11-24-2019, 02:26 PM | #1233 | |
Rep 87
Or you meant that you connected camera detection wire to LED? I have a question for those who experimented with Fastboot on this device. If I reboot into bootloader with adb, can I get out by rebooting the unit? I saw that someone was stuck in fastboot. Also is there a way of using the fastboot without messing with OTG resistor? I'm experimenting with custom TWRP recovery for this unit so I want to know if I gonna screw myself by going into bootloader to boot TWRP. |
11-24-2019, 02:53 PM | #1234 | |
Rep 45
11-25-2019, 01:13 AM | #1235 | |
Rep 114
Don't know if having USB debugging enabled will change anything . I've got stuck at fastboot by accident, after updating Magisk . |
11-25-2019, 01:53 AM | #1236 |
Rep 114
antennas
Who knows which antenna connector is for what ? We have those 3 connectors in Snapdragon units .
In my unit only middle connector was connected to an antenna wire which seems to be for WIFI. I wold like to improve 4G-LTE reception . Maybe someone who opened their units and has some other antennas connected can give some details . I think Naviodm units come with 4G antenna too. Where is that 4G antenna connected ? |
11-25-2019, 04:01 AM | #1237 | |
Rep 67
Does someone has a solution for quicker gps fix? As said, I do not believe it is a hardware problem. |
11-25-2019, 04:30 AM | #1238 | |
Rep 159
This may also work but requires you to have your Android rooted https://play.google.com/store/apps/d...n.GPSRepairFix |
11-25-2019, 05:10 AM | #1239 | |
Rep 67
Other solutions rather are welcome'd too. |
11-25-2019, 06:12 AM | #1240 | |
Rep 118
Not a one click solution : https://forum.xda-developers.com/sho...&postcount=740 I haven't tried it personally though |
11-25-2019, 08:19 AM | #1241 |
Rep 79
Another reason to have Snapdragon unit, instant GPS fix for me. I have the antenna mounted behind instrument cluster.
11-25-2019, 08:57 AM | #1243 |
Rep 67
Yeah my car has no oem gps antenna this makes a difference of course. But somehow I need to fix this as this make me crazy. Beside this everything else is flawless i am really happy with da unit
11-25-2019, 09:58 PM | #1245 |
Rep 53
A few days after I installed my new screen I've had random intermittent really bad distortion in my one drivers side door speaker. Randomly gets very loud and shitty sounding when a song has even minor base. Sometimes it gets really bad and sometimes I can drive the car for 30 minutes without it happening.
What are the chances I messed up a connection or the harness they gave me could be bad? Or is it possible that my speaker is going bad. Any ideas on how to troubleshoot this? |
11-26-2019, 12:07 AM | #1246 | |
Rep 114
I would check the speaker itself. But there is always a chance for a bad connection in chinese quad locks. |
11-26-2019, 12:10 AM | #1247 |
Rep 18
I got a manual from seller for fixing the problem with noise in navigation voice. He means that the problem is the center speaker. Don't ask me why... I don't know.
Here is the URL for the download: https://gofile.io/?c=fVzPxV Someone here who would like to try it? For me cutting wires is the last option. I think it is a software bug. When I start music player, start navigation, close music player and open Deezer, navigation voice is normal without noise. If I don't start the music player there is a noise, no matter if Deezer is playing music oder radio. |
11-26-2019, 03:30 AM | #1248 | |
Rep 237
IT IS a software bug but they can't/wan't talk to people who developed the software to fix it, apparently. The original multimedia apps apparently starts a service that fix the audio routing. They didn't do it as a service, they did all embebdded in the app. Typical of chinese software developers hamsters. Last edited by floc; 11-26-2019 at 03:59 AM.. |
11-26-2019, 06:33 AM | #1250 |
Rep 86
Newest Update file for Snapdragon Units:
3.3.5 https://mega.nz/#!r8MCQITK!Gth6TXTg4...ZbXt5kEC08D5No |
11-26-2019, 06:57 AM | #1251 | |
Rep 18
For the moment I will try a tasker/macro app which runs and closes automatically the default music player app when head unit starts. Maybe a root access is necessary for that. |
11-26-2019, 07:17 AM | #1252 | ||
Rep 237
11-26-2019, 07:19 AM | #1253 | |
Rep 424
11-26-2019, 07:21 AM | #1254 |
Rep 29
RaceX Dimming Service v1.11
Hey guys,
I'm back with a new version of my dimming application. List of features : - Android service. The app will start an Android service so it can control the brightness whenever the UI is not displayed - Day/Night mode brightness - Steering wheel control support - Automatic brightness switch (sunrise/sunset) based on time and location - Display main UI on startup. You can choose to display the main interface at startup - Configurable presets (thanks to Shrazy for the idea - Idrive knob integration. You can use the Idrive knob to select and activate a preset Considerations : - It has been designed for my PX6 Android 8.1. I have no guarantee it will work on Snapdragon or Android 9 units. - The steering wheel controls will NOT work fine if you start the default music app. I'm using the steering wheel scroll wheel to adjust the dimming, so if the default music app has been started it will also change the current playing track... - I can't guarantee the serial port used by your unit will be the same number than mine. I can add a config menu in the future. Using the steering wheel scroll button : - Increase the dimming by scrolling up the wheel scroll button - Decrease the dimming by scrolling down the wheel scroll button - Switch day/night mode by clicking the wheel scroll button Using Broadcast Intent : I added a broadcast intent so you can control the dimming using you own application (or Tasker, Automate, etc...) The action string is : Code:
ovh.msinfo.RACEX_DIMMING_ACTION Code:
Name --> ovh.msinfo.RACEX_DIMMING_EXTRA_PERCENT Type --> Integer Values --> 0-100 Code:
Name --> ovh.msinfo.RACEX_DIMMING_EXTRA_DAY_NIGHT Type --> Integer Values --> 1 I have some work to do on the design of the interface. I'm not very good when it comes to create interfaces. If you have any ideas please let me know. Donate : If you wish you can make me a donation : https://www.paypal.me/racex58 Download link : RaceX Dimming Service v1.11 RaceX58 |
