BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Xenon to adaptive Xenon conversion
Studio RSR
      11-10-2015, 04:43 PM   #1
tomsab0
Drives: F48
Hy, I am wondering if it is possible to exchange the basic Xenon headlights with adaptive headlights. Will it be plug n play? Is the pinout the same?
      11-13-2015, 01:55 PM   #2
Chris93
Chris93's Avatar
30
Drives: BMW M340d
Just done this myself you need:
New headlights (£900 each)
New driver control modules (£315 each)
The rest can be transferred over from your old xenon's
You have to take the bumper off to fit them and make sure you take the wheels off, i didnt and it made it so difficult the access is terrible
You then need to code the VO and add 524 for adaptive headlights otherwise the turning and self levelling won't work. Its pretty involved but i think its worth it as they are so much better at lighting the road than standard xenon, i don't think the beam pattern on the standard ones is very good
Chris
G21 M340d Touring - Skyscraper Grey over Cognac interior
      11-14-2015, 09:09 AM   #3
tomsab0
Drives: F48
Thank you for your reply.
Is the pinout the same or did you Change the wiring?
      11-14-2015, 10:16 AM   #4
Chris93
Chris93's Avatar
30
Drives: BMW M340d
No Wiring is the same as regular xenon
      11-15-2015, 10:19 AM   #5
lemonchicken
Drives: 2013 328i blue
is this really worth the trouble and money? i have adaptives and don't really think they're all that but I dunno?? maybe I'm missing something
      11-15-2015, 04:07 PM   #6
Chris93
Chris93's Avatar
30
Drives: BMW M340d
Yes, the standard xenon's beam is not very good and in europe the adaptive are coded differently so we have no glare high beam assist and the light beam changes with speed. They are very good
      11-15-2015, 07:08 PM   #7
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
So we have to change the current headlight and buy another one? Won't it be better to go the LED headlight route?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      11-17-2015, 11:28 AM   #8
Chris93
Chris93's Avatar
30
Drives: BMW M340d
LED needs additional wiring and even more added expense and many people have said they aren't impressed with the light output, i have seen both and think xenon is a better light quality
      11-17-2015, 04:37 PM   #9
sdjro
Romania
Drives: BMW F82
Chris
So you had to replace headlights?what is the difference between normal xenon, and adaptive xenon headlights?
      11-18-2015, 12:39 PM   #10
Chris93
Chris93's Avatar
30
Drives: BMW M340d
Adaptive xenons swivel in the corners and the beam constantly adjusts dependant on your speed. The light output is much better and wider
      11-18-2015, 02:50 PM   #11
sdjro
Romania
Drives: BMW F82
i meant physical difference between the ''normal'' xenon headlight and adaptive xenon headlight,do they have some electrical motor or different lens...
on real oem are different codes for these headlights and the prices are different as well,with the adaptive one being more expensive.
i think i will drop this conversion,new headlights and new control modules are all together too expensive,if only new control modules and coding were needed it was ok
      11-18-2015, 02:56 PM   #12
Chris93
Chris93's Avatar
30
Drives: BMW M340d
The adaptives are heavier, have an additional motor inside for swivelling and different internals although they look identical on the outside and have the same part number on the top
      11-19-2015, 05:49 AM   #13
sdjro
Romania
Drives: BMW F82
thak you for the info
      11-24-2015, 05:21 AM   #14
beanbaguk
beanbaguk's Avatar
Spain
455
Drives: BMW G30 520d M-Sport
That and the new LCI projectors look quite ugly (IMHO). I saw one for the first time on the road and the pre-LCI LED sidelights (angel eyes) look much nicer.
      12-11-2019, 04:44 AM   #15
mastrchee
mastrchee's Avatar
Drives: i4 M50
Chris
Sorry to revive an old thread - do you happen to have the part number or any reference to the driver control modules? thanks
