03-19-2020, 12:16 PM | #1 |
Rep 42
Diy bavgruppe headlights tips?
Hi, hello. Recently, I have to courage to go through with the idea of doing a DIY blacking out my headlights and adding the Bavgruppe vision led rings instead of paying 1.4k for someone to do them. I was looking around their website and found some tutorial but there isn't much. So I want to ask if any of you guys have experience with this product and do you guys have tips for installing them? I'm more clueless about the wiring aspect. I have a 2016 435i xenon. Thanks!!
This is the one I was planning: https://www.bavgruppedesign.com/prod...hts-only-5r9n8 |
03-25-2020, 07:23 PM | #2 | |
Rep 169
That being said if this is your first time ever opening up headlights, there is plenty of prep work needed as well as post work to make sure they seal back up correctly. If you are just swapping in White angels or switch backs this will alleviate I would say 10% of the overall work. RGB controllers for color-changing LEDs will bring other headaches of where to mount them and more wiring. Maybe find a buddy or someone who has done it before local to you to get some hands-on help. This is the type of project where you will either find out you are good with your hands or not, messing up is expensive if you get unnecessary moisture or damage any components. Hope this helps, good luck! |
03-30-2020, 09:08 PM | #3 | |
Rep 42
I got the pry tools with the hook. Butyl sealer, oven cleaner for stripping chrome, duplicolor high heat paints and a heat gun. I'm not doing rgb as that looks more complicated haha. I'm just more confused about the wiring. Was it simple when you were install them? |
03-31-2020, 06:43 PM | #4 | |
Rep 169
04-14-2020, 02:47 AM | #6 | |
Rep 42
Did you use the oven technique? Or the heat gun? Technically, the whole setup is powered via the fuse cable right? |
04-14-2020, 07:28 AM | #7 | ||
Rep 12
04-14-2020, 07:31 AM | #8 | ||
Rep 12
01-03-2021, 12:51 PM | #10 |
Rep 42
Sorry for reviving the thread but I literally seriously started the headlight modification a week ago and I ran into a couple of issues. Any help is appreciated!
Everything is actually painted black, reassembled and the permaseal is cleaned off as best as I can except for the brows. I heard you have to dremel and mod them to fit the LED strip in, is that true? For the wiring part, do I have to mod the rear circle panel to fit the wires through? How much of the whole wiring harness am I suppose to hide into the headlight? For switchbacks do I need to solder the wire on or can I just wrap it around the turn signal pin? Lastly, for the rings is there a specific way you stick it on? and what points do you put 3m tape on? Thanks guys!! Sorry for bombarding with questions! |
07-01-2022, 02:03 PM | #11 | |
Rep 13
Hey also reviving an old thread! do you solder the wire or how did you go about tapping in the switchback eyebrow? did you take a dremel to fit the eyebrow in or just 3m/glue it on? thanks! |
07-03-2022, 01:38 PM | #12 | ||
Rep 19
07-08-2022, 01:27 AM | #13 | |
Rep 13
Were you able to get your fuse to sit flush and actually click in as a fuse normally would? After trimming, I cant get my fuse to sit flush. I also discovered I have a fuse on The second fuse from the bottom where everyone says to plug into, need to find another switched fuse that will work. Also discovered my rings and eyebrow strip don't power on. I tried just tapping the positive & negative & pushing the fuse in without actually plugging in the headlight assembly to see if only the rings and eyebrow will light up and it didn't. No relay click or anything. Hopefully it's not faulty and it's just my error. Would assume the rings and strip to turn on automatically just from receiving power after plugging in the plug & play harness. |
