11-16-2017, 03:13 AM | #134 |
Rep 7,484
Check to see if your vehicle has either of the following installed:
6AC, 6AE, 6NH (all three) or 6NH and 609 (both) If you see either of these combinations, you're good to go. If you are still unsure decode your VIN online. |
SteRaw5.50 |
11-16-2017, 03:36 AM | #135 |
Rep 53
11-17-2017, 06:28 AM | #137 | |
Rep 399
No just need to finish work, put the kids to bed and I can go and brick my car Just so I know, what's the Ctl/Alt/Del process to reset it back to backup? |
11-17-2017, 07:29 AM | #138 | |
Supreme Being
1804
Rep 5,425
Place hands together, Pray to whatever you believe in. Then call BMW Assistance. Good luck, you'll be fine
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
Theone8875.00 |
11-17-2017, 11:41 AM | #139 | |
Rep 618
M340d - Brooklyn Grey - Cognac
RustyBitz1573.50 |
11-17-2017, 11:58 AM | #140 |
Rep 2,157
Drives: X3M Competition
Sweet great news
CURRENT
X3M Competition- Toronto Red [url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Car[/url] |
11-17-2017, 12:56 PM | #141 | |
Rep 922
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
11-17-2017, 01:04 PM | #142 | |
Supreme Being
1804
Rep 5,425
All of those parameters are in the same ECU so doesn't make sense that you're missing only some... ...unless you have a different head unit? EDIT: If you still have the 2015 car, yours will likely be HU_NBT - can't recall if this had the separate com box, if so you may need to look in the CMB module for some telematic stuff. What are you missing?
11-17-2017, 01:04 PM | #143 |
Rep 922
How does one go about coding out the cornering lights, on BimmerCode?
I go into FEM see the option for Cornering Lights, click on it and the "Aktiv" is selected, but it doesn't give any other selectable option?
11-17-2017, 01:05 PM | #144 | |
Rep 922
According to the online VIN decoder, I have all of the following; 6AC 6AE 6NH 609
11-17-2017, 01:13 PM | #145 | |
Rep 922
HU_NBT_EVO > HMI 3000 > CDMM_USB_PORTS = usb1 HU_NBT_EVO > HMI 3000 > CDMM_USB_PORTS = usb1_sia HU_NBT_EVO > HMI 3000 > OFFICE_MENUS_ACTIVE = aktiv And this wasn't the default; HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > API_USB_VIDEO = none [Default] And then I just stopped going further cos I thought better to just ask first.
11-17-2017, 01:14 PM | #146 | |
Supreme Being
1804
Rep 5,425
I would imagine the options will then appear different as you have the slightly other model head unit. What you are aiming for is to change 6NH to 6NS, 6NK or 6NL SA 6NS - comfort telephony with expanded smartphone connection SA 6NK - mobile phone preparation with connection of Bluetooth and USB devices SA 6NL - mobile phone preparation with connection of Bluetooth and USB devices incl. BMW-Assist The instructions below from Stephan are to change a more recent setup (ie. not 6NH). So in answer to your question, I believe YES, just code what you can see but note a) what you are missing and b) everything you change (along with original values!)
Dr Forinor266.00 |
11-17-2017, 01:17 PM | #147 | |
Supreme Being
1804
Rep 5,425
The OFFICE_MENUS_ACTIVE may potentially cause issue as I think that's where the text messages and emails are stored API_USB_VIDEO is related to the USE sockets (none, front, both) - you don't have that option so don't worry.
11-17-2017, 01:18 PM | #148 | |
Rep 922
Can you help with the Cornering Lights, please? http://f30.bimmerpost.com/forums/sho...&postcount=143
11-17-2017, 01:29 PM | #149 | |
Supreme Being
1804
Rep 5,425
All this will be in FEM_BODY expert mode.
Dr Forinor266.00 |
11-17-2017, 01:31 PM | #150 |
Rep 922
Thank you
11-17-2017, 04:43 PM | #152 |
Rep 399
So started a bit of coding and it was all a bit hit and miss.
Things that worked - Handle lights on reverse M Logo on idrive screen PDC distance and speed Things that didn't work - Digital speedo M logo on cluster (although I could get M550d in pick!) Things with no option - Indicator clicks x3 : |
11-17-2017, 04:45 PM | #153 | |
Rep 922
Indicator Clicks x3 is an option that you can do via the iDrive if memory serves correct?
11-17-2017, 04:47 PM | #154 | |
Rep 922
This also seemed to get rid of the stupid thing where the front fog lights would go on when you select reverse if the dipped/auto lights were on.
