11-27-2019, 06:41 AM | #1277 | |
Rep 50
11-27-2019, 08:48 AM | #1278 | |
Rep 280
- root the unit - install (Ed)Xposed - install my app - enable it in the Xposed Manager app, reboot - done Optionally use the included settings activity to configure the input. Instructions for rooting and Xposed can be found in this thread. Again, there is plenty of room for errors so everything is done on your own risk. |
11-27-2019, 11:41 AM | #1279 |
Rep 16
11-27-2019, 11:51 AM | #1280 | |
Rep 16
It goes by internal CAN to the front head unit somehow. Thanks for the info. Will try splitter as well. Last edited by Sergii; 11-27-2019 at 11:59 AM.. |
11-27-2019, 11:59 AM | #1281 |
Rep 16
I can confirm that disconnecting AUX socket in the hand-rest really improves sound.
Interesting enough: you need to wait some time (2-3 seconds?) before sound improves. My setup: NBT-Evo + PX6. |
11-27-2019, 12:09 PM | #1282 | |
Rep 1,407
Drives: 13' F30 328i 6MT
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] Last edited by QUiKSR20; 12-05-2019 at 11:28 PM.. |
11-27-2019, 12:48 PM | #1283 | |
Rep 122
thanks Last edited by gsnake; 11-27-2019 at 12:57 PM.. |
11-27-2019, 02:40 PM | #1284 |
Rep 399
11-28-2019, 01:18 AM | #1286 | |
Rep 18
btw: My seller will send a new harness to me. I've to wait few weeks but it is no problem for me. Hope that the harness will fix the problem with navigation voice. Did you cut any cable (e.g. center speaker) when you connecting the new harness? |
11-28-2019, 06:22 AM | #1287 | |
Rep 16
It's NBT-Evo (ID4) with AUX, USB and iPhone 6 dock in the armrest. Everything is pretty useless for me as Android user with Android head unit. No need to cut anything in my case. It was "plug-and-play". Only extra step is to connect front speaker. |
11-28-2019, 07:36 AM | #1288 |
Rep 45
brooksarama0.00 |
11-28-2019, 09:08 AM | #1289 |
Rep 1,048
11-28-2019, 09:32 AM | #1290 |
Rep 122
brooksarama0.00 |
11-28-2019, 10:51 AM | #1291 | ||
Rep 53
11-28-2019, 11:24 AM | #1293 | |
Rep 87
However, boot time is now longer. https://f30.bimmerpost.com/forums/sh...&postcount=409 If I've rooted the device and installed magis. Can I seamlessly update to new version without bricking the unit? Also, for those who updated, are there any functional improvements? I'm mostly interested if they fixed brightness adjusting for the screen. And if apps are still getting killed when we switch to iDrive screen? |
11-28-2019, 11:31 AM | #1294 |
Rep 399
1. Has anyone manual transmission and PDC working on the Android unit?
2. What is the difference between IDrive_A and IDrive_B in the factory settings? |
11-28-2019, 11:33 AM | #1295 |
Rep 399
11-28-2019, 11:40 AM | #1296 | ||
Rep 1,048
I extracted the most common apps from the latest Snapdragon 3.3.8. Build, you can download it here. Kri |
11-28-2019, 11:48 AM | #1297 | |
Rep 122
<!-- 工厂设置密码(4~6位数) --> <password>1314</password> |
11-28-2019, 12:25 PM | #1298 | |||
Rep 1,048
I had 0000 before, after removing the numbers it was back 1314 You can reduce it to only one number, this will work, my password is now 0. Quote:
I think the difference between Idrive_A and B are some kind related to the old CCC one / CCC-CIC multi Button Controller have the CIC Controller, and have not noticed a difference in changig the setting. Quote:
it`s from 13th. November 2019 Code:
ro.bootimage.build.date=Wed Nov 13 04:11:34 CST 2019 ro.bootimage.build.date.utc=1573589494 ro.bootimage.build.fingerprint=Android/msm8953_64/msm8953_64:9/PKQ1.190202.001/11130411:userdebug/test-keys New Feature: Last Screen Selection (maybe does require MCU update ?) New Feature?: AUX Position selection, function unclear - related to MCU Car Aux Operate New Feature: E-Car Service www.e-car.cn activateable via factory_config.xml (china only service) Change: Small Language updates Change: internal Updates to NGT6 and UG GUI Change: Change to MCU function ( Time Function / new: Car Aux Operate / ) This code is new: Code:
<string name="set_caraux">AUX Position</string> <string name="set_caraux1">AUX Position 1</string> <string name="set_caraux2">AUX Position 2</string> Last edited by Kri; 12-12-2019 at 11:03 AM.. |
Firefly1337846.00 kcsmithcyril0.00 |
