11-26-2019, 07:55 AM | #1255 | |
Rep 118
Donation done, keep up the good work buddy |
RaceX5854.00 |
11-26-2019, 09:40 AM | #1256 |
Rep 45
11-26-2019, 11:11 AM | #1257 | |
Rep 190
It works fine for now. But it does not change the brightness if you change the night mode slider. It defaults to 20% . How can you set the default night mode brightness to a higher level ? |
11-26-2019, 11:13 AM | #1258 | |
Rep 399
11-26-2019, 11:56 AM | #1259 | |
Rep 1,048
I checked the source-code and found a new feature called "ecar" but it seems to require a entry at the factory_config.xml, at least i found the entry there. Kri |
11-26-2019, 02:58 PM | #1261 | ||
Rep 1,048
I checked the source code, and found a couple of changes again. First the Build.prop to see what version it is exactly: Code:
ro.vendor.build.date=Fri Nov 8 04:10:12 CST 2019 ro.vendor.build.date.utc=1573157412 ro.vendor.build.fingerprint=Android/msm8953_64/msm8953_64:9/PKQ1.190202.001/11080410:userdebug/test-keys Now to the more important stuff, the following list is my interpretation of stuff/code changes i found. so it may be correct, but something also may be wrong. * First of all, the main update to this seems to be GUI related. There are three new GUI`s within this image, MBUX, MB_GT6, and GS_UG. The first two are obviously Mercedes gui`s, the third one is some kind of BMW ID7 Spin-Off. changes found from 3.0.8 to 3.3.5: To activate them you need to add a couple lines to the Factory_config.xml This for example is how i added them: Code:
<SupportUIList> <Item id="1" name = "BMW_EVO_ID5" /> <Item id="2" name = "BMW_EVO_ID6" /> <Item id="5" name = "BMW_EVO_ID7" /> <Item id="8" name = "Common_UI_GS" /> <Item id="10" name = "Benz_MBUX" /> <Item id="11" name = "Benz_NTG6" /> <Item id="12" name = "Common_UI_GS_UG" /> * The second thing is, that Bootimage Selecting is now fully implemented You can now select between different images or import a new one. However they removed four images which where present at update 308. so if you want to add an image you need to create a splash.img file. How to create your own Splash file is described HERE. For replacing the bootanimation you still need to put your animation file into the OEM folder of your thumbdrive, it will be then imported into /cache/ then, so no root necessary for this. * Then there also have been made alot of changes to the Bluetooh App, it seems they have splitted some part of the code, probably because of the Benz GUI`S but also addes some stuff. There are changes at the virtual-Key input methods, i don`t have a Iphone, maybe it`S idrive related, need to be checked There is also a updated at the Phone Calling history list, and some kind of Powermanagement code of the BT module. * The language translations have also been updated, some german translations are better now again. * It seems they a working on implementing a new app called ECAR SOS for what i found out it seems to have following Features: * Online / Phone Helpdesk Service with Callback Service * Message Center * Fault Check * Emergency Camera ? * Road Rescue (breakdown service) * Accident Assistant * Vip Service ? * Tired chat , Somebody will talk to you to stay awake * Private Doctor * ect. Below a screenshot is also attached * New carplayzlink.apk at preinstall folder , Version 3.5.6 this is what i found so far. Kri Last edited by Kri; 12-12-2019 at 11:08 AM.. |
11-26-2019, 03:07 PM | #1262 | |
Rep 10
In the current state do you get a change of display when you select reverse gear? Even without the camera actually connected / working? Although the oem side works as normal, the android side on mine doesn’t change. |
Frankly30137.00 |
11-26-2019, 03:47 PM | #1263 | |
Rep 16
I have F31 with gps antenna in the back. I'm wondering how difficult to pass antenna through the car. Do you have GPS antenna splitter? Or did you just disconnect native navigation system? |
11-26-2019, 03:51 PM | #1264 | |
Rep 16
Try to ask your seller for same. |
11-26-2019, 03:56 PM | #1265 | |
Rep 16
But also I was able to temporary fix distortion with turning on music player first. So it's difficult to understand what is the real reason. But changing cable really helps. |
11-26-2019, 04:34 PM | #1266 |
Rep 237
do you have any picture of this harness? As explained, in my case the mod only inverted the problem.
11-26-2019, 10:32 PM | #1267 | ||
Rep 53
11-27-2019, 12:12 AM | #1268 | |
Rep 18
I am using a FAKRA splitter in the back and a extension cable which connects android system with splitter. The extension cable is under the luggage space and goes on the co-driver side to the front. With the splitter I can use ConnectedDrive and android navigation. It finds the GPS signal very quick, maybe 3 seconds. |
11-27-2019, 01:22 AM | #1269 | |
Rep 10
Did the screen change beforehand though? Or did nothing at all happen until you grounded the camera? |
11-27-2019, 02:17 AM | #1270 | |
Rep 29
Thanks a lot buddy !
With it I can be able to find which serial port is used by snapdragon units. Can you please give me more details? To adjust the night mode brightness you have to go to the settings then move the slider. But I'm sure you've already done this. |
11-27-2019, 02:23 AM | #1271 | |
Rep 190
In your app settings if you move night mode slider nothing happens. If you go in Android settings the brightness is set if it is night at 20% by default and there you can change it. The problem is why the slider in your app does not change brightness. It does change if you enable the steering wheel buttons though. |
11-27-2019, 03:55 AM | #1272 |
Rep 67
11-27-2019, 05:01 AM | #1274 | ||
Rep 29
Setting day and night mode brightness ? In the app settings you can set a brightness value for day mode and night mode. It means that when the app switch from day to night mode it will set the brightness to the night value. And when the app switch from night to day mode it will set the brightness to the day value. Switching day/night mode ? There are 3 methods to switch between mode : - If you enable 'Automatic brightness' in the settings, the app will switch automatically between day and night mode according to the sunset/sunrise of your location. - If you enable 'Steering wheel support' in the settings, you can click the steering wheel scrool wheel button to switch between day/night mode. - If you use an application like Tasker or Automate you can use Android Brodcast Intents to switch between mode. You can also set different presets according to the weather conditions (sunny, cloudy, etc...) I hope it is more clear for you now. Let me know. Quote:
RaceX58 |
Shrazy12.00 |
11-27-2019, 05:07 AM | #1275 | |
Rep 190
But my car has no click steering wheel button to make the switch so when i move the night mode slider i cannot know what level of brightness the app uses, unless i wait for the automatic mode to make the change. when you move the slider it does not show a value of current brightness that you choose. to be more specific . when you change the brightness from steering wheel buttons it says brightness 10% , 20% , 30% etc. You set the value that you need , but on next change the app will set the value from the slider again. Could you put an indicator in the slider that measures the brightness? I am trying to explain but is a bit difficult. Can you understand me? |
11-27-2019, 05:20 AM | #1276 | |
Rep 29
If it can help you, the sliders go from 0 to 100. It may help until I update the app. For my part I've set the night mode to 0 % on my unit. It's s still bright enough for me. |
