BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ☛ MHD Flasher F Series (F2x F3x) discussion ☚
proTUNING Freaks
      08-16-2018, 10:11 PM   #2245
FastF30
FastF30's Avatar
405
Originally Posted by GatorF30 View Post
That's not how you log...
Yea... I know... but I had to post something.... just had too.. lol..
      08-17-2018, 11:41 AM   #2246
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
Originally Posted by jgoens View Post
I may do it tomorrow or Saturday. How long did the flash take?
Originally Posted by FastF30 View Post
44 minutes..... and yes you do need the charger...
Should only take 22-25 mins when doing the flash for the very first time...
Trust me I've completely removed the flash and re-flashed at least 5 times due to taking the car into the dealership for warranty claims (non-tune related).
Also, i never used any battery chargers, although i will recommend it if your car is higher mileage. My 435i is only 4 years old so the battery is pretty fresh!!!
Just installed DP, CP and FMIC!! WOW the car is a BEAST with the Stage 2+ flash on 93oct!!!!! Very eager to throw in 2-3 gallons of E85 but worried to max/crap out the HPFP!! Hoping MHD releases a similar option as they did with the N54 tunes to measure octane!!!
jgoens3651.00
      08-17-2018, 12:26 PM   #2247
FastF30
FastF30's Avatar
405
Well lucky you .... timer said 44 minutes and yes it was 44 minutes for my car...used a samsung S7... I do have to remove it cause I'm taking it in for something else and hope it is quicker next time I re-flash...
How long did it take to flash back to stock completely?
      08-17-2018, 01:06 PM   #2248
Munchi435i
Munchi435i's Avatar
Takes the same amount of time when completely removing and flashing, maybe your cable is faulty
I use a Samsung Note 4 to flash
If your using the Bimmergeek cable like i do, make sure the toggle is all the way to the right, aside from that im really not sure why its taking so long to do the initial flash for you, BUT so long as it works
      08-17-2018, 02:01 PM   #2249
Jimi1121
Drives: 2014 F30 M-Sport
To flash back to stock, mine also takes around 45 mins.
      08-17-2018, 02:31 PM   #2250
ChrisFulton
Drives: m235i
There was an update to the app today.
      08-17-2018, 03:00 PM   #2251
Munchi435i
Munchi435i's Avatar
What cable are you using?
That is a very long time......
      08-17-2018, 03:04 PM   #2252
ChrisFulton
Drives: m235i
Agree . . . mine takes 22-23 minutes.
      08-17-2018, 04:07 PM   #2253
Major_Sarcasm
Major_Sarcasm's Avatar
Drives: 2011 LCI E82 135i
Bimmercable?
Mine took 44 mins via the cable I have (BMCables.com) - works perfectly, just takes that long.
Steve
/// 2011 LCI E82 135i
      08-17-2018, 04:41 PM   #2254
louielouie
Drives: '15 435i | '16 M4
I have seen people on the WhatsApp group encounter issues when flashing w/o charger. Better safe than sorry.
+1 for Bimmergeeks cable
I flashed in 22 min
      08-17-2018, 06:29 PM   #2255
ChrisFulton
Drives: m235i
Originally Posted by Major_Sarcasm View Post
Bimmercable?
Bought the Bimmer Geeks cable when I bought the flash tune.
I was skeptical that the cable would make that much of a difference; but maybe it does.
      08-17-2018, 06:39 PM   #2256
Munchi435i
Munchi435i's Avatar
Bimmercable?
https://www.bimmergeeks.net/product-...eeks-pro-cable
This is the cable we are speaking about. MHD has said in the beginning that other Dcan cables will result in slower flashing, might have to search back in this thread for the information.
      08-17-2018, 07:10 PM   #2257
jgoens
jgoens's Avatar
3651
Drives: 2013 335i msport
Went to flash...bought a new battery charger and followed the PDF manual..shut everything off, sat in car etc. Phone said "waiting for last process to finish"...so, I waited and waited hoping I would be the lucky guy and it would be 22 min. Then, kept waiting and figured I would be another 44 min guy. Then, when that point passed, I thought probably something is not right.
Right when I hit flash got dongs and bunch of errors. Figured that was normal. Once I hit an hour, I knew something was wrong. Checked the battery charger and it was showing less than 25% and it was off on an overheat error.
Thought, fuck, this is probably going to be an expensive tune. Car would not start, yet there was power, however trunk would not open. Left charger on but battery would not charge over 40%. So, at 40% I went for flash to OEM option. Got a bar showing time left and it did flash that. Car started up.
A few months ago I had checked codes with ISTA and one was battery is worn replace soon. Car cranks immediately and I have a voltage meter hooked up in the trunk as well as the battery is 5 1/2 years old. This is why I went and bought a decent charger today before going for the flash.
I'm thinking there is some kind of defect in the battery that cut the charger and voltage dropped too low not allowing the flash to really even start.
I am going to get a new battery tomorrow as I am due anyway. Had some codes when I started and cleared with JB4, but then driving got a DT malfunction--which I am thinking is due to battery issues.
So, fun times.
Last car: 2011 335i Msport. JB4. Vrsf CP
      08-17-2018, 07:40 PM   #2258
Munchi435i
Munchi435i's Avatar
So, fun times.
Do you still have the JB4 installed while flashing?
Not sure but you might have to remove that first....need someone to chime in with more insight regarding JB4
      08-17-2018, 08:04 PM   #2259
jgoens
jgoens's Avatar
3651
Yes. I set it to map 0 and unplugged the OBD connection. My plan was to flash and then drive it to see how ran. When you do a back-end flash the Jb4 is connected.
Once flashed the issue would be the JB4 would control boost, so my plan was to remove that tomorrow. My thinking is, is that for today I would have had MHD controlling timing and tranny with burbles and JB4 running boost. O don't think that is the issue because the phone appeared to lock up almost instantly. I never got to a progression bar and my battery was pretty low during the process.
      08-17-2018, 08:29 PM   #2260
FastF30
FastF30's Avatar
405
I bought the Burger Motor Sport one off of Amazon Prime $27 (really wasn't the money but next day delivery is oh so tempting)... well we'll find out about difference of cables since I just purchased BimmerGeek...
p.s. when I first hooked up my charger... it said 65% ... normal good battery is 75% .... the battery is original so will be 4 years old December...typical battery life is 3-4years... just gonna get a new one...
      08-18-2018, 06:13 AM   #2261
Major_Sarcasm
Me too. Too many people testifying otherwise though.
I was familiar with the cable, just that I already had the other cable that worked fine (just takes twice as long). However, I have been convinced! Bimmergeeks cable ordered this morning.
Steve
      08-18-2018, 03:33 PM   #2262
jgoens
jgoens's Avatar
3651
Replaced my battery this morning and also was able to flash MHD...took a couple tries. I hooked up my new battery charger just because I had it and the first time I went to flash I got an error. Seems like the charger went off as the battery was charged and that caused the flash to fail. So, once again had to flash back to stock which took 26 minutes.
The flash to stage 2, 91 took 3 minutes. Then I realized that the burble setting had to be changed before the flash. So, set those tabs up and flashed again. I left the JB4 on, map 1 and took it for a quick drive. Car ran fast. But the burbles with my DP were shockingly loud--so, I had to turn those down and re-flash.
I also did a drive with the JB4 on map 0 (disabled) and I am not sure, but it seemed to run a little more aggressive with the JB4 on. I did purchase the log monitor so I will have to check that out later.
One thing I notice is that the car idles slightly rougher for the first 10 seconds on startup.
      08-19-2018, 06:57 PM   #2263
Mountain_Commando
Mountain_Commando's Avatar
Australia
295
Drives: 435i Gran Coupe M-Sport
Did you try enabling the cold start delete? With that, the idle are smooth as butter.
435i Gran Coupe | ///M Sport Pkg | 430hp | MHD Stage 2+ | BMS Intake | Catless Downpipe | FMIC | Black Sapphire exterior | 9H Ceramic Coating | Black Anthracite interior | 19" Black ///M Wheels | Red ///M Brake Calipers | ///M Steering wheel | ///M Metal Pedals | Alcantara dash panel | Carbon Fiber trims and gear knob | Angel Eyes LEDs | Surround Cameras | Spoiler | Coded ///M iDrive, Mirrors, HUD |
      08-19-2018, 06:59 PM   #2264
Mountain_Commando
Australia
295
Do you recall what was updated? I have an iphone so I'm too lazy to check myself
      08-20-2018, 06:27 AM   #2265
Jimi1121
Does anyone experience ruff cold start ups ? Car starts fine, but almost sounds like its misfiring on cold start up.
      08-20-2018, 06:35 AM   #2266
Jimi1121
WHAT'S NEW
0.995
- added support for Precision Racewerks coils kit.
- added M2 e20 maps.
- added support for N13 engine (stage 0 and custom maps. Stage 1 & 2 will follow).
- fixed open VMAX on car with driver's package.
- fixed license store always requiring a connection to the car.
flash, mhd, tune
