BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > BMW 437M wheels (Black M4 wheels)
      10-22-2016, 06:40 PM   #89
FeelinBlessed
FeelinBlessed's Avatar
227
Drives: 2017 340i AW MPPSK/Track
2017 BMW  [0.00]
Originally Posted by Kabrich View Post
Originally Posted by FeelinBlessed View Post
[B]^Nice!
Here's mine as of yesterday
Lowered using?
AC Schnitzer Springs
Didn't want to give up EDC
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
      10-26-2016, 08:42 PM   #90
Gabo435i
Drives: 2014 435i MSPORT
^Nice!
Here's mine as of yesterday (sitting on AC Schnitzer)
OEM 437m from M4
Was supposed to install the IND reflectors but USPS did not deliver....
Could you tell what tire setup you have and the brand?
      10-27-2016, 11:12 AM   #91
FeelinBlessed
227
2017 BMW  [0.00]
See post #81
      12-12-2016, 01:09 PM   #92
qgshadow
Drives: 2020 m340i
If i already have M Adaptive Suspension, can i just change the springs to lower the car or i need to change the dampers too? If so will i lose the Adaptive part of it?
      12-12-2016, 01:19 PM   #93
FeelinBlessed
227
2017 BMW  [0.00]
Any dinan, acs, h&r springs will work with the stock dampers. No need to change the dampers. You should be aware that some have argued using lowering springs without changing the dampers will cause the car to be bouncy and premature damper wear.
      12-12-2016, 02:10 PM   #94
qgshadow
Drives: 2020 m340i
Alright thanks, i'll take a look
      12-12-2016, 04:19 PM   #95
BASELINE
Drives: A few...
Anyone running M4 size tires 255/35-19 fronts 275/30-19 rears on an XDrive car?
      12-13-2016, 11:16 PM   #96
Kabrich
Drives: '13 AH3 (335IH) 3F93 MSport
Not an answer to your question, but an observation from someone who has used 275s.
http://f30.bimmerpost.com/forums/sho...0&postcount=20
      12-14-2016, 03:40 AM   #97
larrylam646
larrylam646's Avatar
Drives: 2020 M340i xDrive
M3/M4 OEM tire size on the 437M wheels is 255/35-19 and 275/35-19.
This setup will not work properly with xDrive. The wheel diameter between the F/R is too great and will cause issues with the transmission. In my case, the transmission was not shifting smoothly and after further research,some references suggest to keep the difference in wheel diameter below 3%.
I went with 245/40-19 in the front to keep the % difference as close to OEM stagger as possible.
I have a slight rub when turning on the driver side front inner wheel liner where it protrudes for the side view camera and park assist sensor . I am lowered ~0.5".
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold
      01-12-2017, 12:59 AM   #98
GCinFLA
This hit me this evening for some odd reason.
For the Car Techies/Gear Heads.
Are the Alignment, Camber, Caster, Cross-Camber, Cross-Caster and Toe same for F30 403m @ 225/40R19 and F80 437m @ 255/35R19 and their different ET?
If not, then it would seem F30s with 437m should be setup with F80 Specs???
As I do not know tech specs for both, I am throwing it out here for those gearheads that are into these numbers.
      01-12-2017, 05:53 AM   #99
63MM
Drives: 2016 X5M LBB
Are you running 275/30 for the rears?
      01-20-2017, 12:36 AM   #100
mhshah88
Drives: 2016 F32 435I COUPE
I saw this thread and done my car
2016 435I OEM 437M wheels
YR430D45.50
cdwalls703.00
NCG80M3663.50
      01-20-2017, 12:47 PM   #101
FeelinBlessed
227
2017 BMW  [0.00]
^very nice yo!
      01-20-2017, 04:15 PM   #102
Kabrich
What size tire did you use?
      01-20-2017, 05:57 PM   #103
///Master
Drives: 08 BMW M3 Coupe
OEM w/ Continentals
      01-20-2017, 07:29 PM   #104
Kabrich
Originally Posted by davidschi View Post
OEM w/ Continentals
As F3x do not have 437m OEM, your response doesn't really help.
OEM for 19" F30 403m?
OEM for M2 437m?
OEM for M3/M4 437m?
Options I probably haven't thought of......
Continental DWS, 5P, 6 SC6 or something else?
      01-21-2017, 12:33 AM   #105
mhshah88
Michelin pilot super sport - Front 255/35/19, Rear 265/35/19,
The wheels came of F80 M3 with 275 rears, wasn't happy so last month moved down to 265's which are much better.
Kabrich355.00
      01-21-2017, 12:37 AM   #106
Kabrich
Thank you.
FWIW, you are at least the second F3x OEM 437m owner I've read on forum state they ditched the 275 rears.
Was it comfort of ride or something else?
Btw, your car looks great.
      01-24-2017, 07:52 PM   #107
mhshah88
Thank you.
Hey Thanks!
It looked to buggy like is that makes sense, also I am considering lowering springs, I am not sure if I am now, but car would rub on 275's, I urgently needed rear tires and I just closed my eyes and went for 265's, and looks much better, no obvious difference in ride comfort, and looks lower from the rear. I would not recommend 275's, My wheels came of a f80 m3 therefore has 275s fitted.
Kabrich355.00
      02-15-2017, 11:09 AM   #108
///Master
I apologize.. These are OEM tires for BMW M4 437M
Continental SportContact 5P
Fr: 255/35/19
Rr: 275/35/19
OEM for M2 437m?
OEM for M3/M4 437m?
Kabrich355.00
      03-10-2017, 10:07 AM   #109
rir9005
Drives: 2016 grand coupe 428i
Awesome!
      03-26-2017, 06:35 PM   #110
Robby29
Robby29's Avatar
Drives: AP M4 / Z3 2.8
My turn to contribute
KW SC and stock RFTs
Appreciate 12
