05-21-2023, 04:34 AM | #1 |
Rep 5
20x10 et35 f32
Hello, I have a question about this wheel size 20x10 et35 for the rear part. is it possible to ride on this size? I have xdrive with m suspension and i would like to ride 265/30/20 on it will there be a problem with the fender? Does anyone ride this size? Thanks for the reply
05-21-2023, 10:58 AM | #2 | |
Rep 1,386
I'm not running exactly what you mentioned.. but this is 20x10 ET 42 If I had to guess you'll clear the strut just fine as you'll be further away than mine (I just clear the strut and carpet lining). As for poke though I'm just outside of the fender, I'll try get you some more photos once I've cleaned the car For modelling try http://willtheyfit.com - my setup is 275/30/20 ET 42. Once I get you some close up photos it should give you an idea on how 35 will look.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
05-21-2023, 01:51 PM | #3 |
Rep 1,386
I run B16 coilovers, as you can see it's super close to the strut:
2015 435i - 401whp
05-22-2023, 08:19 AM | #4 |
Rep 3,191
ET35 is not ideal and you will probably rub the fender no matter what tire you have. Really needs to be max ET40.
alohasurftoad3127.50 LuxoM347.00 |
