08-31-2018, 04:42 AM | #68 | |
Rep 3,967
I would get it inspected now it's failed an emissions test to see if the DPF is modified/removed etc. If it is reject it before the 30 days is up. |
08-31-2018, 04:44 AM | #69 |
Barge driver
8618
Rep 12,401
Come on name and shame them OP get on to the finance company and tell them the car isn't fit for purpose or road legal and they asset they have funded isn't as described.
730d/Z4C
DarrenL_007208.50 |
08-31-2018, 04:47 AM | #70 |
yes....spelt with J's
55
Rep 963
Any garage worth their salt would be able to tell if your DPF is hollowed in minutes.
Pulling one of the sensor pipes from under the car and throwing in a scope or heck, even a fine screwdriver That is a priority now as that is a key part to your legal stance Do it today! J |
JustChris17426.00 |
08-31-2018, 05:10 AM | #71 | |||
Rep 2,152
also just because its had a DPF gut doesnt make it a lemon! Quote:
as been mentioned. get the garage to drop the sensor and inspect the DPF. if its been gutted you have 2 options 1) go back to the dealer explain that you are rejecting the car as it was explained that it was DPF deleted with means the car is not road worthy and that it would of had a Remap applied to code out the DPF. or 2) if you really like the car. get them to supply and a new DPF (Expensive and wont be covered by your warranty) and then they will need to flash the car back to stock. again i will say it again just because it has a DPF delete and Map doesnt make it a lemon but at the end of the day its what you want. either way if it was me that dealer needs to replace DPF and remap the car again
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
jinjur55.00 |
08-31-2018, 05:16 AM | #72 |
55
Rep 963
I didn't implicitly say his car was a lemon btw
My biggest point is the dealers magic soot test that was fine. When it obviously isn't And if it is as bad as the OP says re:smoke output.........the dealer knows. Of course they do. It would be naive to think not. This is all just IMO op but i think a fair few of us are getting a bad feeling from this, that is what we are getting at. |
Smee505.00 |
08-31-2018, 06:00 AM | #73 |
Rep 8,617
I wouldn't want to touch that car with a bargepole.
Dealer is being a cock. You have rights, reject it, stuff the crappy warranty these places put on cars. |
08-31-2018, 06:18 AM | #74 |
Rep 1,449
No warranty covers pre-existing faults, even less so removed components
Get it rejected today. You will have a world of pain with this car, get out while you can and buy a decent unmolested example, as has already been said, there are plenty out there |
08-31-2018, 06:21 AM | #75 |
55
Rep 963
Yep ^
And we know rejecting it will be super duper sucky..........especially if you really love the car and it's spec But that love will soon fade if (perhaps, when) other issues arise |
08-31-2018, 06:55 AM | #76 | |
Rep 782
Drives: 2018 F80 M3 CP YMB
To be fair to the dealer he can't necessarily have known that he was sold a dodgy car and strictly he should be given one chance to fix it... Though given the cost which I assume would be over £1000 I would think he'd be better to take it back and see if can find someone else to sell it to who doesn't know of this forum if he is as dodgy as he is sounding... Really hope you do get to a speedy resolution - I would think once he realises that you aren't going to let the matter drop he'll cut his losses and take the car back... Return it to him now with the full support of the finance company - why should you be running around trying to diagnose the fault - that's his problem... Also list off all the other issues so he knows he's got a mountain to climb to keep you happy - should help him to make his mind up to accept your rejection... |
08-31-2018, 09:15 AM | #77 |
Rep 389
OP, it's beyond any reasonable doubt that the car isn't as described and the MOT results by the dealer don't match the same emissions test carried out a few weeks later.
The one thing I would say about this forum is that it has a wealth of knowledge and experience with BMW; technical, legal and commercial. You need to listen to the guys on here mate and reject the car.
X5 40d M F15 - July 2018 - Space Grey
Mini JCW F56 - June 2018 - Rebel Green Previous: 340i M F31 2016-18, 2015-16 435i M F32, 2013-15 330d M F30, 2011-13 Mercedes C250, 2008-11 320i E92 |
08-31-2018, 10:46 AM | #78 |
Rep 2,152
so whats the latest i am intrigued and want to see how this pans out!! updates updates and more updates
08-31-2018, 11:31 AM | #80 |
Rep 1,846
You need to get ista connected up, it'll tell you when it last regenerated it should be every 300-600 miles, if it's more than this either it's been coded out or egt sensors or pressure are knackered causing it to be smoke hence clogged dpf, black smoke and no regens as ecu will not initiate a regen.
08-31-2018, 04:03 PM | #81 |
Rep 48
Thanks everyone for the responses!
So the latest is, that messages have been exchanged with the dealer. I mentioned that the difference in emission values from the test he had done to what I had done was a 365% increase so it was a huge difference. I have the car booked in with an ex bmw service engineer on the 5th and he's fitted many acs springs to 335d xdrives. He knew exactly what I was talking about in regards to possibly having a remap and or dpf internals removed. He also said he can check the pressures of the dpf via diagnostics using a laptop and determine whether the dpf internals have been removed and whether the coding has been altered to stop the engine light coming on etc. So no removing of the sensor for a borescope is necessary, which is good. Plus he could look at the car quicker than my local bmw dealer so I was pleased about that. So I told the dealer that I'll let him know the outcome and if its bad then that will be the decider as to whether I reject the car since I'm well within my consumer rights to do so, especially if I've been sold an illegal car. He just replied with please free to do the inspection and that he hasn't sold an illegal car. I haven't responded to that since I'll see what happens on Wednesday. The car is a really nice spec though but I don't know the history even though the dealer said he knows the car after selling it before. I've informed the finance company of the fail and of the inspection on Wednesday. I said I'll keep them updated once I know the outcome. They just said thanks for letting them know and they'll do what they can to help. I thought about recording conversations, but our exchanges have been via email today which is preferable to have them as proof. The dealership is apex performance cars in Huddersfield. They also have a much larger site called shaks specialist cars. Thanks, Connor. |
08-31-2018, 04:20 PM | #82 |
Rep 3,967
Thanks for keeping us all updated.
My own opinion here is if it is just a blocked DPF that needs replacing and the dealer says he'll get a new DPF fitted if you really like the car give him 1 chance to get the car put right. If as we suspect though it's been tampered with and mapped out I would just reject the car as sold not road legal. |
08-31-2018, 04:20 PM | #83 |
Rep 1,449
Connor, please tell us you'll do everything you can to reject this car.
An independent dealer in West Yorkshire is probably the worst place you could go to get an honest car. Get a refund and maybe spend a little more at a BMW dealer and you'll be able to enjoy the proper experience that a BMW should bring Don't be fobbed off. They haven't got a leg to stand on. |
JustChris17426.00 |
08-31-2018, 05:29 PM | #85 |
Rep 269
Drives: F30 335d M Performance
is this the car still being advertised on their site?
He's either still got it up to attract customers or re-advertised because he's expecting it to be returned. Ready for the next unsuspecting customer. They could genuinely have known nothing about it.... If it has had the dpf gutted that is. I guess the inspection will give you the answers. Lovely looking car with a great spec too!
Current. 2016 335D STORM TROOPER!
2011 E70 X5 40D. 2005 E60 535D 395bhp 580lb/ft (Noteworthy) Evo V & VI. Jaguar s-type R. Yamaha raptor 700R |
08-31-2018, 06:20 PM | #86 |
Jeff
318
Rep 1,451
They have got some great looking cars in there and the main site has even better ones. I feel sure that you will get sorted out and an amicable outcome, one way or another.
08-31-2018, 06:53 PM | #87 | |
Rep 48
Steveo.G96.00 |
