07-12-2015, 03:19 PM | #1 |
Rep 183
Shell V-Power rough idle
So I recently tried Shell V power for around 6 fill-ups and notice that my car idles worse than diesels (my but feels full of vibration). I switched to Sunoco, then my car idles smooth like before. BP also makes my car idles smoother. Anybody had this problem with Shell V-Power? I tried Shell in many places (PA, NJ, NY, etc.) And all of them cause roughness.
But power-wise, V-Power kicked butt with my BMS stage 1. |
07-13-2015, 06:17 AM | #3 |
Assassin
144
Rep 156
Drives: 2013 F30 335i Xdrive M-SPORT
I use Shell gasoline, (93 octane) and have had no issues, and I feel it burns a little cleaner too. Judging from my chrome exhaust tips, the black soot is very low compared to other fuels.( I also have tried Exxon 93 octane.)
Verify that the gas attendant is indeed using 91 octane or higher with your BMS stage 1 piggyback. If you are running regular 87 octane with a piggyback it will cause the issues you listed. Another suggestion that I have found does work is maybe running some http://m.advanceautoparts.com/mt/sho...ontent=7081073 Last edited by jamoka3; 07-13-2015 at 06:26 AM.. |
07-13-2015, 09:52 AM | #4 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
I've been using V-Power since I got my car in March, no issues no far.
07-13-2015, 11:32 AM | #5 | |
Rep 674
07-13-2015, 11:56 AM | #6 |
Assassin
144
Rep 156
The octane number indicates the degree of resistance to knock. In other words, the higher the number the higher compression that will be required to fully ignite and combust the air fuel mixture in the combustion chamber. Not running the proper octane considering compression and timing will cause either premature detonation (octane level to low) hence combustion is happening before piston arrives at top dead center, or occurring to late (octane level to high) therefore unburnt fuel in combustion chamber exiting into exhaust and such. Rough idle caused by running to low of an octane?
That anyways is my interpretation of octane levels. If I am wrong pardon me and I hope to be corrected. We are all here to in fact learn! |
07-13-2015, 12:19 PM | #7 | |
Rep 674
07-13-2015, 11:06 PM | #8 |
Rep 183
I mostly filled up by myself with V-Power since I lived in Philly and there's no attendant. I just suspect either the new nitro thing or the high ethanol content since I felt a great power boost from them. I just filled up with full tank of V-power somewhere in Jackson, NJ and my car started to idle pretty rough again. Maybe I'll try techron just in case its idling rough because of sunoco.
07-13-2015, 11:20 PM | #9 |
Rep 183
Or is it also possible that Shell cleans up the system really well that it pushes out all the junk all over the place? Sounds like a bad logic though
07-14-2015, 02:30 AM | #10 |
SPEED RACER
375
Rep 740
It could just be a badly maintained gas station with excess water in the fuel.
2019 BMW X5 M50d Artic Grey | 2020 BMW M2 CS Misano Blue
Incoming - Ginetta G56 GT Academy | Incoming - BMW X5M Comp Oxford Green RIP - 2020 Mini JCW GP Racing Grey | RIP - 2013 X3 xDrive28i Carbon Black |
07-14-2015, 06:32 AM | #11 |
Rep 183
07-14-2015, 07:23 AM | #12 |
SPEED RACER
375
Rep 740
Try the Italian Tune up. Put the car into manual and keep the car at around 4000 rpm for 10 mins and see if that helps. Also driving your car like you stole it might help haha.
07-14-2015, 09:20 AM | #14 |
IG @bmwF9xG80
3813
Rep 7,592
Funny once I used 89 when there was No 93 available (Sandy Storm) and noticed it idle rough, put 93 back and it went away.
Shell is the best premium gas in the NorthEast (Power and Burns Cleaner) Definitely put a bottle of Techron or Redline when the tank is almost empty to see.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 07-14-2015 at 10:07 AM.. |
07-14-2015, 09:55 AM | #15 | |
Rep 115,980
Shell is pretty good gas so its pretty odd to have issues with it across many different stations. Mike |
07-14-2015, 06:45 PM | #16 |
Rep 183
Maybe there's something wrong with east coast Shell? I never filled up with anything lower than 93 (never touched 91) Every shell yields the same bad result, while every BP and Sunoco removes the problem. I've bought 20 oz Techron and will see if it helps and update.
Every one said that Shell is one of the best gas and always get a very good results. I'm dieing to figure out what's wrong with my car. |
07-14-2015, 06:56 PM | #17 | |
Rep 183
07-14-2015, 07:04 PM | #18 |
IG @bmwF9xG80
3813
Rep 7,592
Redline, Techron in that order
But get whichever of those u can from your local Auto store. Weird because I used Costco, BP, 76Gas, ExxonMobil, Shell and Valero. Did some testing in BMW 328xi, Mercedes C300, Cadillac STS, and now X3 and notice Shell is best performance and better mpg. Shell Valero 76Gas Costco BP ExxonMobil In that order works for me, and have not tried Sunoco only did once in my Cadillac but can't remember and will not put it in my current car.
07-14-2015, 08:17 PM | #19 | |
Rep 183
07-14-2015, 08:36 PM | #20 | |
Rep 183
07-20-2015, 11:41 AM | #21 |
Rep 228
I just tried the Nitro+. Have consistently used the old v-power 93 and it was good. The Nitro+ gave me 10% LOWER gas mileage. Car seemed to run fine but the mileage difference is unacceptable. Luckily i have a station on the way to work that has 100% gas. Only 91 oct but car loves it! On the old v-power 93 I would avg 29.7 combined. The nitro+ had me working to avg 27. The 91 no ethanol I'm at 32.9 avg COMBINED.
Am I the only one the laughed at the comment about a gas station attendant? I haven't seen that since 1991. |
07-20-2015, 12:32 PM | #22 |
Rep 183
I wish there's 100% gas station near me. I tried techron and it helped a little bit for the rough idle, but not that significant. I just suspect the 10% "foreign" stuff in V-Power that causes the rough idling.
