BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Bimmercode app iOS/Android
      06-03-2018, 01:06 PM   #287
AmusedToD
Drives: 2014 F10 520D XDRIVE
Hi guys, anyone managed to enable High Beam Assist through the Bimmercode?
As per some forum guidelines, this is what has to be done:
FRM/3050/FLA_VERBAUT/aktiv FRM/3050/FLA_AUTO_AKTIV/automatisch HU_CIC/3000/HIGH_BEAM_ASSISTANT/aktiv
KAFAS/3015/FLA_ON_OFF/aktiv
The last option (KAFAS/3015/FLA_ON_OFF/aktiv) is not available through the Bimmercode app (although the KAFAS folder is there since I have the KAFAS camera).
When I coded the remaining 3 available options, my car displayed an error “camera based support systems failure”. I couldn’t clear the code through the Biimerlink either, it kept coming back. So I reverted the 3 options back to stock and the error disappeared.
My car is an F10.
Any ideas?
      06-03-2018, 06:50 PM   #288
wilbur_the_goose
Drives: 2018 330ix Gran Turismo
AmusedToD - does your car have a camera to be able to see oncoming traffic?
This takes much more than just coding.
      06-04-2018, 11:53 AM   #289
rlmesq
Drives: 2018 440i M Sport
Originally Posted by snareman View Post
Has anyone successfully coded the driver seat to move back when you open the door using Expert mode? A few of the settings that I've read you have to change don't have options to actually change.
I saw the earlier discussion on this. I think you need to use ESYS and a cable instead of Bimmercode.
      06-04-2018, 05:53 PM   #290
jmciver
///M SubDriver
jmciver's Avatar
Drives: 2017 M3, 2020 X7 40i
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
2009 BMW 128i  [0.00]
Actually, you can use BimmerCode for enabling easy entry (i.e. moving the seat back upon exit) - I just verified it myself as I was curious (I previously coded it with E-Sys though). All of the necessary ECUs are available and you can quickly search and find the necessary parameters using Expert Mode. In fact, the demo mode (which is a sample of ECUs and parameters) has the necessary ECUs and parameters for this mod as well if you want to take a look before you actually code your car (at least the demo mode on my iPhone had it).
Keep in mind that there are slight variations between models and model years when it comes to which ECUs are actually installed in the car. Also, the current software installed in your car adds some variability as well (which is why in general it is better to have the most current software in your car from the dealer). As a result, when it comes to coding this mod (and some others) YMMV...
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
      06-05-2018, 01:53 AM   #291
alainv1029
alainv1029's Avatar
42
Drives: 2015 328i xDrive GT Bootmod3
Obstacle warning gone
Got my obd-2 bluetooth connector and BC all working. Coded some things and worked fine. Had an error (little triangle with !) but got some clues from this thread and cleared it. However, the only thing that didn't work out is that now I've lost the Obstacle warning when rear camera is on in reverse. Left vertical menu 2nd to last option is now greyed out.
Any ideas guys?
      06-05-2018, 05:53 AM   #292
fuzzyboat9239
Drives: MY2017 440i GC
Any ideas guys?
Try restoring from backup and recoding
      06-05-2018, 06:26 AM   #293
RAWATU89
Drives: f31 2014
Vgate iCAR Pro BLE 4.0
having trouboe connecting, once it does connect the app says bluetooth mode not switched on in device.
any help please?
      06-05-2018, 04:48 PM   #294
alainv1029
alainv1029's Avatar
42
Before I did that I noticed that once in a while the PDC would not work but didn't throw up any errors. It's being looked at by SC now. Pretty sure that's what it is - if PDC doesn't work then it cannot sense any obstacles. Thanks for the input.
      07-04-2018, 04:32 AM   #295
xxxzibit2007
Drives: Bmw F30 328i
Originally Posted by spuntyb View Post
I just tried this this morning. App connected just fine to the adapter and I went through and made all the changes. How long should everything take to kick in? I drove for about an hour after all the coding, and nothing. No errors, just nothing took.
I did it with the engine running and doors shut, since without the engine on, it said it couldn't find the car.
I'll try unplugging the adapter, plugging back in and starting over, but any ideas? Did I miss a step?
EDIT- never mind, I figured it out
It should kick in as soon as you done it.....I've got a Bluetooth one and is working fine....done loads of codings with it....
      07-04-2018, 04:34 AM   #296
xxxzibit2007
any help please?
Is it WiFi or bluetooth ?
      07-04-2018, 11:37 AM   #297
snareman
Leave the gun. Take the Canoli.
snareman's Avatar
Drives: ///M8 & X3 ///M40
I couldn't get this to work. Nor did the guy that coded my car the normal way
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40
Retired:
2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe
      07-04-2018, 04:35 PM   #298
jmciver
///M SubDriver
jmciver's Avatar
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
Not sure what to tell you. I coded this originally using E-Sys using the info on the forums (I have a '17 M3). So either your coder did not follow the coding instructions properly to turn on this functionality, or your car has a more current I-Step where BMW made coding this function no longer possible (which BMW has done before with other coding functions).
As far as using Bimmercode, if the parameters can be coded with E-Sys, they can be coded using the app. I verified that myself.
      07-07-2018, 09:10 AM   #299
sgrutt22
Drives: 2014 BMW 328i
2014 328xi  [0.00]
Just successfully coded enhanced bluetooth and tpms pressure and temperature readouts on my 2014 328 x drive using the vgate iCar Pro BT 4.0 and the bimmercode app
      07-08-2018, 01:28 AM   #300
Jimboii
Drives: 2013 bmw F30 sedan
Battery registration
Anyone know if I can do the battery registration through BimmerCode? If so. What dongle do I need that will work with no issues and not too expensive.
      07-08-2018, 10:29 AM   #301
DarkStarBimmer
Colonol Forbin
DarkStarBimmer's Avatar
208
Drives: 17' BSM 330i xDrive
2017 330i  [0.00]
I recently got my Vgate Bluetooth in the mail and used Bimmercode
I have the most basic Idrive system with no NAV no comfort access
I was able to change the following:
Removed all warning chimes and warning screens
Digital speedo
Red sport gauges
ASD Off
Tire pressure with temps
Door handle lights on in reverse
Easy seat entry
Open Door @ ignition shut off (dont have to pull twice now)
Radio/Idrive off with door opening (dont have to hit start/off twice)
Smartphone ringtones
I'm still undecided on doing the folding mirrors with lock/unlock...
This thread plus a few others were a great help in coding these things...Thank you!
EDWYER1669.50
N26Ghost496.50
      07-13-2018, 08:33 PM   #302
Ciram13
Drives: M135i
Hello,
I coded a 440 grandcoupe 2018 today with nbt evo to get Video in Motion using BimmerCode app.
It was done properly and it worked, however my friend called me later today saying the i drive was rebooting every 3 to 5 minutes or so. Contacted to BimmerCode App developer and said it could be due to overheating inside the car, and in case necessary i could revert the coding with the back up option.
Has anyone seen this before? I have read multiple threads regarding idrive rebooting and going to fix it from dispairing phone, updating software in car, taking car to dealer for warranty and so on.
Obviously this was not happening to the car before today’s coding.
      07-17-2018, 04:23 AM   #303
RoopD
Drives: F30 Alpine Weiss
how did you coded enhanced bluetooth?
      07-24-2018, 03:55 PM   #304
emfollin
Drives: 2015 335i M-sport
I just used bimmercode and veepeak to code unlock doors on ignition off and radio off on door open. Two dumbest things BMW ever coded. Very easy to do and only $58 spent. Highly recommend. I did not mess with anything else. Some of the other coding seems to be more in depth. Those two items took 10 seconds.
      07-24-2018, 09:09 PM   #305
EDWYER
Yoda of mods
EDWYER's Avatar
1670
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
Just ordered my Vgate. Love this thread!
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired)
Follow me on Twitter: https://twitter.com/EdwyerCLT
YT: https://www.youtube.com/@DWYERGARAGE/videos
      07-24-2018, 09:28 PM   #306
bdmac97
Drives: 2015 435xi Coupe
I coded a few things tonight and all seemed to go well. One thing I noticed so far though is after updating the instrument cluster board computer to show digital speed it lost the time for the clock in the lower right section. When it comes on now it says "Set date and time." I can't figure out how to do this since in the iDrive system the time is still set...
      07-24-2018, 09:57 PM   #307
jsouth
jsouth's Avatar
Drives: 2013 328i
I emailed Stephan at Bimmercode and he confirmed that he is working on this feature but does not yet have a release date. I'm hoping that by the time I need a battery he'll have it released. I love the app so far.
      07-24-2018, 10:04 PM   #308
ADeBaro9
ADeBaro9's Avatar
Drives: 2013 335i M Sport
Just ordered a vgate can't wait
2013 335i estoril on black M sport
