06-19-2015, 09:47 AM | #1 |
Rep 114
328i non-sport oil cooler?
I drive my car pretty hard and was wondering is anyone has come across a good after market oil cooler option that is designed for setup in our cars?
06-28-2015, 11:26 AM | #2 |
Rep 101
I would like to know, too. Where i live the BMW sells the Europe version instead of the US version, so we don't get the extra oil cooler as the US M sport do. It would be great for me to know this, too. I always wondered if it is possible to buy the US model M Sport oil cooler and install it on the cars which don't have it.
06-28-2015, 05:05 PM | #4 |
Rep 764
06-29-2015, 04:16 PM | #5 | |
Rep 577
The oil is cooled through an oil to water - plate type heat exchanger. Also looking at the schematic of the engine cooling system, it looks like the left side (looking at the engine bay) rad is more directed towards the turbo cooling loop (keeping turbo cool), while the right side additional rad in the hot climate M-Sport version is more directed to the transmission cooling loop. |
Domotron149.00 |
07-01-2015, 07:01 AM | #6 |
Rep 44
There is a small aluminum radiator for cooling engine oil attached directly to the oil filter housing. P/N 11427525333 for all N20 engines regardless of market.
There are some universal oil coolers that provide an upgrade, but may not mount directly to the N20 Engine. You can try http://www.ecstuning.com/BMW-F30-328...ng/Oil_Cooler/ |
07-01-2015, 07:33 AM | #7 |
Rep 577
Yes that is a water to oil heat exchanger.
Although it looks small it is very effective in rejecting the heat in the oil to the Water cooling circuit. Also the water to oil HX is counter flow which is much more effective at exchanging heat than a cross flow Oil to Air HX. So it is essentially like having a much bigger surface area of oil to air radiator to reject the heat. Since water has 4 times the specific heat capacity than air there is an advantage in rejecting the heat in the oil to the water. It is also a lot more consistent since the dT between the oil and water can be managed much more consistently. The heat in the water is then rejected to the ambient air. Since the equation for convective heat transfer is Q=Hc.A.dT, as the outdoor temperature rises the engine will run hotter to a point, from there the dT will start to diminish. To keep below dangerous temps you can either add more surface area (like Hot Climate pack on M-Sport in US) or since Q=M.Cp.dT you can increase mass flow rate to reject the same amount of heat. Surface area is obviously tough to increase (past that of the M-Sport Hot Climate pack) so that leaves mass flow, and not much can really be done there. I guess an oil cooler could be added, but it may not really do much to reduce the oil temp, based in this system design and the operating points. Also since the oil temp is tightly controlled based on water temp and load, adding an oil cooler (oil to air HX) may mess with the control algorithm. Installation would have to be right. You would hate to be confusing the ECU and have it think the oil temp is actually cooler than it really is, and reduce the heat rejected to the water circuit. |
N26Ghost496.50 |
07-01-2015, 09:00 AM | #9 |
Rep 101
Hi interesting points. So even when installing the M-Sport hot climate extra coolers also need to code the ECU for these mods right? By the way, what is the extra radiator used for in a M-sport hot climate version? Thanks.
07-01-2015, 12:42 PM | #11 | |
Rep 577
The extra radiator just adds more surface area (ie heat rejection capacity). Since the dT reduces in hot climates the surface area must go up to match the overall Q. I believe it is piped close to the transmission fluid heat exchanger. Yes there is another HX that takes the transmission fluid and rejects it's heat also to the water cooling system. So maybe the extra rad just helps keep the trans a little cooler. There is a schematics on f30post or here somewhere of the different setups and how they all operate. |
07-02-2015, 08:55 AM | #12 |
Rep 114
07-02-2015, 09:24 AM | #13 |
Rep 577
The oil cooler is the lump (oil to water plate heat exchanger) on the oil filter. The extra radiator is the added water cooling surface area I was talking about.
03-08-2018, 03:49 PM | #14 | |
Rep 2,382
Looking at the design, I'm wondering if we could put the oil cooler before the filter and have it cooled before entering the stock cooler. Looking at a cooler through HEL Performance, it's thermostat controlled and only opens when a certain temp is reached. My two concerns with this is: 1. Does this affect the stock cooler and ECU? 2. Will there be a sudden drop in oil pressure as this is activated?
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
03-08-2018, 08:11 PM | #15 |
Rep 57
Any links for us to look at the products being talked about? I would be interested in this too since I live in FL. I can probably do it when I do oil change.
Alpine White 328i F30 - JB4 STG2 / VRSF FMIC / CW DP
Torque gets you going, HP keeps you going. |
03-09-2018, 08:50 AM | #16 | |
Rep 2,382
Then there is this one. A bit more expensive (+$800 on eBay): http://www.katecool-motors.com/engin...0-f31-n20.html Mishimoto offers a universal one as well that's not too expensive.
Alpine3s14.50 |
03-09-2018, 03:10 PM | #17 | |
Rep 57
Whats the temperature our oil should be at which would require the additional cooling. Ive notice my oil usually hovers 200f or so (JB4 with BT gauges). When I get on the highway it seems to climb a bit, once I get back into road driving it goes down (oddly enough).
03-09-2018, 03:36 PM | #18 | |
Rep 2,382
I average 200 to 225 or so (225 after some spirited runs), but getting it closer to 200 after runs would be ideal. I'm pasting a link to the doc I'm reading out of. Go to section 4.2.3 for more on this. http://www.bimmerpost.com/goodiesfor...BIMMERPOST.pdf
Alpine3s14.50 |
03-09-2018, 03:38 PM | #19 |
Rep 2,382
I'm trying to figure out what would be the best for flow. Do we put it before or after the water/oil heat exchanger? If you put it before, it may not help because temps would be lower going into the exchanger and result in a lower coolant temp and lower flow. If you put it after.. Not sure of the pro/con for that.
03-11-2018, 03:07 PM | #20 |
Rep 577
I'm currently trying an inexpensive G-Plus unit. Was easy to install and seems to be working well in cooler ambient temps. My engine temps have been hovering just above the 160F tick on the gauge. I haven't monitored them on bootmod3. It will be interesting to see what happens as the ambient gets hotter.
Yesterday it was 88F here in Austin and the gauge change much than normal. Here ares a few a pics of the unit installed. |
N26Ghost496.50 |
03-11-2018, 06:05 PM | #21 | |
Rep 2,382
03-11-2018, 08:13 PM | #22 | |
Rep 57
I would like to hear it from the Gurus on the forum. If I keep the temps between 190-230 even after runs, back to back, etc, would an oil cooler be necessary? I log with the JB4 BT module realtime via iPhone and havent seen anything over 225 on a 88f ambient.
