08-07-2019, 08:34 AM | #309 |
Rep 1,277
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
08-07-2019, 01:18 PM | #310 | |
Rep 1,105
read up on the description on the app for each stage because it does say, "Re-calibrated S/Sport+ mode for Roll-racing and race track use. Transmission keeps the engine in the upper rev range all the time..."
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
08-09-2019, 02:28 AM | #311 | |
Rep 153
08-09-2019, 12:42 PM | #312 | |
Car Hypochondriac
331
Rep 899
https://m.imgur.com/a/BTSwOXR Btw, the shift point editor is available now, so you can tweak the shift points in D and S mode individually within the app. |
08-09-2019, 06:56 PM | #313 |
Rep 16
I tried stage one and that feels really good. Back to how I’d expect it to be. In sport mode around town it stays in 5th whereas stage 2 loafs around in 8th. If I can change that with the shift points I might try. Just giving a 100% honest review.
ChrisFulton227.50 |
10-17-2019, 07:55 PM | #314 |
Rep 160
why did they remove "race-mode" in v2.5 stg3
..? I personally enjoy it a lot |
racemepunk8.50 |
10-18-2019, 12:24 AM | #315 | |
Car Hypochondriac
331
Rep 899
I personally don't use the stage 3 map because comfort mode manual shifting was harsh on downshifts. |
11-25-2019, 02:54 PM | #317 |
Rep 684
which trans turned out to be better overall from xhp. The 6 speed or the 8 speed zf???? my 135i with zf6 is a monster with xhp stage 3 crazy downshift blips and upshifts extremely fast.... Keep in mind my 6at has only about 30k miles on it as it was replaced by bmw cpo and i changed the fluid at 20k so maybe thats why it feels so good.. I xhp'd a friends 6at and sad to say his felt nothing like mine did, his shifted much slower so wear and tear does play a major role...
12-08-2019, 11:21 PM | #318 |
Rep 2,351
xHP torque limiter
Check this out!
I am blown away by how well this works!!! I set the torque limiter to 221 ftlb/300 nm in 1-4 gear. See how well it manages and the power delivery is butter smooth https://datazap.me/u/harkes/033-xhp-...-9-10-15-19-20
(A Dane in China) |
12-10-2019, 01:00 AM | #320 |
Rep 2,351
Just turned them all the way down for testing purpose. Dont think I'll be using this - I like my car to be a little squirmy when boost hits in 4th
(A Dane in China) |
01-30-2020, 10:33 AM | #322 | ||
Rep 288
01-30-2020, 11:42 AM | #323 | |
Rep 7,555
I have 255 PS4S (basically MPSS) and on a clean dry road i spin first a little but it doesn't blow the tires off like using actual launch control. If you have XHP you can also try launching in 2nd. |
01-30-2020, 12:42 PM | #324 |
1288
Rep 3,502
Is there any way to turn race mode back on with the settings? I really like the idea of stage 3 with trans in sport mode to auto downshift to lowest possible gear. Its great for roll racing.
01-30-2020, 12:50 PM | #325 |
Rep 4,632
Why is it, our cars can make massive tq on the dyno, but are limited in datalogs and on the road..
Is this because of the non load bearing dyno most of us use?
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
01-30-2020, 01:31 PM | #326 |
Rep 1,105
02-12-2020, 06:47 AM | #327 |
Rep 41
I set custom launch control to 25% / 25% but rear tire was spinning too much that I actually lose time. Any recommendation on the settings?
Car is 335i f30 RWD.
335i F30 PWG, PS2, XDI-35, ER DP, CSF FMIC, MST AI, BM3, Snow Perf WMI
02-12-2020, 11:39 AM | #328 | |
Rep 7,555
Or, do what i do with RWD, and don't use launch control. Basically just do your own launch. Left foot on the brake with moderate pressure, floor it with right foot and let off the brake about 0.5-1sec later. You dont want to actually hold the car back with the brake like with launch control, you just want to prevent the car from moving while you "stall" the converter and get the rpm up slightly. Stock turbo will make boost at 1500 rpm, which is about where you get using this method. If you have good tires you should only spin a little on the street with FBO + tune. |
02-12-2020, 11:45 AM | #329 | ||
Rep 41
What does torque scaling do anyway?
02-14-2020, 02:46 AM | #330 |
Rep 531
LoL. My car does this with AWD and MHD Stage 2+ it's awesome !
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
