12-02-2019, 01:00 PM | #266 |
Rep 127
Update:
After enabling the Pressure and Temperature using BImmercode, the TPMS malfunction alerts went away! I have to reset the sensors from the i-drive after coding this feature.
2012 335i | silver | Sport | Premium | DHP | Lane Departure | Nav
12-12-2019, 02:10 AM | #267 |
Rep 328
Hi all,
Is there a detailed guide on exactly what is required, the wiring and also coding procedure for this? I've a late 2013 with the basic TPMS (no individual pressures) Thanks
13' F30 330D XDrive
01-08-2020, 08:57 AM | #268 |
Rep 6
Hi guys, I’ve retrofitted the tpms sensors into my tyres and added 2VB into my VO, coded dsc, fem, kombi ,HU_entrynav and icm. However when I try to reset, the progress bar remains at 49%, and I get a tpms failure warning shortly after.
I get a 4809EB error code in my dsc, tpms no reception, position unknown. My car is a 2015 320i Lci. With a mk100 esc pump. I have also tested all 4 sensors with a tpms tester and all sensors are working fine. Last edited by Alvin1001; 01-08-2020 at 10:56 AM.. |
02-29-2020, 01:23 PM | #270 | |
Rep 15
Did u need any additional HW or just the sensors?
Also trying to test it out, do I need all 4 sensors for it to work? Quote:
03-01-2020, 11:19 AM | #271 |
Rep 18
Guys
I wonder if someone can help me. I have a f31 2013 and followed the guide and purchased brand new tpms sensors 6856227 and also a 2nd hand rdc control unit 6876227 also, which was removed from a F25. I went through the process of coding 2vb and updated all ecus. Rechecked ncd file and all coding completed successfully. Now when I try to perform a reset, I get tpms malfunction. I clear the codes but then I get the following two codes: 480A46 'Tyre Pressure Monitor: gateway or aerial fault D35694 'No message (RDC data package 1, 127.0.2), receiver DSC, transmitter FEM Ive coded DSC, HU NBT, ICM, KOMBI and FEM. I cross checked that all those ecus have updated with new entries as per below: FEM RC_RDC_ENABLE = aktiv ICMQL IcmKod_B_S2VBA = verbaut DSC C_Funktion_RDCi_l = aktiv C_Funktion_RPA_e = nicht_aktiv C_RPA_Extra = nicht_aktiv HU_NBT RDC = aktiv RDC_DRUCK_TEMP = aktiv RDC_FORTSCHRITTSANZEIGE = nicht_aktiv REIFENUEBERWACHUNG_RDC_RPA = rdc RPA = nicht_aktiv KOMBI ST_TYR_RDC_ALIVE = aktiv ST_TYR_RDC_TIMEOUT = aktiv KOMBI DSC_MIT_RPA = ohne_RPA Oh it flashes from active to failed. For a second all the tyres are green with the readings and then it greys out and says failure. Keeps on looping after I reset all error codes. Please can someone help!! Last edited by Harj; 03-01-2020 at 12:40 PM.. |
03-01-2020, 04:42 PM | #275 |
Rep 2,302
03-01-2020, 05:49 PM | #276 |
Rep 18
I made a mistake! I didnt code the RDC ECU. There is no CAFD file and when I try to 'Detect CAF for SWE' I get an error.
I haven't tried flashing it as I dont have the instructions and the link provided earlier doesnt work. Please help!! I feel I'm so close!! |
03-02-2020, 03:30 AM | #277 | |
Rep 2,302
Here is a good and current flashing guide with pictures. https://f30.bimmerpost.com/forums/sh...7&postcount=13 You should skip point 5 - 10. At point 30 choose only the RDC ecu. |
03-02-2020, 04:42 AM | #278 | |
Rep 18
Many thanks I followed that process and when I get to step 30, the RDC is greeted out so unable to flash. |
03-02-2020, 05:05 AM | #279 | |
Rep 18
I went back and still cannot see CAFD. What do I need to do now? |
03-02-2020, 08:23 AM | #280 |
Rep 2,302
03-02-2020, 09:01 AM | #281 |
Rep 18
03-02-2020, 09:13 AM | #282 | |
Rep 2,302
For flashing you need the psdzdata Full. What is the error message when you press "detect caf for swe"? For that you don‘t need the psdzdata Full. |
03-02-2020, 09:40 AM | #283 | |
Rep 18
When I try to select "Detect CAF" I get the error: Failed to get CAFs for SWE swfl_000008fa-004_007_004 If I try against any other ecu, it works. Just not rdc. My rdc unit came from a F25 2015. I'm using e sys 3.33.4 Last edited by Harj; 03-02-2020 at 10:29 AM.. |
03-02-2020, 11:01 AM | #285 |
Rep 18
03-02-2020, 12:41 PM | #286 |
Rep 2,302
