11-02-2018, 08:07 AM | #1937 | |
Rep 1,499
I made an Excel spreadsheet that accounts for the fuel in the tank, ethanol content and octane then I can manipulate the additional gasoline and ethanol added to calculate my new ethanol content and octane. An easier way is to run the tank almost completely empty so you have a fresh start. I also will run through a couple tanks of only gasoline to get a definite fresh start.
ceedawg467.50 |
11-02-2018, 11:05 AM | #1938 | |
Rep 1,288
That E85 sensor is a great idea.... but no matter what you need some kind of tester for the pump before the fill up.... E85 at the pump could be E40 Last edited by FastF30; 11-02-2018 at 11:12 AM.. |
11-02-2018, 11:25 AM | #1939 |
Rep 525
I thought they all had to be between a specific range, depending on the season/blend? I don't think they can market it as E85 when it's below 70% (winter blend).
11-02-2018, 11:47 AM | #1940 |
Rep 1,288
Well the video and from what I've read from numerous sources is that E85 is never E85 and that you should always check and adjust accordingly especially if you plan at running at the max limit...
ronanz1819.50 |
11-02-2018, 05:14 PM | #1941 |
Rep 160
I miss my Evo days when I could just run pure e-85 without having worry about mixing, lol..
Check out my log I took on the way home from work... It seems I might have a boost leak. Anything else look off? 91 octane, stage 2 with vrsf 5" hd fmic, charge pipes, and down pipe and afe dry panel filter @ 2000ft elevation. http://www.bootmod3.net/log?id=5bdcc48cd10b437ebbf3391e Last edited by Guerillah; 11-02-2018 at 05:38 PM.. |
11-02-2018, 08:23 PM | #1942 | |
Gettin It Figured Out
1820
Rep 2,669
11-03-2018, 06:23 AM | #1943 | |
Rep 1,348
2k15 335i Msport xdrive 6spd
11-03-2018, 10:02 AM | #1944 | |
1820
Rep 2,669
Kit utilizing its own App.. Android App IOS My kit was installed in same location as video...Hope that helps .. .
FastF30521.00 |
11-03-2018, 01:01 PM | #1945 | |
Rep 1,348
11-11-2018, 02:05 PM | #1946 |
Rep 1,862
Drives: powered by bootmod3
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
PabloK597.00 |
11-13-2018, 11:48 AM | #1947 |
Rep 93
F30_SixSpeed1170.50 |
11-21-2018, 09:00 AM | #1948 |
Rep 145
Hello All,
Rookie question. I'm going to be getting a FMIC, cp, and catless dp installed at a shop about 25miles from home and then will run the bootmod3 stage 2. Should I tune the car to stage 2 before the bolt ons are installed, or drive back and then tune the car? Don't know which is the safer option for the vehicle. Thanks! Last edited by Waltabeast; 11-23-2018 at 03:39 PM.. |
11-21-2018, 09:05 AM | #1949 | |
Rep 220
Drives: 22 X3 M40i
Garage List 1991 Toyota Pickup ... [0.00]
1997 Nissan 200SX S ... [0.00] 2006 Mitsubishi Lan ... [0.00] 2009 BMW 335i [0.00] 2015 BMW X3 M Sport [0.00] |
Waltabeast72.00 |
11-21-2018, 11:23 AM | #1950 | |
Rep 1,753
Waltabeast72.00 |
11-24-2018, 02:09 PM | #1951 |
Rep 145
11-24-2018, 02:25 PM | #1952 | |
Rep 1,753
11-26-2018, 04:03 PM | #1953 |
Rep 40
Has anyone come across the DME details unavailable error??? I’m trying to activate my license and when I open up the bootmod3 agent it connects to the car and pulls the VIN however it fails to retrieve the software version of my DME and states “error DME details unavailable” I opened a ticket with PTF but the service has been subpar so far... I’ve tried all the troubleshooting steps such as disconnecting the negative terminal on the battery and all settings on my laptop have been adjusted accordingly. I’m not sure if there’s something I may be missing? If anyone has some insight I would greatly appreciate it!
11-26-2018, 04:11 PM | #1954 | |
Rep 1,862
11-26-2018, 04:23 PM | #1955 |
Rep 40
11-26-2018, 11:37 PM | #1957 | |
1820
Rep 2,669
Yes .
11-27-2018, 05:34 AM | #1958 |
Rep 373
can i fitt the NGK plugs gapped to 0.022 as well as my other stage two mods(dp intake FMIC) and then drive down the road with the stock file (basically 1 mile) to my tuner to have the car flashed with stage 2 91 bm3 is this safe?
