BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > NBT Continuously rebooting after new Maps install
      01-14-2019, 09:13 PM   #45
Kamz2070
Drives: E92 M Sport Alpine White
Also can the idrive firmware be updated if the idrive keeps rebooting?
      01-26-2019, 01:59 PM   #46
grzesiekb80
Drives: F11 530d
Hi, same problem here. Car 2013 F11.
Installed 2019-1 maps, after few hours did 120 mile trip, all was fine. Next day NBT start rebooting every 1 min, not enough time to update idrive.
Anyone know simple solution other than dealer?
      01-27-2019, 05:11 PM   #47
grzesiekb80
Drives: F11 530d
Originally Posted by cassius777 View Post
Hi, have the same, what i found so far is downgrade to 2017 maps should help, but how to attempt to do that if idrive rebots every 1 minute?
anyone?
edit: the car is from 2013
edit: I found that from time to time nav stops rebooting (in my case it was 1.5h of constant driving), i have used that occasion to reload earlier maps. Since then everything seems to be ok.
Long driving seems help, after 1 hr stopped rebooting, had my USB ready so upgraded Idrive. I was also trying to disable all options in the system, but no luck, some time later stopped resetting. Don't know if it helped, I'll see later if it's fixed for good.
      03-07-2019, 11:52 AM   #48
bbotas
Drives: f10
Originally Posted by XuLeTZ View Post
2012-2013 cars are using an old firmware on the HU, hence they can't show the content of the new map and it will restart the HU. So an ECU update of HU_NBT must be done.
You can do it at home also, as I just done mine with E-Sys and the full version of E-sys PSdZData.
I had my I-Step version 12-07-533 and went to 18-03-532.
Be aware it will take like 1 hour if you have the basic hard drive. I have upgraded to SSD and my job was completed in 28 minutes.
You will need a power charger if you don't want to mess the ECU during the update.
Hey Can you help me with that? I have same thing as you had it so now I need to update my HU and can't really find any info about that.
And another strange think I did updtate my nav from 2013 NBT next 2019 nbt next and it didn't asked me for FSC code, however today I went to check my car and it asked me to enter code but that code I entered sec after it's asking me again to do same... any Ideas or anyone could help me with that?
      03-07-2019, 12:30 PM   #49
XuLeTZ
XuLeTZ's Avatar
Drives: BMW 320d F31 M Sport
Hi,
No idea why is asking you for FSC every time.
If you need help with updating the iStep, DM me
Regards,
Alex
      03-25-2019, 11:40 AM   #50
EnerJi
Drives: '13 BMW 335i M-Sport EB-II
Originally Posted by shrubbery View Post
Quick update.
The dealer has replaced the head unit under warranty and has coded the ECUs.
This has fixed the issue with 2018-1 maps but I don't know if changing the head unit or changing the firmware fixed the issue...
I suspect probably the firmware but not going to whinge about a new head unit (including replacement cracked radio buttons).
I have the same car and am having some occasional navigation system problems. I'm curious how you managed to get BMW to replace it under warranty? Is there a quiet warranty extension for the CIC nav units on the 2013s?
      03-26-2019, 06:00 AM   #51
Moto749r
Drives: BMW F31 330d M Sport
Hey guys.
Just bought a f31 330d msport, all great then the idrive has started just rebooting over and over. Thought I'd try the BMW.com/update and yes there is an update, but the idrive reboots before it's had chance to install it. Any answers apart from a new head unit, pretty please.
      05-12-2019, 02:27 AM   #52
Rajdhami
Drives: BMW f30 328i
Quick update.
Hi mate. You said your car was out of warranty but you managed to get the HU changed under warranty. How did you manage that? I have the same problem as you did, but its been 6 years since my 2013 F30 was built.
      07-08-2019, 10:13 AM   #53
San75
Drives: BMW E60 F30
Originally Posted by Moto749r View Post
Hey guys.
Mine is doing the same. Can I force a hard reset to wipe any setting etc?
      07-10-2019, 02:53 AM   #54
shrubbery
Drives: F30 330d M Sport
Hi, sorry for the late response.
The head unit was replaced under BMW's extended warranty program that I was paying for, not the original vehicle 3yr warranty.
F30 BMW 330d M Sport
E46 BMW 330d SE | SOLD
E36 BMW 318i SE | SOLD
      07-10-2019, 03:00 AM   #55
shrubbery
Hey guys.
I don't think that the updates through BMW.com/update have anything to do with this issue.
The main firmware of your HU will probably need updating and this cannot be completed via USB. Only a dealer or someone with the necessary software / hardware can complete this task.
It does look like there is an incompatibility between the HU firmware (I-Step version) of some 2012-2013 NBT cars and map updates after 2018-1.
BMW should really be fixing this issue for free regardless of warranty cover as they are releasing the incompatible map updates (that we are having to pay them for!) and these maps seem to be causing issues with people's stock HUs. As was mentioned earlier in the thread, BMW know the VIN of your car and therefore what version of I-Step you are running so this really should not be an issue in the first place if they had handled things properly.
      07-10-2019, 03:09 AM   #56
shrubbery
Originally Posted by Kamz2070 View Post
Hi mate, how did you re upload the older version of the map if the idrive is rebooting doesn't that stop the download?
Mine only started rebooting if I moved the car. If I started it up and didn't drive anywhere then I could downgrade the maps to 2017.
      12-24-2019, 12:47 AM   #57
F30zoom
F30zoom's Avatar
Drives: F34 330d xdrive
Question
Hi,
Anyone having any issues with idrive reboots after 2020-1 map install? Also guide to update idrive or links would be useful I already code via Esys but never done idrive firmware update other than via usb.
Rgds
Pete
      03-21-2020, 07:03 AM   #58
narse
Drives: BMW 135
Has anyone had any experience of this fault on the 2020-1 maps? I have them downloaded, but worried about installing them. Also does anyone know where I can get the 2017 map files if I need to downgrade after?
      03-21-2020, 07:07 AM   #59
x-m4n
x-m4n's Avatar
Drives: Gran Turismo (F34)
I installed NBT Europe west 2020-2 this week and all is working as usual
      06-16-2020, 04:35 AM   #60
678hug
Drives: F48 2.0i XLine
I've just tried to install 2020-2 and it failed to complete. Now getting the reboot. Old nav is still on there and working but the 10 minute reboots weren't there before i attempted it. Mine is a 2015 F31 with NBT
