02-17-2020, 02:32 PM | #1 |
Rep 90
440i exhaust fit 320i B48
Hi,
Would this 340i/440i exhaust fit my 320i b48 without any welding or major modifications? It is pretty much the full system being sold at a good price. Thanks Last edited by mechamanz; 02-17-2020 at 04:10 PM.. |
02-17-2020, 04:13 PM | #2 |
Rep 90
Just to add....the pipe diameter Cat back is both 80mm, but on the image it looks like it bends slightly different?
Has anyone had any experience with this? And, was it just a simple bolt-on job? |
02-18-2020, 01:51 PM | #4 | |
Rep 90
In that case what if this bit is cut off and a pipe is fitted from cat to 340i front muffler (as circled on attached image)? |
03-11-2020, 06:01 PM | #5 | |
Rep 90
As per my response above, what if I fabricate a pipe from the cat to 340i front muffler (as circled on attached image)? Would this work? |
03-15-2020, 09:25 AM | #6 |
Rep 1,058
There are no gains to be made if you bought and fitted this exhaust. Look up dual muffler conversion 320/328i. That's literally the difference.
Looks wise, it looks really good to have two outlets instead of one.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block |
03-15-2020, 12:47 PM | #7 |
Rep 90
Yes, I am aware of this - I am mainly going for aesthetics (looking to follow up with some 3.5 inch akrapovic tips), but I understand there is a minor sound benefit (slightly more if i do the ''PE'' mod to it)
03-15-2020, 02:47 PM | #8 |
Rep 1,058
Give it a shot. The stock 335/340i muffler compared to the 320/328i muffler seems as if it's slightly louder than the stock twin-pipe one side exit muffler. As I literally did this conversion a couple of days ago, I think it seems to be "louder" due to sound coming from two sides of the car instead of one. Friends say the car is slightly "louder" then again I also flashed stage 2 bm3 without a downpipe as I drive like a grandma with hot weather in Florida. Catless Downpipe is on the way to add on the supporting mods.
mechamanz26.50 |
03-15-2020, 04:19 PM | #9 | |
Rep 3,752
Also mounting area #7 on the photo is slightly different. |
mechamanz26.50 |
11-15-2021, 12:43 PM | #10 |
Rep 5
Waking this thread up since I'm hoping to have this done while getting my car serviced on Thursday...
I have the full 340i exhaust system ready. Does anyone know if the circled part above has the same diameter? So that it would in best of worlds come down to cutting the current 320i exhaust and the 340i exhaust, lining it up and welding it together? Or did BMW decide that the 320i should go from 80mm straight down to 65mm at once? Looking at images - it doesn't appear to be the case - but would LOVE to get some facts |
11-15-2021, 05:07 PM | #11 |
Ozzy Dude
222
Rep 187
Drives: BMW F30 330i LCI
Hi Oliver - you need a couple of other parts to fit the whole system as the exhaust mounting is slightly different. Also the down pipe is on a different position, so not a straight fit. All factory fitted exhaust systems are in one piece but there is a marked cutting point just before the muffler I have done the rear muffler box conversion on my 330i (also from a 440i - see picture below ) and my exhaust shop has just used an adapter from 75mm to 80mm. I would only change the rear box as it is pretty much plug n play apart from the adapter. The cutting point for the 440i is on the same spot than for the 320i (B48) exhaust. I have finished mine off with Akrapovic exhaust tips. The video link is for US cars, they don't need an adapter but it is the same apart from that. The cutting point is explained as well.
11-16-2021, 12:43 AM | #12 | |
Rep 5
Looks more and more like this will be the most likely option. Cant help thinking that the larger diameter 80mm vs 65mm would help when I go for my custom tune and also add some more sound without be obnoxious. |
11-24-2021, 06:15 AM | #13 |
Rep 5
And there we go. Exhaust is fitted. They fitted the entire 340i system onto my 320i.
Only thing they had to do was cut the piece shown further up in this thread. They then cut the original 320i system in the same area. Welded it together and voila - 100% fit. Anyone looking to do this - the diameter of this first step of the exhaust is the same on 340i and 320i. No video as of yet - but exactly the difference I was looking for - subtle. Last edited by 0liver; 11-24-2021 at 06:21 AM.. Reason: Photo is rotated - don't know why |
11-26-2021, 03:12 PM | #14 | |
Ozzy Dude
222
Rep 187
That's great - you probably the first person with this particular mod. How do you like the sound? the muffler box alone is quite an update but the whole system must be awesome. |
01-05-2022, 10:10 AM | #15 | |
Rep 5
I will try to make a video, family been ill and the plan to meet up with my brother to make a decent video - turned into not happening. I will see if I can at least make a "startup" video this week 🚀 But all in all - it's most definitely to quiet if it's a lot of sound that one is after, however it is clearly louder than the normal exhaust (but could be partially due to the OPF delete) Got the cheapest diffuser on stock. Looking to replace it and add m-performance front lip and side extensions during spring this year Last edited by 0liver; 01-05-2022 at 10:15 AM.. |
01-11-2022, 09:38 PM | #16 |
Rep 1
Hi guys, i have catback exhaust from 340i on my 320i. Little bit tricky and good welder will do it easly. I have a question for you, mine exhaust flap is uninstalled (because 320i have not controller and connector for it) for a year. How do you control your flap?
i have it with always opened flap and the sound is crazy good (catless downpipe+BM3) but for some comfort driving i am finding somethink to operate the flap. thank you |
01-12-2022, 10:02 PM | #17 | |
Rep 1,788
https://valvetronic.com/products/ele...d853c7ed&_ss=r |
