01-07-2019, 09:50 AM | #1 |
Rep 361
328 xdrive springs
All,
This forum space is filled with garbage spring request threads. I'll try and not do this. I just would like to know if anyone has fit a RWD spring set to the AWD platform? The Eibach, HR, ACS and Dinan XDrive springs are nice and all, but i want my fender closer to the tire. Coilovers are the answer I know, but i would never adjust them and I live in the salty winters where the coilovers are junk after a few seasons. I'll be doing shocks as well. Also can we get our members to post JUST side view of their car and what springs; taken at around Wheel level so we can see the actual drop? Taking pics too high up is tough to judge the wheel gap. Thanks f30post
Present: 2014 f30 328xi MSport, 1992 VW GTi VR6 swapped
Past: 2010 335i 6 speed; 2008 VW GTi stage 2, 2004 Subie WRX FBO, 2003 20th Anny VW GTi FBO |
01-11-2019, 08:53 AM | #2 |
Rep 10,256
Well - a few more thoughts why coilovers are still a better solution.
Coilovers made from stainless steel will withstand winter + salt driving conditions. Good coilovers are specifically engineered to deal with all annual season changes. The biggest advantage of coilovers: after installation - having the flexibility to precisely adjust the suspension (height, compression, rebound) and fender gap to your preferences. Then - usually no adjustments are needed. Unless of course your preferences change. The biggest disadvantage of usually stiffer / lowering springs + stock shocks: no suspension adjustment opportunities, no control over how springs and shocks will settle, softer shock typically have trouble stopping spring oscillations resulting in a bouncing effect, and duplicate labor charges when replacing springs-only solution with something better. |
Fronttwelv148.00 |
01-11-2019, 09:53 AM | #3 | ||
Rep 361
I think i have it narrowed down to H&R Sports for x-drive or ACS/Dinan for RWD applications. I would really like to hear from other members on how the fitment is on the RWD ACS or Dinan springs on an x-drive car. thanks for the response cfm56d7b
01-11-2019, 11:27 AM | #4 | |||
Rep 10,256
Stock, softer shocks with lowering, stiffer springs is the least attractive combination. Selecting different shocks together with new springs is a better option. Good luck! |
Fronttwelv148.00 |
01-11-2019, 05:22 PM | #5 |
Rep 5
I'm in the same situation as you, trying to get my 328i xDrive decently low without investing in a set of coilovers. I ended up ordering a set of Eibach Sportlines (E20-20-031-02-22, 320i xDrive fitment according to Eibach's website). I should be getting them installed within the next couple of weeks, depending on how fast Turner's shipping is.
Here's how they look on someone else's 328i xDrive on 19" Apex EC-7s: |
01-11-2019, 07:52 PM | #6 |
Rep 361
Not bad. The rear looks too low though. I really can't have reverse take at all.
01-13-2019, 08:27 AM | #7 |
Rep 122
Fronttwelv148.00 |
01-14-2019, 09:57 AM | #8 | |
Rep 361
Can we confirm the Eibach ProKit RWD springs will directly fit into the XDrive application?
01-25-2019, 10:37 AM | #9 | |
Rep 122
