BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 335 exhaust on my 328i
      01-06-2019, 01:45 PM   #1
6629matt
Drives: 2015 bmw 328i msport
Hi everyone. I have never posted before but wanted to share a few things I discovered this weekend while putting an axle back 2015 335 exhaust on my 2015 328i. I read everything I could find on this forum before I did the modification and it was extremely helpful. there were a couple of surprises however and I wanted to share them with anyone considering doing the same thing. I love the way it turned out and am very happy I decided to do it. I bought a used 2015 335 axle back on Ebay for $195.00 including shipping. A diffuser on Ebay for $117.00 including shipping and a stainless clamp on Ebay for $7.99. I rented an exhaust kit which contained a cutter and some expansion tools from Autozone for free. I had the old exhaust and diffuser off in about a half hour and that part was very easy. I decided to unbolt the hangers and transfer them to the 335 exhaust. the 335 exhaust was not as long as the old 328 exhaust so the studs went into the rubber mounts about 3/4 of the way, which seems plenty good. I will try to attach pictures. the problem was that the pipe coming out of the muffler and the exhaust pipe (midpipe?) were at totally different angles so there was no way I would get the clamp to work. I am lucky to have a small shop near me that does custom exhausts and could weld stainless. I drove the car to them with the exhaust installed but the pipes not connected. The guy[IMG]undefined[/IMG] quoted me $60.00 to make the connecting pipe and weld it. I was so happy he did it for me on a Saturday with no notice that I slipped him a hundred cash. I did have to buy a 3" dia 18"l. piece of stainless exhaust pipe from Autozone for him to use though. that cost $27.99. The exhaust tips were another small issue. it seemed that I could either have them centered in the cutouts or the same poke, but not both. I chose centered since I am going to put some aftermarket carbon fiber tips on anyway and will adjust it then. in the meantime I just popped the OEM chrome tip on the left out a little bit and it looks fine. I hope this helps someone.
anotheran389.00
rjd_F301999.50
N26Ghost496.50
dr3amer45.00
      01-09-2019, 04:33 AM   #2
kobluna
Drives: 320i
I'm going to do the same but I have sport line 320i. That means that I have only one exhaust tip on the left and I don't have removable diffuser. Could you measure the distance between left parking sensor and left exhaust tip? See the picture. Please do at least x measurement and maybe z as well, just to make sure. Or if you come up with another easily measureable distance it's fine as well.
If that distance is close enough to my current left tip then I only need to make one more cut to right hand side of the bumper. Otherwise I need to buy a whole new bumper which means that it's not worth it.
      01-09-2019, 05:09 AM   #3
6629matt
measure
Sure. I'm at the gym this morning, but when I get home I'll take some measurements for you.
      01-09-2019, 07:05 AM   #4
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
I have no interest in doing this conversion, but this would be a helpful thread if I was. Good write up
      01-09-2019, 07:57 AM   #5
6629matt
measurements
I measured the z dimension from center of the sensor to center of the tip is 11". I also measured center of left tip to center of right tip, which is about 32-1/2". the tips are equidistant from the center of the car. I hope that helps.
      01-09-2019, 08:12 AM   #6
CandyRedRC46
CandyRedRC46's Avatar
242
Drives: 2013 328i
Looks great from the back, but I would be concerned about the exhaust hanger not being fully inserted.
      01-09-2019, 08:29 AM   #7
6629matt
hangers
I agree, that was also a concern of mine. the exhaust specialist who welded my pipes said it was fine though. It is about 3/4 of the way in both rubber grommets, so even if it shifted all of the way to one side it would still be firmly in the other. I do plan on inspecting it regularly though.
      01-09-2019, 08:32 AM   #8
6629matt
thread
Thanks. Several other posters of the same mod did a much better job describing all the steps, tools, etc so I just wanted to add some of my observations and discoveries along the way that I didnt think were discussed much in their posts. Overall I am very happy with the way it looks and sounds.
rjd_F301999.50
      01-11-2019, 12:07 AM   #9
kobluna
Drives: 320i
Thanks Unfortunately the z dimension for me is 13" so I need to figure out something else than stock 335i muffler.
      01-11-2019, 11:14 AM   #10
6629matt
z dimension
I was wondering if your sensors might be located differently since it is a different bumper type. That's why I gave you the equidustant center to center dimension. so if your cutout was centered at 16-1/4" from the center of the bumper...
      01-16-2019, 12:11 AM   #11
kobluna
Drives: 320i
Yep, thanks again. If I measured it correctly my center to center dimension would be 37½" so few inches more. And indeed, if I look the pictures of 335i the tips seems to be more centered than my single tip.
Maybe I can get muffler shop to cut other outlet pipe from muffler and get an extension piece. Muffler shop needs to modify the mounting points as well so then the whole muffler would be slightly off centered but that is not visible outside of the car. Or just cut both outlets and not modify mounting points, which ever is easier. Might still be cheaper than getting a new bumper.
      01-16-2019, 12:30 AM   #12
N26Ghost
N26Ghost's Avatar
Drives: 2014 BMW 328i M Sport
Great write up! I did the same and never looked back. Currently have the 335i muffler and M Sport diffuser, but I still have an itch to go MPE...we shall see how long it lasts, lol.
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
      01-30-2019, 09:08 AM   #13
Fronttwelv
Fronttwelv's Avatar
Drives: 14 328i xdrive msport
Just gut the 335 muffler.
Present: 2014 f30 328xi MSport, 1992 VW GTi VR6 swapped
Past: 2010 335i 6 speed; 2008 VW GTi stage 2, 2004 Subie WRX FBO, 2003 20th Anny VW GTi FBO
N26Ghost496.50
      01-30-2019, 09:32 AM   #14
Littlebear
Drives: ...the Mods crazy.
For the 'left' or US driver's side muffler mount, there are two mount plates available. I think if you use the alternate plate & rod (left one in pic), the rubber hanger might go on all the way. It might also affect the side to side tip position, though....
Murf
      02-01-2019, 05:09 PM   #15
lfepro.g
Drives: 428i
If anyone is interested in doing this, I'm putting up my 435 muffler with diffuser for sale ! Just bought a Borla Catback so I have no use for it!
BMW F32 428i BSM | KW V2 Coilovers | VRSF Catlesss Downpipe | Evolution Racewerks Chargepipe | Bootmod3 Stage 1 | Custom Borla Atak Exhaust w/ Quadtips
      02-03-2019, 09:26 AM   #16
757seaman
757seaman's Avatar
Drives: 14’ 428i coupe
Interested in doing this to my 428i. Haven't done any extensive research but a couple questions are will it possibly throw any CEL's? Does it sound any different
      02-03-2019, 09:32 AM   #17
6629matt
No CEL and it sounds slightly deeper and louder, but hardly noticable. I couldn't be more happier. I would line up a local stainless welder though. You can hook it all up and drive it there loose if it's not far or just have them do it.
      02-11-2019, 04:44 PM   #18
N26Ghost
N26Ghost's Avatar
Seriously considering this...
Though the sound is better than my stock 328i muffler...it still isn't what I wanted it to be. I'd like the true dual personality difference. Comfort/Eco Pro to be hushed and Sport to be angry and burbly.
I've watched a few vids of people doing this mod and will be reaching out to my local shop to get a quote on what they'd charge to do the work.
