03-29-2020, 04:14 AM | #1 |
Rep 154
Spoiler install
How can i install a rear lip spoiler? will a 3M double sided tape be good enough? is there any specific one i should get?
also if i want to remove the spoiler, how do i do it if i use a double sided tape? |
03-29-2020, 07:45 AM | #2 |
Rep 2,957
3M automotive tape is what most people use. When you want to remove it you'll need to clean the tape residue but worry about that when/if the time comes.
03-29-2020, 08:35 AM | #3 |
Rep 975
Yes 3M is what many use. They key is prepping the surface. The cleaner the better adhesion.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
03-31-2020, 04:58 PM | #4 |
BMW CCA Member
488
Rep 808
FWIW, it depends. I've used 3M outdoor 50lb, 3M automotive and urethane glue.
Of the three, the glue is the only stuff that has held up under rain and sun over the years. Tape is OK in a pinch, but as soon as a cold rain hits, the tape shrinks, water seeps into the space and it begins to deteriorate. My last car, a Subaru BRZ, man I ripped the spoiler off 3x in a year because the tape just wouldn't hold. So when it came time to add the spoiler to my 435i, I had a body shop use the glue. |
03-31-2020, 05:05 PM | #5 |
Rep 1,058
3m super strength molding tape is what worked for me and my spoiler. Everything else sucked. Clean all surfaces with rubbing alcohol, apply to spoiler and heat up tape slightly with heat gun, apply to clean trunk and hit with slight heat pressing spoiler into trunk. Will take a couple hours to set but doesn't come loose even in heavy tropical train storm miami rain.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block |
03-31-2020, 05:06 PM | #6 |
Rep 16,079
Use this, after a thorough cleaning with rubbing alcohol.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
04-04-2020, 10:37 AM | #7 |
¯\_(ツ)_/¯
945
Rep 1,762
04-07-2020, 10:20 AM | #8 |
Stance to make her dance
705
Rep 1,995
Few more DIY videos to help...
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2022 G80 M3 6MT, FEMTO, BM3, KW, AWE, MAD, lots of carbon |
04-07-2020, 11:27 AM | #9 |
Rep 190,750
We use 3M VHB
