06-30-2020, 03:35 AM | #1101 | |
Rep 1,010
You went from 8.8 to 7.6 just by using E35 and a tune with no other mods ?
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
06-30-2020, 05:45 AM | #1102 | |
Rep 106
I have costume tune. We did 10 versions of 93/98 octane. Timing and corrections was bad. After that we did ethanol map..I have got 10 versions and I think we are close to done. I sent in last log yesterday. With supra pump and 93/98 I did not gain anything..it was just the same as standard pump. Then I fitted hpfp and start E10..E15..E20. Around E20 I notice a lot more power..I have logg in 3d gear but now its to much torque. I logg only in 4th now. I remember OZBMR told me when reaching E30 the magic happens
M140 Sunset Orange 2018. M719 Jet Black. Maxton sideskirts and spoiler, Ksb front splitter, RK Tuning diffuser, TPI spacers, MHD Stage 2, Xhp stage 3 , Wagner 300 cell cat, MPE silencer , Quaife LSD.
Supra pump and OTS E30, Spool ethanol analyzer (E35) https://theone1973.imgbb.com/ |
IMS-340C394.50 |
06-30-2020, 06:05 AM | #1103 | |
Rep 1,010
Nice I will sure look into finding Ethanol here.
All pumps are HPFP including the Supra pump they just varies in pressure and flow so which HPFP are you using now I am confused ? Also most of us log in 4th gear anyway so no worries. Quote:
06-30-2020, 06:28 AM | #1104 | |
Rep 106
Dorsch is stage 1 and 2. I have seen one pics of flow but cant remember...
06-30-2020, 06:38 AM | #1105 |
Rep 1,010
I mean which pump are you using now with the E35 setup ?
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 06-30-2020 at 06:52 AM.. |
06-30-2020, 07:31 AM | #1106 |
Rep 106
I have the BMW / Supra pump 8631642.
IMS-340C394.50 |
06-30-2020, 05:09 PM | #1107 | |
Rep 458
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
07-01-2020, 03:47 PM | #1109 | |
Rep 452
https://datazap.me/u/aleksandersuave...og=0&data=3-22 |
07-01-2020, 04:18 PM | #1110 | |
Rep 242
07-01-2020, 04:44 PM | #1111 |
Rep 452
07-01-2020, 04:48 PM | #1112 |
Rep 242
07-01-2020, 04:54 PM | #1113 |
Rep 452
07-01-2020, 04:58 PM | #1114 |
Rep 242
Better bro we discuss this with other guys ,there is already few broken stock turbos with around 22psi boost.Im running around 24psi now with vt gc turbo on 100ron only and vargas told me its ok with around 32psi so have room for improvement ,E ,meth , etc...
07-01-2020, 05:11 PM | #1115 |
Rep 452
Yeah I thought I was ok as is it is on stock turbo. wasnt planning on pureturbos upgrade for a while.
07-01-2020, 06:25 PM | #1116 | |
Rep 585
Ignore the power and torque numbers in the attached Virtual Dyno chart, I haven't adjusted for ambient conditions, your specific weight etc, it's the delta that's important. E20'ish to E30'ish You may also want to try the non-HPFP MHD Stage 2 E30 map, less boost, but more timing you may get a similar result? You've bought the Stage 2 E30 maps so no harm in comparing. The dip at 2800 - 3400 RPM is due to the OTS map load targeting and limits. You should send your log to MHD for their info and they may tweak the OTS map for the next revision.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
07-01-2020, 07:45 PM | #1117 | |
Rep 452
I can top off and add more e85 and do one more run on this map then flash the stage 2 e30 map and log a run with that to compare. |
07-01-2020, 07:58 PM | #1118 | |
Rep 585
When the oil price is low ethanol content may drop towards the lower end of the allowable range so the gas station/fuel company makes more margin. Sounds like a plan, interested to see your results.
07-01-2020, 08:41 PM | #1119 | |
Rep 452
07-01-2020, 08:57 PM | #1120 | |
Rep 585
The only plugs I'd recommend are NGK 94201 SILZKGR8B8S. There's a good discussion here https://f30.bimmerpost.com/forums/sh....php?t=1682609 In the photos I posted there comparing the stock Champion to NGK you can see the insulator on the core of the NGK is thicker and more encompassing, which should make it a colder plug and make the fuel mix less susceptible to pre-ignition
07-01-2020, 09:31 PM | #1121 | |
Rep 452
https://datazap.me/u/aleksandersuave...og=0&data=3-22 added 2.89 gallons of e85 just now, its a full tank or I would have added more. flashed again then fresh 4th gear pull. Had to let off towards the end as I was getting close to my sub and cars were popping out. Thats a total of 5.64 gallons of e85 added today. Looks like the previous map limit didnt kick in until after 3000 RPM now. Looks like I'm still missing boost targets after 5000 rpm. will try flashing the stage 2 e30 map tomorrow and give it another run. I wonder if Stage 2+ is more optimized towards the Dorch/XDI fuel pump, rather than the Supra pump? |
07-01-2020, 10:48 PM | #1122 | |
Rep 585
Timing looks perfect, 14 degrees all cylinders by 5700 RPM and 15.5 by 6700 RPM. It's interesting to see how with increased ignition timing, from increased octane and ethanol cooling, the car needed less boost to hit the load target and made more torque. You have xHP stage 3 flashed? Torque limiters removed? To me looks like there's a torque/load limiter kicking in around 5000 RPM, your power peaks very early about 5000 RPM, should be about 5800 RPM and about 500 WHP. Between 3000 and 5000 RPM it's a rocket. Load/boost targets are just what the map asks for and isn't necessarily what the car will hit, especially up top the stock turbo is never going to hit 190+ load or 22 PSI, just runs out of puff. Edit: order a set of the 94201 NGK's as 26.5K miles on stock plugs is enough
