01-25-2022, 11:32 PM | #617 |
Rep 40,793
It is from DayvG. PM sent.
01-26-2022, 09:44 AM | #619 |
Rep 40,793
01-31-2022, 11:14 AM | #621 |
Rep 40,793
PM sent.
01-31-2022, 06:05 PM | #622 |
Rep 5
Unable to inject CAFD in HU
Hey all,
Lurker turned member here. I am having coding issues with my 2013 F30 where there is a missing CADF file for HU_Entry. I have tried to Inject the CADF through the Detect option as instructed by the other threads with no luck. The below errors keep reoccurring: extract from log file:.... [HU_ENTRY - 63 - cafd_000000f9-007_009_006] Transaction type: cdDeploy; Message: TA started [TRANSACTION] MCDDiagService<id=62649, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: negative response : requestOutOfRange, link=HU_ENTRY_63_ETHERNET> [DIAGSERVICE] [] job failed with negative response error: code: repeat job description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: HU_ENTRY_63_ETHERNET severity: ERROR [THROWABLE] [HU_ENTRY - 63 - cafd_000000f9-007_009_006] Transaction type: cdDeploy; Message: TA finished [TRANSACTION] [HU_ENTRY - 63] -MessageID is used multiple times, so MessageText may be ambiguous-job failed with negative response error: code: repeat job description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: HU_ENTRY_63_ETHERNET severity: ERROR [WARN] [HU_ENTRY - 63] - [Exception - HU_ENTRY - 63] job failed with negative response error: code: repeat job description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: HU_ENTRY_63_ETHERNET severity: ERROR [HU_ENTRY - 63] prepareECUforCoding started [PROGRESS] [HU_ENTRY - 63] prepareECUforCoding finished [PROGRESS] [HU_ENTRY - 63] authenticateECUforCoding started [PROGRESS] [HU_ENTRY - 63] authenticateECUforCoding finished [PROGRESS] [HU_ENTRY - 63 - cafd_000000f9-007_009_006] Transaction type: cdDeploy; Message: TA started [TRANSACTION] MCDDiagService<id=62649, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: negative response : requestOutOfRange, link=HU_ENTRY_63_ETHERNET> [DIAGSERVICE] [] job failed with negative response error: code: repeat job description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: HU_ENTRY_63_ETHERNET severity: ERROR [THROWABLE] [HU_ENTRY - 63 - cafd_000000f9-007_009_006] Transaction type: cdDeploy; Message: TA finished [TRANSACTION] [HU_ENTRY - 63] There was an error during TAL execution, please check the log files. [WARN] [HU_ENTRY - 63] - [Exception - HU_ENTRY - 63] job failed with negative response error: code: repeat job description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: HU_ENTRY_63_ETHERNET severity: ERROR [HU_ENTRY - 63] finalizeECUCoding started [PROGRESS] [HU_ENTRY - 63] finalizeECUCoding finished [PROGRESS] [] There was an error, please check the log files. [WARN] [] - [Exception - HU_ENTRY - 63] job failed with negative response error: code: repeat job description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: HU_ENTRY_63_ETHERNET severity: ERROR .... I am currently using E-Sys V3.30.1 with Launch Pro. On an older thread I read that only E-Sys V3.27.1 can be used to Inject CADF. Is this still true? Do I need to replace my V3.30.1 and install V3.27.1? Or am I missing something that is causing this error? Grateful for some help on this. |
01-31-2022, 06:24 PM | #623 | |
Rep 40,793
Is FA original unmodified FA when Injecting and Encoding?
01-31-2022, 06:38 PM | #624 |
Rep 5
Yes, the FA is original, there are no aftermarket devices installed, and the only FDL coding applied on the car now is Battery Class changed for current battery spec installed.
01-31-2022, 06:41 PM | #625 |
Rep 40,793
I have no idea on error then. If FA is original, there should be no error coding it. When all else fails, flash ECU.
01-31-2022, 06:51 PM | #626 |
Rep 5
I have never done a flash before, to be honest sounds a bit intimidating. But if that's the solution I will get to researching. Will I be able to flash only the HU ECU, and not all the ECUs as HU is the problem child here?
01-31-2022, 07:45 PM | #627 | |
Rep 5
While researching how to go about the Flash, I found one of your old post to check the FA if its unmodified. I expanded my FA and see that it references 6NL while a vin code check on bimmer work shows that the option for my car vin is 6NH Hands-free Facility W. Usb Interfac. Could this be causing the error when injecting the CAFD? If so how do I go about changing this? Your old post didn't go any further than advising to check the FA. |
02-01-2022, 05:19 AM | #628 | ||
Rep 40,793
Save FA, Edit FA, Change 6NL to 6NH, Save FA, load FA in Coding Module, Inject CAFD and VO Code Head Unit.
02-02-2022, 01:46 AM | #630 |
Rep 40,793
02-02-2022, 07:33 AM | #631 |
Rep 5
Thanks much Shawn. I was able to inject the CAFD after editing the FA. In case anyone is having the same issue and do not know how to edit the FA code, the link below detail with pictures how to edit the FA code before you inject the CAFD and VO code the HU ecu.
https://autosvs.com/help/how-to-chan...de-with-e-sys/ |
02-02-2022, 09:27 AM | #632 |
Rep 40,793
02-20-2022, 07:11 PM | #634 |
Rep 40,793
Your Receive PM function is disabled. PM me when working.
02-21-2022, 08:14 AM | #635 |
Rep 6
02-21-2022, 11:59 AM | #636 |
Rep 40,793
PM sent.
02-21-2022, 12:50 PM | #637 |
Rep 9
can I create an FSC code lifetime for a Mini F56, or is that only per year?
and what is the best way to do it, FSC code generator or with another program? |
02-21-2022, 12:54 PM | #638 |
Rep 40,793
Wrong thread and your Receive PM function is disabled. PM me when working.
