11-15-2019, 03:28 AM | #1123 |
Rep 118
It would all be so much better if we could get the source code for the mcu and the unit...
Maybe we could do a "group buy" for the sources Being a chinese product its just a matter of "asking" to the right person. |
11-15-2019, 05:03 AM | #1124 | |
Rep 1,048
but it still require special programming skills to get use of them. Chri |
11-15-2019, 05:22 AM | #1125 |
Rep 118
11-15-2019, 06:30 AM | #1126 | |
Rep 67
what is the use case for a bt client connection?
- torque through obd? (alternative could be HUR with Torque Addin) Quote:
1. afaik not. 2. https://www.amazon.de/clouddrive/sha...gzVOHPXQMij3zv 20190929T is the latest that i got, ask your seller for an update, if you get a newer file, please share. |
11-15-2019, 07:04 AM | #1127 | |
Rep 1,048
* BMW Performance Analyser (require also G-sensor ect.) * external BT Keyboard. * External BT Touchpad (for shortcuts, for example Tsumbai Ai01 ) * BT ODB dongle for diagnosis * BT Microphone for common use like google Assist Kri |
11-15-2019, 08:20 AM | #1128 | |
Rep 71
Gabo
11-15-2019, 11:54 AM | #1129 | |
Rep 399
If only I could find some way to make it beep at least ... Disconnecting CAN from Android is the only way to make it work, it seems. But which functionality is lost? Dashboard, iDrive button and steering wheel buttons? And Android needs to be powered by other means then. I'm thinking of getting power from Quadlock pin 13, which is often used as remote turn on signal for external amplifiers. An added benefit would be that the screen will turn on immediately when the car is unlocked, and will remain on for a while when locked. |
11-15-2019, 01:59 PM | #1131 |
Rep 301
Drives: BMW M235i
Does anyone know if the new 'Android Auto for phone screens' app works without physically connecting the phone via USB?
11-15-2019, 06:32 PM | #1132 |
Rep 71
What I know is if the vehicle has WiFi functionality then will work without usb cable
Gabo
11-16-2019, 05:25 AM | #1133 |
Rep 237
currently, androidauto (AA) works via wireless only with a limited number of galaxy/pixel phones AND (obviously) only with a wireless androidauto server headunit on the car (some car of vag group, some kenwood headunits),
On android headunit we can use "headunit reloaded", an app that use the original aa app in server mode and make it available via wireless form the phone (a wider range, but compatibility is not guaranteed, you have to try). https://forum.xda-developers.com/gen...droid-t3432348 |
grocerylist271.00 |
11-16-2019, 10:43 AM | #1134 | |
Rep 237
11-16-2019, 10:57 AM | #1135 | |
Rep 399
The OEM mic is active and has noise cancelling, much better than others. We can probably make it work by supplying the correct voltage. Is this BMW mic? |
11-16-2019, 10:58 AM | #1136 |
Rep 280
Attached you'll find my app that makes the iDrive controller usable in any app.
Bear in mind, this one only works for Snapdragon devices and requires root and Xposed. Source is attached as well. Remove the '.pdf' ending from the apk to make it work. As always, use at your own risk. I removed my unit from my car today and will return it on Monday. Good luck |
11-16-2019, 11:07 AM | #1137 | |
Rep 399
If you press and hold the Menu button to activate the BMW interface, do you see a working OEM interface there? If so, maybe you could use Tasker to switch to BMW side when reversing. |
11-16-2019, 02:46 PM | #1138 | |
Rep 2,368
Drives: E63 645Ci
Edit: Besides, even if the OEM mic does require power, we don't have to worry about that as all we do here is tapping into the signal wires + and - and passing that over to Android unit. The original mic wiring is intact if you know what I mean. |
11-16-2019, 11:38 PM | #1139 | |
Rep 399
I'm in a bit different situation, because I will retrofit a BMW mic only to the Android unit. I tried it on my PC, which supplies 3.7 volts, and it is barely audible. This is an active microphone with internal electronics which needs power. Last edited by Mjam; 11-17-2019 at 12:10 AM.. |
11-17-2019, 04:34 AM | #1140 | |
Rep 2,368
Drives: E63 645Ci
As I said before I'm not even sure if this would apply to anything newer than E60/E63/E90 CCC variants. I didn't check wiring diagrams for F cars and this could be completely different. I might be able to check voltage readings on OEM mic later on today. Will keep you updated. Just out of curiosity, what part number is your mic? |
11-17-2019, 08:02 AM | #1141 |
Rep 62
Hi Hi
Does the most recent update for the SnapDragon Android 9.0 solves the GPS audio switching issue? This is getting a lot irritating as i do not have the sound coming to the lft speakers, instead to the small speaker provided by the manufacturer which i did not connect to. |
11-17-2019, 08:10 AM | #1142 | ||
Rep 87
EDIT: I followed this instructions to get Xposed https://f30.bimmerpost.com/forums/sh...&postcount=409 Great job with the app! However I must say that for my use case, there are not many benefits. I use it only for Waze and Deezer. It doesn't work in Waze, it works in Deezer but its clumsy. Which is not strange since those apps are designed for touch inputs. Last edited by twoface; 11-17-2019 at 09:56 AM.. |
11-17-2019, 08:45 AM | #1143 |
Rep 159
I was wondering if we need root access to listen to the iDrive controller inputs.. I was thinking of configuring a wrapper for navigation apps, that simulates touch inputs for zooming and moving. I wonder if thats already possible with available apps or if we'd have to write something new.
11-17-2019, 11:22 AM | #1144 |
Rep 399
The latest for E-cars (got it from a E60 2008): 84316938762
