06-13-2020, 11:15 PM | #1 |
Rep 440
Drives: 2014 435i
Audio upgrade time
[img]
View post on imgur.com [/img]It's time to do something new to the car. I am thinking of going after the audio a little. I've got a 2014 F32 with the Hifi system. I would love some input on first audio upgrade. I am thinking of doing the following to start: Match up 7BMW amp 2 earthquake underseats (Im not expecting trunk box level sound from these) Is this a smart place to start? Any other suggestions? Thanks in Advance.
INSTA: roxy_F32
06-14-2020, 02:50 AM | #2 |
Rep 172
Drives: 2015 328i
That's what I have. Start with the amp. It made a huge difference. I did the underseat woofers about a year later. Honestly, if you will do a trunk sub down the line you can skip the underseat. I will not be doing it due to needed space and two kids.
06-14-2020, 10:44 AM | #3 | |
Rep 5,801
I have the next level up Top Hifi/HK system, so I don't know much about your Hifi amp. UPGRADE OF TOP HIFI/ HK SYSTEM I upgraded my underseat subs with the Earthquakes and used a separate combination LOC/amplifier from AudioControl to power them at 150watts/channel into 2 ohms. I searched far and wide. This particular AudioControl was the only piece I could find with every necessary feature for this peculiar BMW installation. It was small, had 40volt LOC inputs and 2x150watts into 2 ohms. EARTHQUAKE UNDERSEAT SUBS The results: the Earthquakes with the correct amount of power sound amazing. They were exactly what the H/K system was lacking. The rest of the H/K speakers are great, but the stock subs in those small underseat sub boxes are the weak point. I didn't tell my family and friends exactly what I had done, and they thought that I had upgraded all of the speakers. Caveat: the underseat subs are never going to rumble the cars around you stopped at a red like a 12" subwoofer mounted in your trunk. But they fill up the car just fine. BEFORE/AFTER MUSIC COMPARISON I don't usually talk about music because tastes vary widely. My before/after test music was: U2 because of the strong bass lines in most of their songs, so a difference over stock can easily be heard. Vintage YES music because Chris Squire is the best bass player in the world. Squire plays every bass note with a heavy pick like a rock guitarist. With the Earthquakes I can finally hear every nuance of the bass notes in my car like on home audio. Vintage Genesis music because there is nothing like properly hearing Mike Rutherford's bass pedals come into a song. Also many of my favorite drummers because proper subwoofers deepen and broaden the range of their kits to how they were meant to be heard. But enough of that... MATCHUP AMPLIFIER & EARTHQUAKES I just read up on the MatchUp amp. Price tag is really high at $1,000, but seems to offer the advantage of plug-n-play. I don't know what other amp options there are for the BMW midrange Hifi system. I do not know if the issue to the sound of the Hifi system is the same as the issue that I noticed with the Top Hifi/HK audio system where the speakers were fine but the underseat subwoofers were lacking. The MatchUp amp specs (subs get 2x 160 watts/channel into 2 ohms each) seem to provide the power needed by the Earthquakes. MAXIMUM POWER TO EARTHQUAKES FYI- during my installation I had a conversation with a very knowledgeable guy at Earthquake tech support. He told me to consider the 2x 150 watts/ channel into 2 ohms that my AudioControl amplifier would put out to be the maximum that the Earthquakes could handle. He suggested that I throttle the AudioControl back to 80%-90% of its maximum. So if you get the MatchUp amp that puts out 2x 160 watts, then I suggest that you do the same. I read some subsequent complaints from guys claiming that the blew out the Earthquake underseat subs. I suspect that they connected them to an amp with too much power or a cheap amp that spiked at higher amounts that caused a problem. Guys constantly wrote to me asking if they could just reuse this or that old amp sitting on their garage shelf, and never wanted to hear "No, your old amp doesn't meet the needed specs." EARTHQUAKE PART NUMBERS/ PRICING The best price that I found on the Earthquakes was on Walmart online for $109 each, but the same reseller is now selling them on Amazon for $109 also. Make sure to get the 2-ohm model, SWS-8Xi. You will also need a pair of spacer rings. There are two kinds based on wiring connection. 1) Earthquake sells them for ~$22/pair. (Part# R8SWS) They have spring loaded posts in the stock location that make it easy to connect your own speaker wiring. I used these along with 14 gauge twisted speaker wire. https://www.amazon.com/Earthquake-So.../dp/B00G2MKGOU Shielded wire would have been even better. I wanted to upgrade from the car's speaker wire which was probably 16g or 18g, because I was putting more power to the underseat subs. The newtis website was helpful in understanding how to remove interior panels which was easier than I expected. Just only do one side of the car a time so you have the other side to refer to to put things back together. 2) Technicpnp sells spacer rings that have OEM wiring connectors on them in the OEM wiring location. This makes it simple to reuse the stock car wiring to the underseat subs. They are $65/pair but well worth it. UPDATE: TECHNICPNP STOPPED SELLING THEIR SPACER RINGS. JUST GET EARTHQUAKE SPACER RINGS AT $27/PAIR. CLIP THE WIRES LEAVING ABOUT 1-2 INCHES OF WIRE IF YOU EVER WANT TO REINSTALL. STORE THE STOCK CONNECTORS WITH THE STOCK SUBS. THEN JUST STRIP THE WIRES AND CONNECT TO EARTHQUAKE SPACER RINGS. https://technicpnp.com/product/sws-8...er-connectors/ EARTHQUAKE UNDERSEAT INSTALLATION This cheap plastic trim tool kit was helpful. https://www.harborfreight.com/Trim-A...-Pc-64126.html This metal tool was helpful http://www.walmart.com/ip/Hyper-Toug...4008/443274151 Watch this video starting at 14:16 to see how to physically install the Earthquakes Tips: it helps to use the electric motor control to slide the seat forward and back to access the four hold down bolts. I trimmed the edges of my factory carpeting back with scissors so it didn't interfere with the subs. AUDIOCONTROL LOC/AMPLIFIER I already mentioned that the combination of necessary specs for LOC and amplifier was difficult to find. The AudioControl model ACM-2.300 matched all of the needed specifications perfectly. It retails for $330. It can often be found for 10%-20% off if you watch for sales/coupons. (SonicElectronix May provide a 10% first buyers discount?) https://www.crutchfield.com/S-5wIMCf...ACM-2-300.html TECHNICPNP WIRING HARNESS This harness is necessary to connect a secondary amplifier without splicing into the expensive BMW wiring harness. $85 Note: This is a different product from the one specific to my TopHifi/HK installation. I bought just the harness for $50. This new product includes a separate small LOC that appears like it could be located near the stock amplifier in the left alcove area of the trunk. So this would provide options for other secondary amplifiers that may cost less. https://technicpnp.com/product/hifi-...ssloc/#reviews MISCELLANEOUS I probably spent another $60 for a high quality power line fuse, wiring connectors, wire and mounting hardware to complete the entire project. MATCHUP AMPLIFIER UPGRADE Besides the two 160 watt channels to the underseat subs, the MatchUp amplifier provides front, rear, and center channels: 65 watts RMS x 5 at 4 ohms plus Match Up's DSP adjustability. I don't have anyway to judge how much of an improvement that would provide to the other five speakers, if any. (I don't know what watts/channel the stock amp provides.) EARTHQUAKE PRICING Note: This price doesn't change either way $218 (2) Earthquake SWS-8Xi $65 (1 pair) Technicpnp Spacers ——— $279 SECONDARY AMPLIFIER Note: This price will likely be much less because now with the PNP Harness/LOC, a lower cost amplifier-only option could be chosen. $297 AudioControl LOC/Amplifier $85 Technicpnp Harness/LOC $60 Miscellanies fuse, wiring, connectors ——- $442 Guessing this would drop to $300-$350 So the cost between installing the Earthquake Subwoofers with their own dedicated secondary amplifier VS installing the Earthquake Subwoofers as part of a MathUp Amplifier upgrade is $650-$700 Hope this information is helpful! |
Billfitz8621.00 boyerstyle89.50 FastFrog145.00 otay826.50 rytec2.50 ReMiii4021.50 BZHPhil0.00 cpdelta0.00 rusty_sojah69.50 |
06-15-2020, 10:35 PM | #4 |
Rep 440
Drives: 2014 435i
Wow, thanks a ton!! That info is so helpful! Thank you for the breakdown of it all. Sounds like I am on the right track? Billfitz has been a great voice of reason with the OEM speaker quality as well. Thank you both. Huge help!
INSTA: roxy_F32
06-18-2020, 04:41 AM | #5 | |
Rep 611
I am glad this upgrade works for you, however want to share some of my experiences, as they differ from yours...
To my ears, the HK mids are absolutely awful. They sound muddy, lack dynamics, have limited freq range, the sound is distorted... and the build is a joke. If somebody is looking primarily for the "boom", upgrade of woofers can make sense. However, the biggest improvement in sound quality comes from better mid speakers. Not to mention that HK mids are very poor at lower freqs, thus upgrading the underseat woofers for subs crossed at sub-bass freqs results in the range, that is not covered by any speaker. |
06-18-2020, 04:45 AM | #6 | ||
Rep 5,801
06-18-2020, 05:22 AM | #7 | |
Rep 500
J555571.50 |
06-18-2020, 05:45 AM | #8 | |
Rep 611
While I have listened to only some of them, I am sure that any of the reputable brand upgrades available on the market (as Audison, Focal, Rockford Fosgate, MTX, Eton, etc.) will make a night and day difference to stock HK speakers... |
pierreye210.50 |
06-02-2022, 12:10 PM | #9 | |
Rep 4,136
excellent write up. I have the harmon kardon with bav sound ghost subwoofers? Can i still use the same amp method? Will this help the other speakers as well? I believe the ghost woofers are 8 ohms tho |
06-02-2022, 09:43 PM | #10 |
Rep 16,674
You may, but the Bavsound woofers are no better than OEM. Look familiar? https://www.aliexpress.com/item/3256...apt=4itemAdapt
The Earthquakes are much better. |
08-11-2022, 11:14 AM | #11 | |
Rep 760
08-11-2022, 11:24 AM | #12 |
Rep 16,674
It's not difficult, you go to aliexpress, search BMW speakers. The midranges: https://www.aliexpress.com/item/3256...80119986%21rec
Jaya36661.00 |
08-11-2022, 11:45 AM | #13 | |
Rep 760
Lol you basically open up their secret sauce
I notice the brand for the tweeter and midrange is the same. And these chinese speakers are not any better than the oem hifi or even oem harman kardon? Quote:
08-11-2022, 01:01 PM | #14 |
Rep 16,674
One can't say for sure, since they don't list Thiele/Small parameters or post legitimate SPL charts. But there's no reason to think they're as good, let alone better. I've yet to come across a 'BMW speakers are junk' comment coming from a professional acoustical engineer.
johnung4945.50 |
08-19-2022, 03:39 PM | #16 |
Rep 16,674
08-26-2022, 06:21 AM | #18 | |
Rep 5,801
Suggest swapping in the Match 7BMW amp (assuming you have the BMW Hifi system) and the Earthquake SWS-8Xi subwoofers. Then listen and decide if you wish to do anything else. |
Billfitz8621.00 |
08-26-2022, 08:54 AM | #19 |
Rep 16,674
I do not recommend changing the mids and tweeters. I have yet to see any real data that proves the worth of aftermarket mids and tweeters, only unsubstantiated advertising piffle. I posted the AliExpress link to point out where Bavsound imports their speakers from, and what is a more reasonable price for them. It's not an endorsement. Quite the contrary, in fact.
johnung4945.50 |
12-27-2022, 11:21 AM | #20 | |
Rep 76
Also, would you mind posting the Technicpnp wiring harness that you went with? I have the HK system and believe you do as well and mentioned you used a different one then posted above? Is there anything else I need to do/require? I'll also need to connect the new amp to the battery, but nothing else correct? Last edited by cooombs; 12-27-2022 at 11:30 AM.. |
12-27-2022, 12:18 PM | #21 | |
Rep 5,801
Clip off the stock BMW connectors from the stock subwoofers, leaving a few inches of wire coming out of them and store the connectors with your stock subs in case you ever want to reinstall them. Then just strip the two wire ends and insert them into the red/black spring posts on the Earthquake spacers. Easy! Also need: 1) Technicpnp harness. See photo. 2) Connections to power and ground. 3) Connection to fuse box under trunk floor. This triggers AudioControl amp to turn on/off with car’s ignition. I have previously posted tons of details and photos on the above. Just search through Bimmerpost. |
01-15-2023, 11:01 PM | #22 | |
Rep 326
Drives: 2014 f30 335i m-sport/ estoril
2014 f30 335i m-sport/ estoril blue/ m power kit/ m performance package
