11-14-2019, 02:43 PM | #23 |
Rep 353
Honestly I'm not sure how much the heat would help, but if you want I'd say give the credit card method a shot! Maybe I accidentally broke half of one of my clips because the squeegee is bigger and thicker.. and I also didn't care to be as careful because I wouldn't need my OEM caps anymore
11-14-2019, 03:44 PM | #24 | |
Rep 741
11-14-2019, 04:03 PM | #25 |
Rep 353
11-14-2019, 04:30 PM | #26 | |
Rep 741
a review i found from that seller, can you relate? "The driver side cover fits right on and perfectly, I had to file for an exchange because the passenger side did not fit well, I received the exchange only to find out that the passenger cover fits the same way as the first one. I am a bit OCD and I like things to fit perfectly, I will let this one pass because these covers just make my car look soooooo sexy. Go ahead and make the purchase, just keep in mind that passenger side cover is a lil off, but they make up for how beautiful these will look in your car." |
11-14-2019, 04:39 PM | #27 | |
Rep 353
As for longevity, I've had these since the end of September and live in Texas. The temperatures were pretty warm/hot when I first got them and it still seems to be doing okay. Will probably update when summer comes with daily 90-100 degree temperatures. |
11-14-2019, 04:45 PM | #28 |
Rep 16,054
You don't need heat or a credit card. What works very well is a pair of plastic trim removal wedges. A pair, so you can apply pressure on opposite sides of the cover. What leads to broken clips is applying pressure to only one side.
11-15-2019, 09:41 AM | #29 | |
Rep 741
11-18-2019, 08:19 PM | #31 |
Rep 353
11-20-2019, 04:00 PM | #32 |
Rep 52
I'm curious about the longevity of these things. It looks like some of the reviews complain about fading/yellowing. I'm curious if I could just put some UV resistant clear on there and solve that problem.
11-20-2019, 04:03 PM | #33 | |
Rep 353
There may be better sprays for UV protection or products but I haven't looked into it as much |
11-21-2019, 08:18 AM | #34 |
Rep 52
I just skinned some door pull trim in carbon fiber, and am using Sp*****x 2K clearcoat as the top coat. It is 2 part "automotive" clear in a can. It's pretty expensive for a single rattle can (relatively), but it is surprisingly awesome stuff, and adds a layer of UV resistance.
11-24-2019, 06:38 PM | #35 |
Rep 2,653
I treated mine with Jescar Power Lock and 2 coats of Collinite 845. They look amazing. Hopefully they will stay that way
11-27-2019, 03:20 PM | #36 |
PsyD
102
Rep 156
Drives: 2016 340i M-sport
Ordered these the other day. I had a problem with fitment on the passenger side, specifically near the bottom on the side closest to the car. In trying to fix the fitment issue, I ended up snapping a couple clips. So they're going back, and I guess I'll try it again. I went with taking the full mirror off too without having any problems in doing so. I had a little trouble with putting the driver's side mirror back in, but I ended up figuring it out after trying it a couple times.
11-28-2019, 11:57 AM | #37 | |
Rep 353
11-29-2019, 02:53 PM | #38 |
Rep 2,653
This works well also. I have to disagree on the heat though. Heating plastic makes it more malleable and less prone to breaking.
12-03-2019, 12:23 AM | #39 |
PsyD
102
Rep 156
Yeah I got the second set yesterday. I'll wait til I can get the car in the garage and it's not so cold for me to try again. I'll post with update.
01-26-2020, 06:02 AM | #40 | |
Rep 2,174
Can you post pic of the mirrors form the driver side point of view or inside of the car?
01-26-2020, 09:41 PM | #41 |
Rep 16,054
True, but the clips are inside the cover, where you can't reach them to heat them. I would avoid trying to pop the old covers off in cold weather, and even in good weather have the car in the sun where it reaches the mirrors for a few hours.
01-26-2020, 10:11 PM | #42 | ||
Rep 76
01-27-2020, 09:36 AM | #44 |
Rep 76
Thank you.....you may have just got them another order lol
I have the same color bmw as the OP, do you find the carbon sticks out against the mineral grey? I'm wondering how noticeable the carbon even is |
