BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to clear check engine codes with Esys / an ENET cable?
      01-28-2016, 07:59 PM   #221
Propilot7x
Propilot7x's Avatar
Drives: 2015 F32 428i Sport
Code
Hi Shawn, I got a code that I'm trying to clear out from the oil level sensor.
Can you please pm the link to download tool32 ediag or Esys? I'm also looking to download the maps for 2016. Thanks for all the help.
2015 F32
      01-28-2016, 08:44 PM   #222
shawnsheridan
shawnsheridan's Avatar
2015 F32
PM sent.
      02-06-2016, 04:14 AM   #223
Stef80
Drives: F20 120i msport auto
Good morning Shawn,
Can you please send me the software for reading and clearing codes with the enet cable?
Is this the same software for logging the car? Where could I find the logging software?
Thank you very much.
      02-06-2016, 07:52 AM   #224
shawnsheridan
Originally Posted by Stef80 View Post
Good morning Shawn,
You can clear codes with E-Sys or Tool32. PM sent.
If you want meaningful interpretation of them, you need to get ISTA/D (Rheingold).
I have no idea on Logging software.
      03-08-2016, 04:12 PM   #225
samy_1985
Drives: BMW 5 series F10
shawnsheridan solved the runtime 933 error...thank you
tool 32 solved an error... ' Pedestrian Protection system ' all I had to do is:
fs_lesen_funktional to read fault codes and then FS_LOESCHEN_FUNKTIONAL to delete errors.
      03-08-2016, 04:13 PM   #226
shawnsheridan
      03-10-2016, 01:02 PM   #227
vipjigga
Drives: 2012 328i
Help
Can you please pm the link to download tool32?
PM sent.
      03-10-2016, 06:58 PM   #228
shawnsheridan
PM sent.
      03-12-2016, 02:18 PM   #229
Mesaman
Drives: 2013 328xi
Can I please get the link to download tool32.exe
      03-12-2016, 02:31 PM   #230
shawnsheridan
PM sent.
      03-14-2016, 09:41 AM   #231
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Any chance of a link to download Rheingold / ISTA/D?
I'm on an F06, but already have an ENET cable.
It's driving me nuts trying to find the software!
      04-09-2016, 08:29 PM   #232
mlavio829
Drives: 2020 BMW 330i X Drive
Would i be able to get Tool32 as well please?
My check engine light won't go away after coding. I've tried Esys with no success.
      04-09-2016, 09:13 PM   #233
shawnsheridan
PM sent.
      04-22-2016, 06:12 PM   #234
ruycostajr
Drives: BMW M235i
Hi, can you please pm the link to download tool32 Ediabas ?
Regards
Ruy
      04-22-2016, 09:19 PM   #235
shawnsheridan
Regards
Ruy
PM senr.
      04-29-2016, 08:35 PM   #236
zerreissen
Drives: 2022 PB M240i
Howdy shawnsheridan
I'd like to be able to read fault codes/CEL's from my F30, this requires ITSA/D (Rheingold) / INPA? If so, do you have a link that you could share?
Thanks so much!
'22 M240i Portimao/Cognac
(Sold) '14 335i Estoril/BK • M Sport • Prem/Tech Pkg • M Perf INTR • VMR V710FF • Shifteck DP
(Sold) '95 M3 Avus/Dove • PSS9 • Vorschlag Camber Plates • 3.46 Torsen Diff • etc.
      04-30-2016, 10:25 AM   #237
shawnsheridan
Originally Posted by zerreissen View Post
Howdy shawnsheridan
Thanks so much!
If you want meaningful Diagnosis, as in to interpret fault Codes, then you need ISTA/D. I cannot help you with ISTA though.
If you just want to clear the fault codes, as most times they are not persistent and thus need no interpretation, then you need only E-Sys:
  1. Click "External Applications" in the left menu.
  2. Click "External Application"
  3. Double-click "Transmitter"
  4. Scroll to the bottom and click "14 FF FF FF,31 01 0F 06,31 01 40 00 00,31 01 40 00 05,31 01 40 00 01;Clear all DTCs (clear DTC,clear Infospeicher,ZFS – DM_Lock,clear ZFS – DM_Clear,ZFS – DM_Unlock)"
  5. Click Connect
  6. Click Send
      05-02-2016, 10:53 PM   #238
CoolFX
Drives: BMW X3 2.0D XDrive F25
Hello. I am trying to reset the frm of my f25 because after trying to change license plate light to a more powerful leds, the light stopped working. Now even with original leds I have no light on my plates. I read on this forum that the frm might closed the circuit and have to be reset. I have E-sys installed, can this be done with E-sys? If I need tool32 can you shawnsheridan give me the link for the latest version? Thanks. Regards.
      05-03-2016, 04:05 AM   #239
shawnsheridan
Did you VO Code FRM with E-Sys to reset it?
      05-03-2016, 05:01 AM   #240
CoolFX
No. I just installed E-sys and connected it to my f25 with enet cable. How can i reset the frm license plate error with E-sys? Can you give me some directions? I am new to bmw coding, don't understand much. Is it easier with Tool32?
      05-03-2016, 05:03 AM   #241
shawnsheridan
I don't know how to reset FRM with Tool32.
VO Code:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on FRM (the ECU itself not the underlying CAFD) => Select CODE (not Code FDL).
      05-03-2016, 08:15 AM   #242
CoolFX
Thanks Shawnsheridan, I will try that later. Hope I don't brick my car software. can you still send me the link for the latest tool32? I found a thread that teaches how to reset frm with that software. This way i could try it if with E-sys doesn't work. Thanks again for your help. I will post the outcome.
