PM | #189 | |
///M SubDriver
1840
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
The sticky focuses on using a laptop with a program called E-Sys to code your car, but it will teach you the basics of how to navigate the parameters that you see in Expert Mode in the BimmerCode app. There are A LOT of parameters available via Expert Mode, most of them are not applicable to the features most people want. Be careful when poking around in there and make sure you understand the parameters you are changing....
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
12-16-2017, 05:37 PM | #190 |
Rep 1,912
My Merc's seat used to go back automatically once I removed the key & back to my memory position when key was inserted again. I do miss this feature, is it possible to code such thing on the BMW?
Happy Motoring
Evdok |
12-16-2017, 06:00 PM | #191 | |
Rep 276
3 lines to code in the very last/bottom ECU (iOS app). My settings: 3000 EINAUSSTIEGSHILFE set to:Modus_FA_SLV 3012 EAH_VERFAHRWEG_SLV_PHYS werte = 00, 3C 3012 EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS werte = 00, 32 Last edited by Somebloke; 12-16-2017 at 06:26 PM.. |
evdok824.00 |
12-16-2017, 06:31 PM | #192 |
Rep 1,912
So you have to wait for the seat to go back before entering or does it go back when exiting the car?
Happy Motoring
Evdok |
12-16-2017, 09:18 PM | #193 |
///M SubDriver
1840
Rep 2,784
It goes back when you turn off the car, prior to exiting.
12-17-2017, 02:31 AM | #194 | |
Rep 63
12-17-2017, 06:49 AM | #195 |
Rep 276
The seat goes back after you've switched off ignition and on opening the door. Seat stays in that back position when you get back in, until ignition when it moves forward to your set driving position.
12-17-2017, 07:04 AM | #196 |
Rep 1,912
Ive seen these settings elsewhere but the 3C & 32 were the other way round!
Happy Motoring
Evdok |
12-17-2017, 07:54 AM | #197 |
Rep 276
These are the settings that work for me. That's why I wrote "My settings". The previous settings I had went too far back.
12-17-2017, 08:12 AM | #198 |
Rep 1,912
Ye I understand what you meant but does the reading 00, 32 mean distance to travel back? on the other settings I found 00, 32 was 00,3C
Happy Motoring
Evdok |
