BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > 328d owners: Can you measure def fluid level?
      12-08-2013, 10:54 AM   #1
m6pwr
m6pwr's Avatar
24
Drives: '14 335i M sport
I've got a new 328d diesel. Great car. My question deals with the ability to measure the level of diesel emission fluid (def) - - much the same way as you can measure the oil level whenever you want.
I was under the impression that the def lasts as long as the factory oil change interval (about 10k miles on the 2014's) and that the fluid need only be replaced or refilled by the dealer at the regular oil service intervals. But I read in the Owner's Manual that the def may need to be replaced once between regular service appointments - - and if you drive in a "sporty" style, the owner may need to replenish the def more often than that. No big problem.
The Owner's Manual indicates it is possible to measure the def level using the iDrive Control Display as follows: select "Vehicle info", "Vehicle status", "Diesel exhaust fluid". Well, I tried that on my 328d and there is no entry or selection for Diesel exhaust fluid under Vehicle status.
Any other 328d owners out there have the same problem, or is there another way to measure the def level? By the way, I have a recent production 328d (October 2013).
'14 328d, '13 M3 ZCP, '12 535i, '11 335d, '09 Z4 DINAN Stage II, '05 330i ZHP, '05 M3 ZCP, '02 M3, '91 328i, '90 535i, '88 528e, '88 M5, '87 M6, '95 Z3, 95 M3, '93 M5, '87 325e, '89 535i, '86 635i, '73 Bavaria.
      12-09-2013, 09:50 AM   #2
glangford
glangford's Avatar
Drives: BMW 328d
I haven't seen it either, but I didn't see it in the manual either. It does give you a warning you need to add some. How much time you have after the warning??
      12-09-2013, 12:11 PM   #3
Moxie
Moxie's Avatar
Drives: AW 328d Touring/SG 335d
You have 999 Miles. You can go to a VW dealer & buy the Ad Blue for less than BMW charges. Even has BMW part # on it. You'll want to get the 1/2 gallon jug & a larger jug. You want to save the 1/2 gallon container for ease of filling. The larger jugs don't screw into the inlet on the car. I didn't get a warning on my 335d until ~18000 Miles. I believe the 328d's tank is smaller. DEF has a shelf life. http://www.idparts.com/catalog/index.php?cPath=25_181
      12-10-2013, 04:42 AM   #4
glangford
glangford's Avatar
Drives: BMW 328d
does anyone know the capacity of adblue in the 328d?
      12-10-2013, 05:01 AM   #5
RIOBLAST
RIOBLAST's Avatar
Sweden
23
Drives: 318d Touring -15
Is this needed for all BMW diesel engines? 320d, 118d too?
      12-10-2013, 09:58 AM   #6
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
1) The 328d being discussed is the US/CA model, which is actually a 320d in EU.
2) Requirement for DEF varies depending upon engine size, vehicle weight & mileage and grams/mile (km) of NOx pollutants.
3) New models in EU of 320d probably do in 2014 (very soon!). Not sure about smaller engines.
      12-10-2013, 10:35 AM   #7
m6pwr
m6pwr's Avatar
24
According to the Owner's Manual: Refill quantity when the 1k mile warning appears is 3 gallons.
      12-10-2013, 03:08 PM   #8
RIOBLAST
RIOBLAST's Avatar
Sweden
23
My manual says nothing about this on either car.
      12-02-2019, 08:32 PM   #9
grimmmmer
Drives: 2015 328d M-Sport
It must be less than 3 gallons; I had ~950 miles left and just overflowed the reservoir onto the floor without finishing a 2.5L jug. Yes, pouring slowly. Clown college.
      12-02-2019, 09:45 PM   #10
catskillclimber
Drives: 328d
We consistently put ~2gal in to fill when the 1k alert goes off.
      12-03-2019, 12:34 PM   #11
FaRKle!
Drives: '17 328d Sport Wagon
I have to fill just under 15L when the warning comes on.
      12-03-2019, 10:59 PM   #12
AlpineX
Drives: Diesel
You'll want to verify you did not clog your passive tank vent.
