BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 9.0 HU discussion
      12-08-2019, 05:51 AM   #1431
pitoncho
Drives: bmw e87
Thank you, but i cannot do anything, only when i start the radio, it appears two omages, on the left no signal and on the right fasten seatbell.. No charge the android boot logo, i dint know why. What more can i do?
      12-08-2019, 06:01 AM   #1432
pitoncho
Drives: bmw e87
i have the same problem..
      12-08-2019, 09:19 AM   #1433
uris
Drives: F31
My friend
this is supposed to be px6.img and update.zip
USB FAT32 MAX 32 gb
do you have a GPS splitter ??
If so, remove it, it causes no signal
      12-08-2019, 09:51 AM   #1434
pitoncho
Drives: bmw e87
Originally Posted by uris View Post
My friend
USB FAT32 MAX 32 gb
no no, the video is not mine, i have an e87 without navigation. My problem is that when i put the key, it appears me that double screen, no signal and the other one is the seatbel and tank liters. I try to touch all the buttons of my steering wheel and of the idrive buttons, and when i touch menu button, it appears the bmw logo (load mode) and after no signal, and turns again with bmw logo and no signal.. all time at that screen.. i try to enter recovery touching with 5 fingers, using reset button, but nothing.. i dont know why does it happen, i need help..
      12-08-2019, 11:14 AM   #1435
uris
Drives: F31
Please record a video
      12-08-2019, 11:38 AM   #1436
pitoncho
Drives: bmw e87
Yes, this is:
any ideas or solution?
      12-08-2019, 12:33 PM   #1437
Pondaire
Drives: 2013 328i
Yes, this is:
The original car display should work regardless, shouldn't it? I think your issue is not with the MCU or the Android part. I think your issue may be with the wiring. Check connections are good.
      12-08-2019, 12:38 PM   #1438
pitoncho
Drives: bmw e87
I think the problem is, that i touch in the settings, the optiom of put bmw x1 old interface, when i didnt have any navigation oem, on the original car it should stay a clock.. i need to know how to enter recovery to solve this thing
      12-08-2019, 02:14 PM   #1439
daschacka
Drives: M5Competition
You should be fine with rebooting with a default factory_config.xml
      12-08-2019, 02:48 PM   #1440
pitoncho
Drives: bmw e87
And how can i do that? i mean, where i need to put the config.xml, on the sd car?? amd where can i find that xml
thank you!
      12-08-2019, 03:04 PM   #1441
franbass
Drives: F30 330d
Yes, this is:
Your problem is the fiber optic connection. You should change the fiber optic from the original quadlock to android quadlock
      12-08-2019, 04:06 PM   #1442
pitoncho
Drives: bmw e87
i dont have fiber optic, i dont have another navi original.. only android radio. it is a configuration problem, but how to solve it
      12-08-2019, 04:56 PM   #1443
smahel
Drives: MINI Cooper, 2020 X1
I would also say that this is the cause. Remove the unit from the car and connect only the 12V power supply as shown. The unit should boot to Android and then you can fix the settings.
      12-08-2019, 06:14 PM   #1444
pitoncho
Drives: bmw e87
should i connect this cables to pins of quadlock radio?
Thank you, i will try that
      12-08-2019, 06:24 PM   #1445
Mjam
Drives: E87, i3, Taycan Cross Turismo
thank you!
Put then factory_config.xml in a folder named OEM on a USB stick. Insert and boot.
You can find the xml file in this post: https://f30.bimmerpost.com/forums/sh...postcount=1374
Note that the Factory settings password is changed to 0 (you can edit this in the file before updating).
      12-08-2019, 06:28 PM   #1446
pitoncho
Drives: bmw e87
Thank you soo much, i will try later both methods.
      12-09-2019, 01:59 AM   #1447
smahel
No, battery, or stabilized power supply
      12-09-2019, 02:36 AM   #1448
XbimE84
Drives: E84 Sdrive 2.0D
hi,
my unit has built in carplay with zlink, and android auto also suppose to work, but can't seem to start it. Do I have to start anything on the phone as well?
Overall this unit works very good, sound quality is amazing, no problems at all, same as OEM.
Minor bugs in scrolling with idrive.
Sometimes it affects sound volume (when I go to idrive it seems to be scrolling in aux settings).
When selecting music, if I scroll down, it goes one click up and then scrolls down.
That's it for now, have it only installed a day or 2.
Has anybody found how to activate BT under android settings?
kr
      12-09-2019, 02:52 AM   #1449
Kri
Austria
1084
Drives: E87
Originally Posted by XbimE84 View Post
hi,
kr
Your unit is px6 or sd625 with Android 9 ?
Does the idrive controller also Work with carplay?
Kri
      12-09-2019, 02:54 AM   #1450
XbimE84
Kri
snapdragon
yes it works, but my main phone is android so would like android auto to work
      12-09-2019, 03:19 AM   #1451
uris
Drives: F31
My friend
Connect Android to the table under the power supply
Show which version is android, store
      12-09-2019, 03:50 AM   #1452
pitoncho
Drives: bmw e87
Ok, i will try that, first i will try to put config file in sd, then if not work i will do it with power suply.. Thank you
