02-06-2018, 11:22 AM | #243 |
Rep 44
02-06-2018, 11:49 AM | #244 |
Rep 12
02-06-2018, 11:51 AM | #245 |
Rep 12
02-06-2018, 01:06 PM | #247 | |
Rep 10,473
Even though the it shows the new is exchangeable with the old in your post, when you look at the old number you see it correctly states it is NOT exchangeable. That is correct as the voltage changed with the newer units. This is also why you need to check both part numbers on realoem and further research if any discrepancies. |
02-06-2018, 02:44 PM | #248 |
Rep 12
02-06-2018, 03:07 PM | #249 |
Rep 565
It seems you have HU_ENTRYNAV, which should support a larger screen. The head unit started production in 11/2014 for cars without nav, however, some got it earlier (if they had standard nav = business nav).
In order to be 100% sure, get an ENET cable ($20 on eBay) and check via eSys software. More info on the coding forum, or PM me for details. You'll need the cable anyway if you want to install the larger screen, so you might as well get it first. |
02-11-2018, 01:07 PM | #250 | |
Rep 12
NBT2_Evo or PRO_NAV also do I have to change the Emulators thanks again for the help |
02-11-2018, 06:22 PM | #252 |
Rep 12
I have uploaded a picture on my account is this the screen Im looking for?
02-12-2018, 07:04 AM | #253 | |
Rep 565
No need for cable change and/or emulators. |
04-10-2018, 04:50 AM | #254 |
Rep 6
Hello Guys, can someone please check if i can do this upgrade.
My vin is: K287328 Production date: 10/2014 RealOEM is showing: 65509292247 - S606 Thank you in advance it would be really appreciated. |
04-10-2018, 05:08 AM | #255 |
Rep 565
Your car should have the suitable head unit (HU_ENTRYNAV). In order to be 100% sure, get an ENET cable/adapter ($20 on eBay) and eSys software (check the coding forums) with which you can validate what head unit you have.
After checking your head unit, get one of these two screens on eBay and follow the instructions at the beginning of this thread to retrofit it. |
Cebela1.50 |
04-10-2018, 06:13 AM | #256 | |
Rep 6
04-11-2018, 12:45 AM | #257 |
Rep 6
MarkoSK: A quick question as I found a cheaper X5 10,25" screen on fleabay, can this be also fitted (coded) with some trimming on the HU_ENTRYNAV?
Unit: 9347878-03 Again thank you for your awesome support. (nvrmind as i found out it only fits on to a NBT unit.) Last edited by Cebela; 04-11-2018 at 03:14 AM.. |
04-11-2018, 09:06 AM | #258 |
Rep 565
HU_ENTRYNAV works with a 10.25" screen (you just code the proper resolution), some have retrofitted it. However, I can't guarantee that particular screen would work - I think yes, but I can't guarantee it. If you can buy it with some sort of return policy, try it out and if it won't work, return it.
Cebela1.50 |
04-12-2018, 05:10 AM | #260 | |
Rep 646
You do need to modify the back plastic to make it fit at all though, but should be possible.
| 2021 Tesla Model 3 |
04-12-2018, 04:40 PM | #261 |
Rep 565
04-14-2018, 11:27 PM | #262 |
Rep 5
I have f25 X3 2017 with 6.5 screen try to change to 8.8
I have f25 X3 2017 with 6.5 screen try to change to 8.8 inch.
I bought the screen 8.8 inch from eBay. But the connector is not same with my car. Look like different display The one I have in my car. Only one connectors. But the one I bought have two connector. They have the adapter for sale. Or I have to get another screen. Thanks And the picture is my original display
Peter
bycomputer@hotmail.com Last edited by bycomputer; 04-14-2018 at 11:38 PM.. |
04-15-2018, 04:04 AM | #263 | |
Rep 565
04-21-2018, 08:40 AM | #264 |
Rep 2,044
Hello BMW Experts!
It was an ordeal, but I got my big 8.8" 7453 screen in & working! The 2626 wouldn't work. Knocked out all screen functions initially, but now all works. Story here: http://f30.bimmerpost.com/forums/sho...4#post23088894 Best, Murf Last edited by Littlebear; 04-21-2018 at 07:45 PM.. |
