11-21-2019, 03:27 PM | #1 |
Rep 190,777
Active Autowerke N55 Catted Downpipe No CEL Guarantee!
ACTIVE AUTOWERKE BMW N55 DOWNPIPE BMW introduced a new valvetronic, single turbo version of its direct-injection engine for the F-Chassis models beginning in 2012. The Active Autowerke N55 downpipe for the M235i, 335i, 435i and M2 helps unleash some of the potential that is restricted by the OEM downpipe. Turbochargers are powered by spent exhaust gases created during the combustion process. The quicker these gases are evacuated, the better. Unfortunately, the factory down pipe in the N55 is quite restrictive, which results in slower exhaust gases and slower turbo spool. The Active Autowerke F-Chassis N55 Signature down pipe utilizes 3.5” diameter stainless steel piping in order to provide more power, quicker spool, and extreme durability. This variant includes a 49-state legal EPA approved 4.5" high flow GESI catalytic converter that will NOT produce a CEL! EPA N/GBL/4389/1119 FEATURES:
The speed of a turbo’s impeller wheel is limited by exhaust back pressure. A larger down pipe relieves some of this pressure, resulting in quicker and more efficient spool. With Active Autowerke’s Signature downpipe, your N55 can rev quicker, and deliver more horsepower and torque. Minimizing back pressure while remaining daily drive-ability was the goal of our N55 downpipe. Owners can now upgrade to a product that is affordable, reliable, and easy to install. After months of research and development, our engineers settled on a 3.5” diameter pipe which utilizes the least number of bends possible. However, the Signature N55 down pipe still fits easily into the OEM location, with a painless installation process. Constructed entirely from 304 stainless steel with 1.5MM wall thickness, we are confident that you’ll be pleased with how robust and durable this down pipe is. Trouble-free installation and a long lifespan ensure that you’ll enjoy many miles of performance with your N55!
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 01-02-2020 at 05:43 PM.. |
11-22-2019, 01:18 AM | #4 |
Rep 7,606
Similar to question above, is this available for EWG with 4'' turbo outlet? OP doesn't specify.
Also, pricing and when will it be available? I am planning to buy a downpipe soon... like within the next week. I have been debating between CG and Fabspeed, but would consider this option as well. Would also like to know the cells per square inch answer, and see a picture of inside (the cat). I imagine it might be something like 400, or very expensive, if it is EPA legal. EDIT: Just found it on XPH currently "on sale" for $949, so in the range of the other non-CEL DPs. However, there is no option for selecting EWG or PWG model. Which one is this made for? |
11-22-2019, 06:18 AM | #5 | |
No 55mph
1621
Rep 8,476
AA pipe would be a good alternative, but I would like to wait for some real world experience with NO CEL & 49 State Emissions Legal claims Also be nice to see some AA Flow charts to compare to OEM & FabSpeed
11-22-2019, 09:57 AM | #6 | ||
Rep 190,777
300 CEL
Correct Quote:
The downpipe comes with an EPA approval number
11-22-2019, 01:10 PM | #8 |
Rep 129
11-22-2019, 01:24 PM | #9 |
Rep 1,499
It's not the cat that determines a ready state, it's your tune. With this DP you can run stock tune, so all monitors ready, but get no CEL.
TinkyWinks42.00 |
11-22-2019, 05:22 PM | #10 |
Rep 190,777
You might be able to pass emission with a downpipe and a tune but that does not make it legal. This is the only pipe thats EPA legal.
11-23-2019, 07:15 AM | #12 |
Mike: Everyone's Pal
2042
Rep 2,972
Drives: F80 M3
nice, I had their e90 headers! good product.
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
11-23-2019, 10:39 AM | #13 |
Rep 190,777
11-23-2019, 12:18 PM | #15 |
Rep 461
I found this for a different GESI catted dp.
"The GESi Metal Core Catalytic Converters have been designed to provide a reliable solution to the most common converter problems experienced by other brands with out having an absorbanent cost. They are considered a 300cell but as bench tested, flow more than the HJS 200 cell cat. " |
11-23-2019, 03:51 PM | #16 | |
Rep 7,606
https://www.verociousmotorsports.com...tic-Converters Several of the bullets about the HP/temp rating, time to reach operational efficiency, etc. Not saying that's a bad thing; I'm sure all vendors that use these cats use the same info. The quote you posted seems to be from Agency Power's 911 turbo exhaust info. I see it on vivid racing and amazon. If the flow information is true, thats a key factor, but i don't see any actual data to support the claim. I am still on the fence between AA and Fabspeed. I'm sure the AA will be great, i just wish there was some real world feedback, but too soon to tell. Fabspeed has the proven track record, which is the thing making the decision more difficult, and with the current sales, the decision has to be made quickly. |
01-10-2020, 01:28 PM | #17 | |
Rep 3,157
We have a check engine light guarantee on this product. Actually we have been Testing the n55 version of this downpipe on my customers M2 for over a year and he just hit 12k miles and is still Cel free. It works and it works well |
alohasurftoad3078.00 superherorockstar63.00 |
01-11-2020, 10:42 AM | #18 |
Rep 211
I have an AA Stage 2 tune with a Fabspeed catted DP and Akropovic exhaust. Were the AA downpipe available when I bought the Fabspeed I wouldn't have hesitated. The support I've received from AA with my tune has been outstanding.
There were reports here that AA was working on that DP quite awhile back and as Andrew has confirmed, it is been thoroughly tested. And with their guarantee you can't really go wrong.
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
01-11-2020, 11:09 AM | #19 | ||
Rep 5,392
01-11-2020, 11:16 AM | #20 | |
Rep 190,777
01-11-2020, 11:16 PM | #21 |
Rep 23
Unfortunately I do not have a base dyno run but I just installed the downpipe and recorded full process, DIY thread coming on this install as well as a full vlog of the install.
Been in the car for a week now super happy with results, no CEL of course as advertised! |
01-12-2020, 10:36 AM | #22 | |
Rep 190,777
