03-20-2017, 06:18 PM | #1 |
Rep 403
Mods to stock air intake
I want the sound from an aftermarket intake without the price tag.
Basicly intakes gives you 0hp so why spend 500$ for them. I took a look at the OEM intake and the silencer is inside the tube that goes from the airbox to the turbo inlet. It may be possible to modify this tube or find a replacement tube without the silencer inside ? If we can come to a solution for less than 100$ with an aftermarket drop in filter it could be a really good alternative and it will look OEM Last edited by F30RiK; 03-26-2017 at 08:18 PM.. |
03-21-2017, 01:25 PM | #2 | |
Nemo banks
65
Rep 253
Like how people modded the stock intake on the e90s .
FBO N20, G-Plus Oil Cooler , Injen Cold Air Intake, MST turbo inlet, AFE Charge Pipe, BMS Oil Catch Can, Forged Motorsport Blow of Vavle, Wanger FMIC, Circuit Werkes Catless Downpipe, Full Straight 3inch exhuast. Stage 2 Active Auto Werke.
03-23-2017, 12:49 PM | #4 |
Big Turbo Boys N Girls
327
Rep 579
Most probably wont venture into this as you can get a slightly used one for around 150-to 250 shipped from the classifieds if you don't want to spend for new. I got mine for 225 shipped from a member and it was never opened. Just got to look.
But one way you can do it is by getting a Silicone J pipe and cutting at the right location or getting an aluminum J pipe and doing the same thing. Than just use silicone Couplers to clamp and you should be good to go. |
03-25-2017, 07:50 PM | #6 |
Rep 190,725
Injen intake costs a lot less than $500
03-29-2017, 08:46 PM | #8 |
Rep 403
The intake resonator is inside this intake tube. If someone can make the same tube without the resonator we should get an injen like sound and everything will look OEM |
waxwing_f311.50 |
12-05-2019, 11:33 PM | #9 |
BMW Fan
Rep 15
12-06-2019, 01:28 AM | #11 |
Rep 943
Drives: F30 328i Msport
3D scan that part, design a CAD replacement to fit OEM dimensions, manufacture in china=profit???!?!?
Theoretically I have the tools to do that, but is it worth it? Doubt it. It'll end up costing as much as a full intake setup from the other vendors. |
12-06-2019, 08:31 AM | #12 |
Rep 5,457
Drives: F30
waxwing_f311.50 |
01-30-2022, 07:32 AM | #13 |
Rep 13
01-30-2022, 08:21 AM | #14 |
Rep 5,457
Drives: F30
Turner Motorsports makes a replacement pipe like the one pictured above, without the baffles.
01-30-2022, 08:22 AM | #15 | |
Rep 1,058
Turner Motorsport sells this. https://www.turnermotorsport.com/p-5...rbo-inlet-n20/ That pipe gets rid of the turbo baffling inside the air intake system. The remaining is cutting/burring out the plastic ridges inside the air box itself.
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
01-30-2022, 11:02 AM | #16 |
Rep 666
01-30-2022, 11:06 AM | #17 |
Rep 133
i have this config, https://www.turnermotorsport.com/p-5...rbo-inlet-n20/ upper intake and k&n filter oem box in my N20, and this is the result, i love this, the next DV+ jajaj.
01-30-2022, 11:36 AM | #18 |
Rep 1,058
It's sound + throttle response. Same thing the cold air intakes do for the car. It's minor but 1-4th the cost of an intake for the throttle response and a somewhat roar from the air box.
01-30-2022, 11:45 AM | #19 | |
Rep 666
like a gun silencer, does a gun silencer make a gun less deadly? a bullet is a bullet, it will hurt or kill with or without gun silencer. air is just air, the only thing i can think of that cause a lag in throttle response is if the diameter of the OEM silencer pipe is smaller than the turner straight pipe, therefore less air volume, but i don't have measurement of both pipes, so i can't claim. the sound, yes, i understand, that's what a resonator does, to silence any noise, but claiming a lag in throttle response due to a resonator is a bit far |
01-30-2022, 12:49 PM | #20 | ||
Rep 1,058
alohasurftoad3076.50 |
01-30-2022, 12:50 PM | #21 |
Rep 1,425
Longer video (14:20), but provides a good explanation about the effect of resonators and Helmholtz chambers. As described, it's not a simple baffle that directly restricts airflow:
https://www.youtube.com/watch?v=d1dHChRGA0U
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
