11-04-2019, 03:05 PM | #991 | |
Rep 120
11-04-2019, 03:45 PM | #992 | |
Rep 220
Drives: MINI Cooper, 2020 X1
11-05-2019, 01:37 AM | #993 |
Rep 67
nice, should be a good warning for RK based PX devices.
did you bridge the pins after removing the otg connector or did you leave them open? if you leave the resistor off, can you still use the usb port for data? |
11-05-2019, 02:12 AM | #994 | |
Rep 118
What about https://github.com/chinesebmwheadunits ? |
11-05-2019, 08:37 AM | #995 | |
Rep 1,407
Drives: 13' F30 328i 6MT
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
11-05-2019, 09:37 AM | #996 |
Rep 220
I connected a 10 Ohm resistor with a wire to the miniature switch on the back cover of the unit...
11-05-2019, 12:46 PM | #997 |
Rep 120
I modify the factory.xml but the system doesn't recognize the update... |
11-05-2019, 01:03 PM | #998 | |
Rep 1,048
at PX6 HU your navigation applications are stored within the mapApkLst.txt which has to be at the OEM folder. you need to add your application there. Chri |
11-05-2019, 03:30 PM | #999 |
Rep 120
No, i'm sure that i have the Snapdragon unit, also i have already update the last Ksw-P-Userdebug_OS_v3.0.8-ota.
11-05-2019, 04:38 PM | #1000 | |
Rep 159
I'll try to look into it more, there should be a solution to it. Got it all working now! Much thanks! Glad I didn't have to fully root it just for that tiny tweak Last edited by Frankly30; 11-06-2019 at 08:36 AM.. |
11-05-2019, 10:58 PM | #1001 | |
Rep 1,048
Chri |
11-05-2019, 11:18 PM | #1002 | |
Rep 120
11-06-2019, 12:08 AM | #1003 |
Rep 1,048
11-06-2019, 01:31 AM | #1004 |
Rep 114
One question - factory_config file is vendor specific , since I see vendor information specifying certain MCU ?
I have a vendor which does not provide this file and I want to edit it .Can I get file from update ROM or from unit ? I can not seem to find it with ES Explorer. |
11-06-2019, 02:05 AM | #1005 | |
Rep 1,048
If Snapdragon you can find your local copy of the file under "/mnt/vendor/persist/OEM/factory_config.xml" but to get access to this file you need to have R/W access to the partition, which ES Explorer normally doesn`t have. either copy it via adb to your internal sdcard folder, or access the device via a PC over a Browser which is capable of adb (Total Commander + adb plugin). Chri Last edited by Kri; 11-06-2019 at 02:12 AM.. |
seaman570513.50 |
11-06-2019, 02:28 AM | #1006 | |
Rep 220
if it looks like second pic, edit it again without errors... Last edited by smahel; 10-18-2023 at 01:32 AM.. |
11-06-2019, 03:37 AM | #1007 | |
Rep 114
11-06-2019, 07:04 AM | #1008 |
Rep 25
Hey guys, does anyone know if these provide a decent sound quality?
Last I checked these headunits were horrendous for music especially when paired with HK audio. That's my main concern when considering this upgrade. Thanks! |
11-06-2019, 08:03 AM | #1009 | |
Rep 1,048
Chri Last edited by Kri; 11-06-2019 at 08:23 AM.. |
11-06-2019, 08:57 AM | #1010 | |
Rep 1,407
Another thing I want to comment on... These units install with ease, The Chinese mfr's making these did a great job with fit/finish & even the harness's work good. They also made a pretty good copy of the BMW design in the OS and how they integrate with the CANBUS... Its just the Audio Quality Issues... This is something I cant figure out, If they can do something this close to perfect why isnt ALPINE / PIONEER / SONY etc etc doing the same? They have been building electronics for 100 years why are they not jumping in? There is no way they cant do it better if they wanted to, Is it a licensing thing or royalties etc? This unit with top level guts would be stellar.
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] Last edited by QUiKSR20; 11-06-2019 at 09:06 AM.. |
11-06-2019, 09:40 AM | #1011 | |
Rep 237
Moreover, chinese oem use low cost electronics, no original design (I'm talking about board, software ecc) and almost no support, for an eom like sony/alpine ecc this could be impossibile. They whould need licenses, development and research budget, and a real support. I think it simply doesn't worth the money. The chinese business is much more "agile" and low cost, they could launch a board with a canbus interpreter, a software developed in a garage and almost forget about it. Notice that the upgrades we're getting are from the board manufacturer, not by the headunit manufacturer, it's like samsung/lg/sony mobile devices to get support directly from qualcomm instead of the respective brands. |
11-06-2019, 10:18 AM | #1012 |
Rep 114
In my case audio is pretty acceptable . I would say 85% of original system . Original system is HIFI on F10 , coded in L7 surrond . Of course it is not really like L7 , but 11 speakers(from original HIFI system) in the car, boosted volume and frequencies add something .
I have to mention that I have disconnected AUX port in armrest and lowered volume in Android unit to about 20. |
