BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Wireless phone charging
      09-20-2018, 09:28 AM   #1
cheesetoastie
Drives: F30 335D
Has anyone put a charger pad in their f30
      09-20-2018, 09:38 AM   #2
Rich9600
Rich9600's Avatar
Drives: i4 M50
Yes.
CHOETECH 3 Coils Fast Wireless Charger 7.5W Charging for iPhone X/iPhone 8/8 Plus,10W Fast Charger for Galaxy S9/S9 Plus/S8/S8 Plus, Note 8, Note 5, S6 Edge+/S6/S6 Edge/S7 Edge and Other Qi Phones https://www.amazon.co.uk/dp/B07C7SDH..._Oc7OBb0DYM50A
Velcro taped in to the pen tray in front of the cup holders.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31)
      09-20-2018, 09:43 AM   #3
Kendo67
Kendo67's Avatar
Scotland
1099
Drives: Me - 440i , Dog - Cayenne
Sounds interesting , any pics of the charger fitted ?
Kenny
      09-20-2018, 09:49 AM   #4
Hugrov
Drives: F36 LCI
Yes, I fitted a 3-Coil QI charger under the pad in the centre console, works very well.
      09-20-2018, 09:50 AM   #5
Rich9600
Rich9600's Avatar
Drives: i4 M50
Kenny
Not the best pics. But, you get the idea.
Velcro tape used to secure and it's thickness brought it level. Wire runs underneath as there is a green charging light on the other side. I didn't want to see this when driving.
      12-29-2018, 12:40 AM   #6
Lincoln61
Lincoln61's Avatar
Drives: 2018 430d Msport+
May be a silly question, but can you leave one of these plugged in without draining the battery. I was thinking of just leaving one plugged into the armrest usb.
      12-29-2018, 01:40 AM   #7
Rich9600
Rich9600's Avatar
Drives: i4 M50
No battery drain issues. The 12V cigar lighters go off after a while anyway. If you hard wire a DIY solution it will depend on the circuit you use as to it staying on.
It uses about 10W, so not huge power when charging. Much less when idle.
      12-30-2018, 06:32 PM   #8
C320
C320's Avatar
Drives: 911 Turbo S, X5 40i, XC90 T5
I just ordered one of these: https://www.ebay.co.uk/itm/Console-S...0AAOSw0rdcBPri
I thought it looked pretty neat / OEM and didn’t want to hack around with splicing wires etc. Will post an update once it arrives from the Far East.
      12-31-2018, 03:40 AM   #9
jbeer
jbeer's Avatar
Drives: 320i M Sport Shadow Edition
Does this not mean that the tray sits up or is uneven if that makes sense?
Also where did you wire it in to?
Current: F30 2018 320i M Sport Shadow Edition
Accessories: BMW OEM Roof Bars & Bike Carriers, Dashcam - Blackvue 590W-2CH
      12-31-2018, 04:55 AM   #10
C320
C320's Avatar
Looking at his images it looks like the charging pad is actually on top of the rubber pad. Can't see why you couldn't mount it under the rubber and then space out the gap with plastic / card to keep it all level?
I'd suggest the best place to hardwire that one would be from the rear 12v socket.
      12-31-2018, 05:07 AM   #11
jbeer
jbeer's Avatar
If you look at his first image it is under the mat for the centre console
      12-31-2018, 05:22 AM   #12
C320
C320's Avatar
True, but I was looking at the second image which threw me. Let's see what Hugrov comes back with.
jbeer154.50
      12-31-2018, 05:33 AM   #13
Lincoln61
Lincoln61's Avatar
Its quick and dirty, only involves velcro tape but it works.
      01-01-2019, 08:23 AM   #14
greatbm
greatbm's Avatar
Drives: G15 840i Coupe
[ATTACH]Name:  O521XtiISLqiUEkiFFF5vw_thumb_73e.jpg
Size:  166.6 KB[/ATTACH]
Fitted the 3 coil version which sits under the original BMW insert wired to the rear power socket. Snug fit for a iphone XS with no sliding around. Unit has a LED which can still be seen if you look down side of insert but the unit also emits a beep when the phone is placed on the pad. Only problem I have is remembering the phone when i get out of car. Phone charges no problem although through original BMW insert, rubber pad of unit and iphone case.
G15, 840i M Sport
C320342.50
      01-19-2019, 09:21 AM   #15
C320
C320's Avatar
So, this unit finally arrived from Southern China and I had a slight delay installing this due to an issue with an incorrect cable (I suspect due to our car being an LCI model).
The seller promptly shipped the correct cable and it's now all installed. It took just under 20 minutes to fit, there are three T20 screws to remove and a bit of trim removal from around the centre console. I'm really happy with the installation and it looks OEM, I highly recommend this product and this particular eBay seller.
If you do intend to order it may be worth checking whether your 12v socket has a 2 or 3 pin connector, so that you can let the seller know when you place your order.
Looks really high quality an OEM, a direct replacement for the rubber pad in the centre console:
The rubber pad is removable for cleaning etc, LED light shows power (white) and charging (blue):
End result, the sliding cover still works fine too:
      01-19-2019, 09:36 AM   #16
Pequin
Pequin's Avatar
Drives: Enthusiastically
Mine came with one
      01-19-2019, 12:50 PM   #17
aquazi
Drives: 18 M4C
Thats really smart and in a better position that the oem one where you uave to keep lifting the armrest... and then forgetting about your phone and having to go get it again
      01-19-2019, 01:04 PM   #18
C320
C320's Avatar
Thanks, completely agree that it's a much better location. I did initially look at trying to retrofit the OEM solution but as you say it's not the best place for a phone. We also have an F15 X5 and a G12 7 within the extended family ad whenever I drive those I often forget to take my phone at the end of a journey!
Not sure if a larger phone would fit properly but it works fine with the iPhone 8 & iPhone X.
      01-20-2019, 03:38 AM   #19
Hugrov
Drives: F36 LCI
Apologies for the delay in replying. The 3-Coil unit sits under the original tray and is powered from the wiring for the 12v outlet for the rear passengers. It can also be run from the wiring from the 12v outlet under the glove box (tap off the wiring on the back of the outlet so it still leaves the socket free for a dash cam etc). The pad you see on top of the original tray is just a thin rubber mat that comes with the device to stop your phone moving around, it just sticks in position. The other charging pad that goes in front of the cup holders is a neat solution but probably won't work for my Galaxy S8 Plus as the phone is too wide.
      01-20-2019, 09:41 AM   #20
C320
C320's Avatar
Thanks, so I guess it would have worked if you didn’t fit the other pad that they provided. The BMW rubber liner is pretty much anti-slip too?
I thunk an iPhone X is pretty much the largest practical to fit on the unit I have. I’ll see if I can get my hands on any larger phones. I would assume that they would still charge it’s just a question of how much they may overhang.
      01-20-2019, 09:54 AM   #21
Hugrov
Drives: F36 LCI
Yeah it would definitely work, I just fitted the extra rubber pad but it's not necessary, the Galaxy S8 Plus sits snuggly in the tray. The front cubby charger is a good solution but I've had my phone there before and it ended up just sliding out under acceleration onto the cup holder cover as it overhangs by a fair bit, it won't sit flat.
C320342.50
